Results 1 to 4 of 4
Thread: Is there something wrong with Audio rectify1
    May 2017
    248
    I am making a SDR radio, but this example shows the problem.
    Teensy 3.2 at 72mhz compiled faster. Not sure how to find my version of Teensyduino. I haven't downloaded recently.
    The idea is to listen to the undistorted audio path, but if you change one patchcord the audio is distorted. It is almost like the rectifiy object gets patched between the output of mixer1 and the input of the biquad1
    //#include <Wire.h>
    //#include <SPI.h>
    //#include <SD.h>
    //#include <SerialFlash.h>
    AudioSynthWaveformSine   sine1;          //xy=280.0000114440918,121.42857360839844
    AudioSynthWaveformDc     dc1;            //xy=280.0000305175781,218.5714168548584
    AudioMixer4              mixer1;         //xy=464.28570556640625,164.28571891784668
    AudioEffectRectifier     rectify1;       //xy=562.8571624755859,265.7142677307129
    AudioFilterBiquad        biquad1;        //xy=658.5713386535645,132.85714149475098
    AudioFilterBiquad        biquad2;        //xy=711.4284896850586,265.7142810821533
    AudioMixer4              mixer2;         //xy=854.2857208251953,174.28573036193848
    AudioOutputAnalog        dac1;           //xy=1005.7142791748047,174.28570461273193
    AudioConnection          patchCord1(sine1, 0, mixer1, 1);
    AudioConnection          patchCord2(dc1, 0, mixer1, 2);
    AudioConnection          patchCord3(mixer1, biquad1);
    AudioConnection          patchCord4(mixer1, rectify1);  // this connection sounds distorted
    //AudioConnection          patchCord4(biquad1, rectify1);   // this connection sounds ok
    AudioConnection          patchCord5(rectify1, biquad2);
    AudioConnection          patchCord6(biquad1, 0, mixer2, 0);
    AudioConnection          patchCord7(biquad2, 0, mixer2, 1);
    AudioConnection          patchCord8(mixer2, dac1);
      AudioNoInterrupts();
      AudioMemory(40);
      sine1.amplitude(0.25);
      sine1.frequency(600);
      dc1.amplitude(-0.1);
      mixer1.gain( 0, 0.0 );
      mixer1.gain( 1, 1.0 );
      mixer1.gain( 2, 1.0 );
      mixer1.gain( 3, 0.0 );
      biquad1.setLowpass( 0,3000,0.707);
      biquad2.setLowpass( 0,3000,0.707);
      mixer2.gain(0,0.5);      // listen to undistorted tone
      mixer2.gain(1,0.0);      // OR listen to rectified tone
      mixer2.gain(2,0.0);
      mixer2.gain(3,0.0);
      AudioInterrupts();
ID:	26251   Click image for larger version.
    May 2017
    248
    Looks like it updates a receive only buffer at least in the version of the library that I have.
    void AudioEffectRectifier::update(void)
    	audio_block_t *block = receiveReadOnly();
    	if (!block) return;
    	int16_t *p = block->data;
    	int16_t *end = block->data + AUDIO_BLOCK_SAMPLES;
    	while (p < end) {
    		int b = *p;
    		int t = *(p + 1);
    		if (b < 0) b = -b;
    		if (t < 0) t = -t;
    		b = signed_saturate_rshift(b, 16, 0);
    		t = signed_saturate_rshift(t, 16, 0);
    		*(uint32_t *)p = pack_16b_16b(t, b);
    		p += 2;
    	transmit(block);
    	release(block);
    1,768
    You must have an old version. TD 1.56 beta2 has
    	audio_block_t *block = receiveWritable();
    Pete
    P.S. It was found and fixed last year https://forum.pjrc.com/threads/64761
    May 2017
    248
    Thanks. I guess I should update my install. I was reluctant to because of some edits I made so I could use non-blocking I2C_t3 functions instead of Wire.
