After getting OTA to work (albeit very slowly) with VS2019/VM and a custom C# program, I decided to try again using Tera Term's macro language to automate the .HEX transfer step. This required some changes to my VS2019/VM 'board.txt' post-build command, and the creation of an appropriate '.TTL' Tera Term macro file.
Here is the VS2019/VM 'board.txt' file:
And the Tera Term macro file:
And the demo sketch 'TeensyOTADemo.ino
For all the gory details, see my 'Paynter's Palace' blog post here
I have also created a GitHub repository containing the Tera Term script file and the demo sketch file. My hope in creating the GitHub repository is that others may contribute improvements and extensions.
Frank
# Teensy OTA Demo build property overrides
# 10/05/21 gfp - trying to run a post-build command
# 10/15/21 gfp - change to use Tera Term macro vs custom C# program
recipe.hooks.postbuild.1.pattern=cmd.exe /c "c:\Program Files (x86)\teraterm\ttpmacro.exe" /v "c:\users\Frank\Documents\Arduino\Teensy Projects\TeensyOTADemo\TeensyOTA1.ttl" "{vm.runtime.build.final_output_path}" {serial.port} {build.project_name}
16 October 2021 G. Frank Paynter
Tera Term macro to connect to Teensy and send latest .HEX file
Tera Term is called via a post-build command in VS2019/VMicro
like <path_to_ttpmacro.exe> /v <path_to_TeensyOTA1.ttl> <build_path>\<project_name>.hex> <COM port>
The actual post-build command is contained in the 'board.txt' file as follows:
recipe.hooks.postbuild.1.pattern=cmd.exe /c "c:\Program Files (x86)\teraterm\ttpmacro.exe" /v "c:\users\Frank\Documents\Arduino\Teensy Projects\TeensyOTADemo\Test2.ttl" "{vm.runtime.build.final_output_path}" {serial.port} {build.project_name}
When this is passed to tera term the arguments appear as follows:
BuildPath = param2 ; used to find the .HEX file to transfer, like "C:\Ussers\Frank\Arduino\Teensy Projects\TeensyOTADemo\Release\"
CommPortStr = param3 ;"COMx" where 'x' is the actual number assigned
ProjectFileName = param4 ;project file name like "TeensyOTADemo.ino"
Notes:
10/16/21: for verbose output, set VERBOSE = 1 (default is 0)
VERBOSE = 0; set this to 1 for verbose progress indications
pathtoHexfile = param2
COMportstr = param3
strtrim COMportstr ' ' ; remove any leading/trailing spaces
ComPortNumStr = COMportstr
strremove ComPortNumStr 1 3 ;isolate the com port number
INOfilename = param4
if VERBOSE then
sprintf2 msgstr "%s, %s, %s" param2 param3 param4;<param1> is ttl filename
messagebox msgstr 'script calling arguments'
sprintf2 msgstr "path to HEX file: %s" param2
sprintf2 msgstr "COM port number: %s" ComPortNumStr
sprintf2 msgstr "INO filename: %s" param4
endif
;connect to Teensy via COM <param2>
if VERBOSE then
sprintf2 msgstr "attempting to connnect to Teensy on COM%s" ComPortNumStr
messagebox msgstr 'info'
endif
sprintf2 cnct_str "/C=%s" ComPortNumStr ; actual string used by TT
if VERBOSE then
messagebox cnct_str 'connect string'
endif
testlink; TT could already be connected
; if result = 0 connect cnct_str; actually launch TT and make the connection. <result> = 2 for success
if result <> 2 then
sprintf2 errstr "unable to connect to Teensy on %s - aborting" COMportstr
messagebox errstr "Error"
goto ERROR ;error exit - closes COM connection and TT
;if we get to here, we have a valid COM port connection
if VERBOSE then
sprintf2 msgstr "sending trigger command (%s) and waiting for %s" "U" "waiting"
messagebox msgstr "info"
endif
send 'U' ;actually send the trigger character
timeout = 5 ; seconds
wait 'waiting'
if result = 0 then
messagebox "Oops - timed out waiting for 'waiting' from Teensy" "Error"
else ; OK, got 'waiting'...
if VERBOSE then
msgstr = "got 'waiting' string - sending file"
endif
hexfilestr = 'C:\Users\Frank\Documents\Arduino\Teensy Projects\TeensyOTADemo\Release\TeensyOTADemo.hex'
if VERBOSE then
messagebox hexfilestr 'sendfile'
endif
sendfile hexfilestr 0 ;actually send the file. Note the 0 is required to make it work
;now we have to extract the number of lines from the 'enter xxxx to flash...' string
wait 'enter' ;get the next line from Teensy
if result = 0 then
messagebox "Oops - timed out waiting for 'enter' from Teensy" "Error"
else ; OK, got 'enter'...
