//the reason there are 3 of everything is: in order to overlap the output blocks, 2 are needed to start with. it takes 2 to make an overlap. this is done in setup().
//after that, only 1 further block is needed at a time in order to overlap with the previous results. this is done in loop().
#define ARM_MATH_CM7
#include <Audio.h> //for audio functions
#include <Wire.h> //for connecting objects together
#include <SD.h> //for SD card
#include <arm_math.h> //for CMSIS_DSP FFT
#include <Bounce.h> //for switches
//Declare constant variables
const int baudRate = 115200;
const uint32_t blockSize=AUDIO_BLOCK_SAMPLES; //C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4\AudioStream.h has #define AUDIO_BLOCK_SAMPLES 128
const uint16_t fftLen=blockSize; //length of FFT, 128 if blockSize
//Create pointers to be assigned to input and output buffers, create input/output arrays
//Teensy audio library works on int16_t (equivalent in size with q15 data), the FFT is running on f32 data
int16_t * ptr_in1; //used in setup(), pointer to first block of 128 samples captured by Q_1_rec.readBuffer
int16_t * ptr_in2; //used in setup(), pointer to second block of 128 samples captured by Q_1_rec.readBuffer
int16_t * ptr_in3; //used in loop(), pointer to each successive block of 128 samples after the first 2
int16_t * ptr_out; //used in setup and loop, pointer to output used by Q_1_play.getBuffer to playback the audio
float32_t inputbuffer1[blockSize]={0}; //output of arm_q15_to_float, input to trianglebuffer, for first audio block
float32_t inputbuffer2[blockSize]={0}; //output of arm_q15_to_float, input to trianglebuffer, for second audio block
float32_t inputbuffer3[blockSize]={0}; //output of arm_q15_to_float, input to trianglebuffer, for successive audio blocks
float32_t trianglebuffer1[blockSize]={0}; //make a triangle out of inputbuffer1 and feed to FFT
float32_t trianglebuffer2[blockSize]={0}; //make a triangle out of inputbuffer2 and feed to FFT
float32_t trianglebuffer3[blockSize]={0}; //make a triangle out of inputbuffer3 and feed to FFT
float32_t FFToutputbuffer1[blockSize]={0}; //output of FFT, input to peak picking buffer
float32_t FFToutputbuffer2[blockSize]={0}; //output of FFT, input to peak picking buffer
float32_t FFToutputbuffer3[blockSize]={0}; //output of FFT, input to peak picking buffer
float32_t peakpickbuffer1[blockSize]={0}; //input to IFFT
float32_t peakpickbuffer2[blockSize]={0}; //input to IFFT
float32_t peakpickbuffer3[blockSize]={0}; //input to IFFT
float32_t IFFToutputbuffer1[blockSize]={0}; //output of IFFT, take first 64 samples (index 0-63) and store in rising1, take last 64 samples (index 64-127) and store in falling1
float32_t IFFToutputbuffer2[blockSize]={0}; //output of IFFT, take first 64 samples (index 0-63) and store in rising2, take last 64 samples (index 64-127) and store in falling2
float32_t IFFToutputbuffer3[blockSize]={0}; //output of IFFT, take first 64 samples (index 0-63) and store in rising3, take last 64 samples (index 64-127) and store in falling3
float32_t overlapbuffer1[blockSize]={0}; //not used :(
float32_t overlapbuffer2[blockSize]={0}; //not used
float32_t overlapbuffer3[blockSize]={0}; //not used
float32_t rising1[blockSize]={0}; //the first 64 samples of IFFT1. the first 64 samples of the first and only the first output block
float32_t rising2[blockSize]={0}; //the first 64 samples of IFFT2
float32_t rising3[blockSize]={0}; //the first 64 samples of IFFT3
float32_t falling1[blockSize]={0}; //the last 64 samples of IFFT1
float32_t falling2[blockSize]={0}; //the last 64 samples of IFFT2
float32_t falling3[blockSize]={0}; //the last 64 samples of IFFT3
float32_t overlapbuffer2_last[blockSize]={0}; //not used
float32_t overlapbuffer_f2r1[blockSize]={0}; //not used
float32_t overlapbuffer_f1r2[blockSize]={0}; //falling1 plus rising2. the last 64 samples of the first output block, and the first 64 samples of the next block
float32_t outputbuffer[blockSize]={0}; //used in setup and loop. it gets converted from f32 to q15 for playback by teensy. first 64 are the last 64 from previous loop. last 64 are previous falling plus current rising.
float32_t falling_prev_prev[blockSize]={0}; //not used
float32_t falling_prev[blockSize]={0}; //equal to falling2 in the first pass, on successive passes, equal to previous falling edge before output, equal to current falling edge after output, which on the next loop will be previous falling edge
float32_t rising_prev[blockSize]={0}; //not used
float32_t rising_current[blockSize]={0}; //not used. it's what rising3 should be, maybe a better name than rising3 would be _current, or _loop. would apply to all 3's
float32_t prev64_127[blockSize]={0}; //in setup which does the first output block, it's overlapbuffer_f1r2. in loop, outputbuffer gets its value in the first 64 indexes. after output, it gets the last 64 indexes of outputbuffer.
