Results 1 to 4 of 4
Thread: ISR to map MIDI notes to output pins?
    Oct 2021
    2
    Hello, I am using the Teensy (LC) to illuminate LEDs based on the MIDI note-on received. I manually assigned 5 notes (e.g. 60, 61, 62, 63, 64) to 5 LEDs. It's working nicely; when I press one of the 5 assigned notes on my keyboard the correct/corresponding LEDs illuminate.
    Next, I want to create an ISR so that when a push-button is pressed, the program 'learns' the next 5 MIDI notes received (stores and maps them to outputs).
    High-level description of desired process and steps:
    a) push-button pressed;
    b) wait for 5 MIDI notes received, e.g.: 56, 57, 70, 79, 90; then
    c) map 56, 57, 70, 79, 90 to specified 5 outputs
    d) result - MIDI note-on messages 56, 57, 70, 79, 90 will trigger the LEDs.
    I have tried implementing a 'for' loop in an ISR to record the next 5 midi note-on messages in an array but I can't figure out how to 'wait' for 5 MIDI notes. (My loop terminates before 5 notes can be pressed and the array ends up being 5 of the same note.) I think this is because "you must call usbMIDI.read() regularly from loop() for usbMIDI to actually read incoming data and run the handler functions as messages arrive."
    I suspect I need to run usbMIDI.read() inside a loop inside my ISR but I cannot find direction on how to do so. Any help would be appreciated. Best regards.
    Feb 2020
    Dublin, Ireland
    58
    An interrupt service routine should only react to the single event that triggers it - it should never wait for another event. It should also run as quickly as possible.
    If you post your current code, someone may suggest a way to modify it to do what you want.
    May 2017
    123
    I even would not use an ISR for this. Teensy is fast enough for doing this within loop(). Use flags and timers to control.
    Jul 2020
    1,362
    This is a job for a state machine. Any multistage interaction with input or output would usually require
    a state machine to track state without locking out other features.