if VERBOSE then
msgstr = "got string containing 'enter'"
endif
recvln; this puts received line into 'inputstr'
if result = 1 then
; if VERBOSE then
; messagebox inputstr 'From Teensy'
; endif
;now extract number of lines from inputstr
strsplit inputstr ' ' ;puts numlines string into <groupmatchstr2>
strtrim groupmatchstr2 ' ';trim any leading/trailing spaces
if result <> 0 then
if VERBOSE then
sprintf2 msgstr '%s lines received' groupmatchstr2
messagebox msgstr 'From Teensy'
endif
;now send <groupmatchstr2> to Teensy to confirm update
if VERBOSE then
sprintf2 msgstr "sending '%s' to Teensy" groupmatchstr2
messagebox msgstr 'To Teensy'
endif
sendln groupmatchstr2; actually sends the <numlines> value
messagebox 'groupmatchstr2 send failed' 'error'
endif
messagebox "nothing received from Teensy" info
endif
endif
endif
endif
:ERROR
if VERBOSE then
messagebox "closing COM port and Tera Term" "info"
endif
testlink ;TT may or may not be connnected
if result <> 0 then
disconnect 1 ;closes the COM port connection
closett; closes teraterm
endif
end
;endif
;filenamebox 'File selection' 0
;if result<>0 then
; messagebox inputstr 'title' 0
; sendfile inputstr 1
;endif
Created: 10/9/2021 11:18:19 AM
Author: FRANKNEWXPS15\Frank
This program demonstrates the use of 'board.txt' post-build instructions in
conjunction with a small C# command-line program for seamless 'over-the-air' (OTA)
firmware update for Teensy modules.
Implementation of OTA update requires that Joe Pasquariello's 'FlasherX'
code be added to the Teensy sketch as it is below, and some code to allow
an external serial communications program to trigger the update process.
In the demo sketch below, the 'FlasherX' additions are the '#include FlasherTxx.h'
line and the addition of the FlasherX specific code at the bottom. The trigger
mechanism is provided by the 'CheckForUserInput();' call in loop. If the ASCII
code for 'U' or 'u' is present on Serial1, the update process will be launched.
#include "FlashTxx.h" // TLC/T3x/T4x flash primitives
#include <elapsedMillis.h>
elapsedMillis MsecSinceLastLEDToggle; //used for LED blink timer
Stream* FTDIport = &Serial1; // Serial (USB) or Serial1, Serial2, etc. (UART)
// hex_info_t struct for hex record and hex file info
typedef struct { //
char* data; // pointer to array allocated elsewhere
unsigned int addr; // address in intel hex record
unsigned int code; // intel hex record type (0=data, etc.)
unsigned int num; // number of data bytes in intel hex record
uint32_t base; // base address to be added to intel hex 16-bit addr
uint32_t min; // min address in hex file
uint32_t max; // max address in hex file
int eof; // set true on intel hex EOF (code = 1)
int lines; // number of hex records received
} hex_info_t;
void read_ascii_line(Stream* serial, char* line, int maxbytes);
int parse_hex_line(const char* theline, char* bytes,
unsigned int* addr, unsigned int* num, unsigned int* code);
int process_hex_record(hex_info_t* hex);
void update_firmware(Stream* serial, uint32_t buffer_addr, uint32_t buffer_size);
uint32_t buffer_addr, buffer_size; //09/20/21 copied from FlasherX - loop()
//Serial.begin(230400);
//while (!Serial) {} //10/06/21 infinite wait hangs pgm when USB cable removed - oops!