//Instantiate audio library objects, make connections
AudioInputI2S i2s_in; //Audio input on i2s bus from the teensy audioshield adapter board
AudioOutputI2S i2s_out; //Audio output on i2s bus to the audioshield
AudioRecordQueue Q_1_rec; //Object for storing audio blocks and accessing as arrays
AudioPlayQueue Q_1_play; //object to write array to for output
AudioConnection patchcord1(i2s_in,0,Q_1_rec,0); //connect audio input to the object for storing audio blocks and accessing as arrays
AudioConnection patchcord2(Q_1_play,0,i2s_out,0); //connect the array object for output to audio output channel1 (L or R)
AudioConnection patchcord3(Q_1_play,0,i2s_out,1); //connect the array object for output to audio output channel2 (L or R)
AudioControlSGTL5000 sgtl5000; //call the IC on the audioshield
arm_rfft_fast_instance_f32 FFT; //instantiate FFT as required by CMSIS_DSP https://arm-software.github.io/CMSIS_5/DSP/html/group__RealFFT.html#gac5fceb172551e7c11eb4d0e17ef15aa3
//Define input to system. Uncomment the input you want to use
//const int input = AUDIO_INPUT_MIC;
const int input = AUDIO_INPUT_LINEIN;
// a bit of helper for printing stuff to serial monitor in a nicer format
constexpr size_t length_format_buffer {64};
char format_buffer[length_format_buffer];
void serial_print_int_width_4(unsigned int input){
snprintf(format_buffer, length_format_buffer, "%03i", input);
Serial.print(format_buffer);
void serial_print_float_width_16_prec_8(float input){
dtostrf(input, 8, 4, format_buffer);
// put your setup code here, to run once
Serial.begin(baudRate); //for serial print if needed?
AudioMemory(10); // Audio connections require memory to work. For more detailed information, see the MemoryAndCpuUsage example
//enable audio shield, select input/mic gain, and initialize output level
sgtl5000.enable();
sgtl5000.inputSelect(input);
sgtl5000.micGain(60);
sgtl5000.volume(0.5);
arm_rfft_fast_init_f32(&FFT,fftLen); //initialize FFT as required by CMSIS_DSP arm_rfft_fast_f32
//Begin the record audio queue
Q_1_rec.begin();
delay (8); //allow time for 2 sample blocks to be acquired. empirically 8 ms.
if(Q_1_rec.available() >=2 ) { //execute if 2 blocks have been acquired
Serial.println(Q_1_rec.available()); //print number of blocks in queue to serial monitor. should be 2
ptr_in1 = Q_1_rec.readBuffer(); //copy addresses of 128 samples in queue block to ptr_in1
Q_1_rec.freeBuffer(); //free the queue of the previous block
Serial.println(Q_1_rec.available()); //print number of blocks in queue to serial monitor. should be 1
ptr_in2 = Q_1_rec.readBuffer(); //copy addresses of 128 samples in queue block to ptr_in2
ptr_out = Q_1_play.getBuffer(); //get pointer to output buffer "empty" array
//teensy audio works in q15 format. FFT works better in F32 format due to the dedicated FPU on the teensy. convert and store in inputbuffer
arm_q15_to_float(&ptr_in1[0],&inputbuffer1[0],blockSize);
arm_q15_to_float(&ptr_in2[0],&inputbuffer2[0],blockSize);
//make triangles of input blocks 1 and 2
for (int i=0; i<64; i++){
trianglebuffer1[i] = inputbuffer1[i] *(i+1)/64; //index 0 = input * 1/64, index 63 = input * 64/64
trianglebuffer1[128-(i+1)] = inputbuffer1[128-(i+1)] *(i+1)/64; //index 127 = input * 1/64, index 64 = 64/64
trianglebuffer2[i] = inputbuffer2[i] *(i+1)/64;
trianglebuffer2[128-(i+1)] = inputbuffer2[128-(i+1)] *(i+1)/64;
//do the FFT on the triangles and output to FFToutputbuffer. Third argument 0 is for forward FFT, vs 1 for inverse FFT.
