Results 1 to 5 of 5
Thread: Issue playing .wav from SD while checking button bounce
    Oct 2021
    1
    So I've been hitting my head against a wall all night to get the most simplest thing to work: play an audio file from SD by the push of a button.
    I'm using a Teensy 4.0 With audio shield rev D and a simple pushbutton from ground to pin 19. Arduino IDE 1.8.16 and Teensyduino 1.55. A 2GB sandisk SD, but no idea of the quality and i dont suspect it being an SD card issue tbh.
    When I comment out all the audio parts the button function work fine to toggle the builtin led and when I comment out all the button bouncing parts the audio just loops fine. But together it really doesn't work. I think the audio stops the bounce2 library from checking the button, I have no idea how to get around this.
    #include <Bounce2.h>
    AudioPlaySdWav playSdWav1; //xy=351,481
    AudioMixer4 mixer1; //xy=577,567
    AudioAnalyzeRMS rms1; //xy=902,593
    AudioOutputI2S i2s2; //xy=920,485
    AudioConnection patchCord1(playSdWav1, 0, mixer1, 0);
    AudioConnection patchCord2(playSdWav1, 0, i2s2, 0);
    AudioConnection patchCord3(playSdWav1, 1, mixer1, 1);
    AudioConnection patchCord4(playSdWav1, 1, i2s2, 1);
    AudioConnection patchCord5(mixer1, rms1);
    AudioControlSGTL5000 sgtl5000_1; //xy=1006,788
    #define SDCARD_CS_PIN 10
    #define SDCARD_MOSI_PIN 11
    #define SDCARD_SCK_PIN 13
    #define BUTTON_PIN 19
    #define LED_PIN LED_BUILTIN
    Bounce2::Button button = Bounce2::Button();
    int ledState = LOW;
    sgtl5000_1.enable();
    sgtl5000_1.volume(0.8);
    AudioMemory(15);
    SPI.setMOSI(SDCARD_MOSI_PIN);
    SPI.setSCK(SDCARD_SCK_PIN);
    // stop here, but print a message repetitively
    while (1) {
    AudioInterrupts();
    button.attach( BUTTON_PIN, INPUT ); // USE EXTERNAL PULL-UP
    button.interval(5);
    button.setPressedState(LOW);
    // LED SETUP
    pinMode(LED_PIN,OUTPUT);
    digitalWrite(LED_PIN,ledState);
    button.update();
    if ( button.pressed() ) {
    Serial.println("pressed");
    playSdWav1.play("SOUND2.WAV");
    // delay(3000);
    // TOGGLE THE LED STATE :
    ledState = !ledState; // SET ledState TO THE OPPOSITE OF ledState
    digitalWrite(LED_PIN,ledState); // WRITE THE NEW ledState
    May 2017
    123
    try to increase debounce time from 5ms to maybe 20ms
    or use Intervalltimer for function button.update() every 2 ms
    I asume a timing problem
    Germany
    9,424
    PIN 19 is used for I2C which is needed for the Audio Shield.
    25,223
    You probably want to check button.fallingEdge(), so you only start playing the WAV file once when the button changes from not pressed to pressed.
    Germany
    9,424
    Not needed here - pressed() takes care of that. It returns true if the state changed.
    It's just the wrong pin.