delay(2000); //10/06/21 - just use fixed delay instead
// Serial1.begin(115200);
Serial1.begin(230400);
while (!Serial1) {}
pinMode(LED_BUILTIN, OUTPUT);
MsecSinceLastLEDToggle = 0;
if (Serial1.available())
if (MsecSinceLastLEDToggle >= 200)
MsecSinceLastLEDToggle -= 200;
digitalWrite(LED_BUILTIN, !digitalRead(LED_BUILTIN));
void CheckForUserInput()
const int bufflen = 80;
char buff[bufflen];
memset(buff, 0, bufflen);
//const char s[2] = ",";
if (Serial1.available() > 0)
// read the incoming byte:
int incomingByte = Serial1.read();
// say what you got:
//Serial1.print("I received: ");
//Serial1.println(incomingByte, HEX); //chg to HEX 02/18/20
//02/18/20 experiment with multiple commands
switch (incomingByte)
case 0x55: //ASCII 'U'
case 0x75: //ASCII 'u'
Serial1.println(F("Start Program Update - Send new HEX file!"));
if (firmware_buffer_init(&buffer_addr, &buffer_size) == 0)
Serial1.printf("unable to create buffer\n");
Serial1.flush();
for (;;) {}
Serial1.printf("buffer = %1luK %s (%08lX - %08lX)\n",
buffer_size / 1024, IN_FLASH(buffer_addr) ? "FLASH" : "RAM",
buffer_addr, buffer_addr + buffer_size);
//09/20/21 clear the serial buffer
while (Serial1.available())
Serial1.read();
// receive hex file via serial, write new firmware to flash, clean up, reboot
update_firmware(&Serial1, buffer_addr, buffer_size); // no return if success
// return from update_firmware() means error or user abort, so clean up and
// reboot to ensure that static vars get boot-up initialized before retry
Serial1.printf("erase FLASH buffer / free RAM buffer...\n");
firmware_buffer_free(buffer_addr, buffer_size);
Serial1.flush();
REBOOT;
// update_firmware() read hex file and write new firmware to program flash
static char line[96]; // buffer for hex lines
static char data[32] __attribute__((aligned(8))); // buffer for hex data
hex_info_t hex = { // intel hex info struct
data, 0, 0, 0, // data,addr,num,code
0, 0xFFFFFFFF, 0, // base,min,max,
0, 0 // eof,lines
serial->printf("waiting for hex lines...\n");
// read and process intel hex lines until EOF or error
//DEBUG!!
//int line_num = 0;
//DEBUG!!
long int start_msec = 0;
bool bFirstTime = true;
while (!hex.eof) {
read_ascii_line(serial, line, sizeof(line));
if (bFirstTime)
start_msec = millis();
bFirstTime = false;
//DEBUG!!
//serial->printf("%d: %s\n", line_num, line);
//line_num++;
//DEBUG!!
//10/02/21 gfp added for visual xfer confirmation
if (hex.lines % 10 == 0)
digitalWriteFast(LED_BUILTIN, !digitalReadFast(LED_BUILTIN));
// reliability of transfer via USB is improved by this printf/flush
if (serial == (Stream*)&Serial)
serial->printf("%s\n", line);
serial->flush();
if (parse_hex_line((const char*)line, hex.data, &hex.addr, &hex.num, &hex.code) == 0) {
serial->printf("abort - bad hex line %s\n", line);
return;
else if (process_hex_record(&hex) != 0) { // error on bad hex code
serial->printf("abort - invalid hex code %d\n", hex.code);
return;
else if (hex.code == 0) { // if data record
uint32_t addr = buffer_addr + hex.base + hex.addr - FLASH_BASE_ADDR;
if (hex.max > (FLASH_BASE_ADDR + buffer_size)) {
serial->printf("abort - max address %08lX too large\n", hex.max);
return;
else if (!IN_FLASH(buffer_addr)) {
memcpy((void*)addr, (void*)hex.data, hex.num);
else if (IN_FLASH(buffer_addr)) {
int error = flash_write_block(addr, hex.data, hex.num);
if (error) {
serial->printf("abort - error %02X in flash_write_block()\n", error);
return;
hex.lines++;
//serial->printf("\nhex file: %1d lines %1lu bytes (%08lX - %08lX)\n",
// hex.lines, hex.max - hex.min, hex.min, hex.max);
serial->printf("\nhex file: %1d lines %1lu bytes (%08lX - %08lX), %lu Msec\n",
hex.lines, hex.max - hex.min, hex.min, hex.max, millis()-start_msec);
// check FSEC value in new code -- abort if incorrect
#if defined(KINETISK) || defined(KINETISL)
uint32_t value = *(uint32_t*)(0x40C + buffer_addr);
if (value == 0xfffff9de) {
serial->printf("new code contains correct FSEC value %08lX\n", value);
else {
serial->printf("abort - FSEC value %08lX should be FFFFF9DE\n", value);
return;
// check FLASH_ID in new code - abort if not found