arm_rfft_fast_f32(&FFT,&trianglebuffer1[0],FFToutputbuffer1,0);
arm_rfft_fast_f32(&FFT,&trianglebuffer2[0],FFToutputbuffer2,0);
//peak picking. set i<peaks, 128 for all peaks
for (int i=0; i<128; i++){
peakpickbuffer1[i] = FFToutputbuffer1[i];
peakpickbuffer2[i] = FFToutputbuffer2[i];
//Do IFFT on peaks picked. Third argument 1 is for inverse FFT, vs 0 for forward FFT.
arm_rfft_fast_f32(&FFT,peakpickbuffer1,IFFToutputbuffer1,1);
arm_rfft_fast_f32(&FFT,peakpickbuffer2,IFFToutputbuffer2,1);
//take each edge of each triangle to help follow wtf is going on
rising1[i] = IFFToutputbuffer1[i]; //triangle1 rising edge
falling1[i] = IFFToutputbuffer1[64+i]; // triangle1 falling edge
rising2[i] = IFFToutputbuffer2[i]; //triangle2 rising edge
falling2[i] = IFFToutputbuffer2[64+i]; //triangle2 falling edge
overlapbuffer_f1r2[i] = falling1[i] + rising2[i]; //falling1 plus rising2
prev64_127[i] = overlapbuffer_f1r2[i]; //prev64_127 will be used in loop(), since the first part of each output is the same as the last part of the previous output
falling_prev[i] = falling2[i]; //falling_prev will be used in loop(), added to the current rising edge for the 64-127 samples of each output block
outputbuffer[i] = rising1[i]; //first part of output block is triangle1 rising edge
outputbuffer[64+i] = overlapbuffer_f1r2[i]; //second part of output block is falling1 plus rising2
arm_float_to_q15(&outputbuffer[0],&ptr_out[0],blockSize); //convert from F32 back to Q15 for teensy audio output
Q_1_play.playBuffer(); //output first block to headphone jack
Serial.println("Setup done"); //indicate success to serial monitor
else{
Serial.println("Something went wrong"); //indicate otherwise
} //end void setup() {
// put your main code here, to run repeatedly
if(Q_1_rec.available()){ //check to see if there is a queue block available.
ptr_in3 = Q_1_rec.readBuffer(); //copy addresses of 128 samples in queue block to ptr_in3
arm_q15_to_float(&ptr_in3[0],&inputbuffer3[0],blockSize); //convert Q15 to F32
//make triangle of input block
trianglebuffer3[i] = inputbuffer3[i] *(i+1)/64; //index 0 = input * 1/64, index 63 = input * 64/64
trianglebuffer3[128-(i+1)] = inputbuffer3[128-(i+1)] *(i+1)/64; //index 127 = input * 1/64, index 64 = 64/64
arm_rfft_fast_f32(&FFT,&trianglebuffer3[0],FFToutputbuffer3,0); //FFT on current triangle
//peak pick current FFT output spectra. set i<peaks. set i<128 for all peaks.
peakpickbuffer3[i] = FFToutputbuffer3[i];
arm_rfft_fast_f32(&FFT,peakpickbuffer3,IFFToutputbuffer3,1); //IFFT of peaks picked
//separate triangle edges for ease of understanding
rising3[i] = IFFToutputbuffer3[i]; //current triangle rising edge
falling3[i] = IFFToutputbuffer3[64+i]; //current triangle falling edge
outputbuffer[i] = prev64_127[i]; //the first part of the output block, index's 0-63, are always the last part, index's 64-127, of the previous block (overlapping)
outputbuffer[64+i] = falling_prev[i] + rising3[i]; //the last part of the output block, index's 64-127, are always the previous falling edge, plus the current rising edge (overlapping)
prev64_127[i] = outputbuffer[64+i]; //after output, update prev64_127 with the last part of the output block, to be used as the first part of the next output block in the next loop
falling_prev[i] = falling3[i]; //after output, update falling_prev with current falling edge, to be added to next rising edge, for last part of next output block
arm_float_to_q15(&outputbuffer[0],&ptr_out[0],blockSize); //convert the output block to Q15 for teensy audio playback
Q_1_rec.freeBuffer(); //free the record buffer for the next block on the next loop
Q_1_play.playBuffer(); //output the buffer to be played
} //end if(Q_1_rec.available()){
} //end void loop() {
