Hi all,
I am trying to connect a small 128x64 OLED screen to my teensy - using I2C - I have connected as below:
GND to Teensy GND (pin before D0)
VCC to Teensy 3.3V (pin between D12 and D24)
SCL to Teensy pin 19
SDA to Teensy pin 18
The screen is working as expected, however I am experiencing a fair amount of noise from the audio out. I added a 2.2K resistor between VCC and teensy 3.3V so connection was:
VCC to 2.2K resistor to Teensy 3.3V (pin between D12 and D24)
and this removes the noise completely (also means the OLED is slightly dimmer - which is fine by me).
I just wanted to check adding a resistor is okay in this way (and not causing some unexpected damage anywhere?), and also to ask if anyone else and experienced this issue at all? The OLED screens I am using are these (again not sure if these are causing the issue?): https://www.amazon.co.uk/gp/product/B08QJ7BL3R/ref=ppx_yo_dt_b_asin_title_o04_s00?ie=UTF8&psc=1
Okay thanks very much!
David
David