if (check_flash_id(buffer_addr, hex.max - hex.min)) {
serial->printf("new code contains correct target ID %s\n", FLASH_ID);
else {
serial->printf("abort - new code missing string %s\n", FLASH_ID);
return;
// get user input to write to flash or abort
int user_lines = -1;
while (user_lines != hex.lines && user_lines != 0) {
serial->printf("enter %d to flash or 0 to abort\n", hex.lines);
sscanf(line, "%d", &user_lines);
if (user_lines == 0) {
serial->printf("abort - user entered 0 lines\n");
return;
// move new program from buffer to flash, free buffer, and reboot
//serial->printf("user entered %d lines\n", user_lines);
flash_move(FLASH_BASE_ADDR, buffer_addr, hex.max - hex.min);
// should not return from flash_move(), but put REBOOT here as reminder
REBOOT;
// read_ascii_line() read ascii characters until '\n', '\r', or max bytes
int c = 0, nchar = 0;
while (nchar < maxbytes && !(c == '\n' || c == '\r')) {
if (serial->available()) {
c = serial->read();
line[nchar++] = c;
line[nchar - 1] = 0; // null-terminate
// process_hex_record() process record and return okay (0) or error (1)
if (hex->code == 0) { // data -- update min/max address so far
if (hex->base + hex->addr + hex->num > hex->max)
hex->max = hex->base + hex->addr + hex->num;
if (hex->base + hex->addr < hex->min)
hex->min = hex->base + hex->addr;
else if (hex->code == 1) { // EOF (:flash command not received yet)
hex->eof = 1;
else if (hex->code == 2) { // extended segment address (top 16 of 24-bit addr)
hex->base = ((hex->data[0] << 8) | hex->data[1]) << 4;
else if (hex->code == 3) { // start segment address (80x86 real mode only)
return 1;
else if (hex->code == 4) { // extended linear address (top 16 of 32-bit addr)
hex->base = ((hex->data[0] << 8) | hex->data[1]) << 16;
else if (hex->code == 5) { // start linear address (32-bit big endian addr)
hex->base = (hex->data[0] << 24) | (hex->data[1] << 16)
| (hex->data[2] << 8) | (hex->data[3] << 0);
else {
return 1;
return 0;
// Intel Hex record foramt:
// Start code: one character, ASCII colon ':'.
// Byte count: two hex digits, number of bytes (hex digit pairs) in data field.
// Address: four hex digits
// Record type: two hex digits, 00 to 05, defining the meaning of the data field.
// Data: n bytes of data represented by 2n hex digits.
// Checksum: two hex digits, computed value used to verify record has no errors.
// Examples:
// :10 9D30 00 711F0000AD38000005390000F5460000 35
// :04 9D40 00 01480000 D6
// :00 0000 01 FF
/* Intel HEX read/write functions, Paul Stoffregen, paul@ece.orst.edu */
/* This code is in the public domain. Please retain my name and */
/* email address in distributed copies, and let me know about any bugs */
/* I, Paul Stoffregen, give no warranty, expressed or implied for */
/* this software and/or documentation provided, including, without */
/* limitation, warranty of merchantability and fitness for a */
/* particular purpose. */
// type modifications by Jon Zeeff
/* parses a line of intel hex code, stores the data in bytes[] */
/* and the beginning address in addr, and returns a 1 if the */
/* line was valid, or a 0 if an error occured. The variable */
/* num gets the number of bytes that were stored into bytes[] */
#include <stdio.h> // sscanf(), etc.
#include <string.h> // strlen(), etc.
unsigned sum, len, cksum;
const char* ptr;
int temp;
*num = 0;
if (theline[0] != ':')
return 0;
if (strlen(theline) < 11)
return 0;
ptr = theline + 1;
if (!sscanf(ptr, "%02x", &len))
return 0;
ptr += 2;
if (strlen(theline) < (11 + (len * 2)))
return 0;
if (!sscanf(ptr, "%04x", (unsigned int*)addr))
return 0;
ptr += 4;
/* Serial.printf("Line: length=%d Addr=%d\n", len, *addr); */
if (!sscanf(ptr, "%02x", code))
return 0;
ptr += 2;
sum = (len & 255) + ((*addr >> 8) & 255) + (*addr & 255) + (*code & 255);
while (*num != len)
if (!sscanf(ptr, "%02x", &temp))
return 0;
bytes[*num] = temp;
ptr += 2;
sum += bytes[*num] & 255;
(*num)++;
if (*num >= 256)
return 0;
if (!sscanf(ptr, "%02x", &cksum))
return 0;
if (((sum & 255) + (cksum & 255)) & 255)
return 0; /* checksum error */
return 1;
Frank
