Results 1 to 3 of 3
Thread: Teensy 4.1 Low Power
    May 2021
    19
    I am trying to port some code that I had compiling under Arduino to the Teensey 4.1. The code used the Sleep library? Does the sleep library work under 4.1? I noticed that the github page for sleep (which was not updated for a while) does not specifically reference 4.1. I tried to compile one of its samples and that did not compile?
    I am just wondering the best way to sleep a Teensey and wake it up once in a while to take a picture , with some readings at minimal power (at worst)? At best, it can wake up on an interrupt or pin that changes state , and then do something.
    Thanks,
    Jeff
    Cheltenham, UK
    465
    I am afraid I think the Sleep Library is not supported any more.
    I have in the past asked questions and got zero response.
    May 2021
    19
    Ok, I suppose that's the tradeoff for having mind blowing speed and resources on the Teensey.
