chanbennet
New member
Hi all, sure I am missing something simple here. I am attempting to get a basic transmit/ receive between two teensy 4.0's with Reyax RLYR890 modules. I can get printing messages on the transmitter side but have yet to be able to receive anything on the receiver side. The connections are as follows...
Transmitter & receiver connections
Teensy LoRA
Pin 0 > TX
Pin 1 > RX
Pin GND (by 28) > GND
Pin 3.3v (by 30) > VDD
Here is the datasheet and AT Command information for the Reyax modules.
Transmitter code
Any and all help is very much appreciated! Thank you.
Teensy LoRA
Pin 0 > TX
Pin 1 > RX
Transmitter code
#include <SoftwareSerial.h>
#define HWSERIAL Serial1
void setup(){
HWSERIAL.begin(115200);
delay(20);
HWSERIAL.print("AT\r\n");
Serial.print("AT\r\n");
HWSERIAL.print("AT+RESET\r\n");
Serial.print("AT+RESET\r\n");
HWSERIAL.print("AT+IPR=115200\r\n");
Serial.print("AT+IPR=115200\r\n");
HWSERIAL.print("AT+ADDRESS=1\r\n");
Serial.print("AT+ADDRESS=1\r\n");
HWSERIAL.print("AT+NETWORKID=5\r\n");
Serial.print("AT+NETWORKID=5\r\n");
HWSERIAL.print("AT+MODE=0\r\n");
Serial.print("AT+MODE=0\r\n");
HWSERIAL.print("AT+BAND=868500000\r\n");
Serial.print("AT+BAND=868500000\r\n");
HWSERIAL.print("AT+PARAMETER=10,7,1,7\r\n");
Serial.print("AT+PARAMETER=10,7,1,7\r\n");
delay(20);
void loop(){
HWSERIAL.print("H");
HWSERIAL.print("AT+SEND=2,1,H");
Serial.print("H");
HWSERIAL.print("L");
HWSERIAL.print("AT+SEND=2,1,L");
Serial.print("L");
const int ledPin =13;
int incomingByte;
void setup(){
pinMode(ledPin,OUTPUT);
delay(20);
delay(200);
delay(200);
Serial.print("AT+ADDRESS=2\r\n");
HWSERIAL.print("AT+ADDRESS=2\r\n");
delay(200);
delay(200);
delay(200);
delay(200);
delay(200);
void loop(){
if (Serial.available() > 0) {
incomingByte = Serial.read();
if (incomingByte == 'H') {
Serial.print("high");
HWSERIAL.print("high");
digitalWrite(ledPin, HIGH);
if (incomingByte == 'L') {
Serial.print("low");
HWSERIAL.print("low");
digitalWrite(ledPin, LOW);
if (HWSERIAL.available() > 0) {
incomingByte = HWSERIAL.read();
