hi all,
this is my first post. I got a teensy 4.1 which seems just great.
I got through the installation steps and i did a lot of reading (forum, samples, links,etc.) to get familiar with USB and MIDI.
Lucky the samples are small and simple.
The goal is simple : i want to have 8 virtual MIDI cables and use the 8 uarts to send/receive the data at the highest possible baud. Looking at the samples that seems to be doable.
But in Arduino i have the choice to select USB type 16x16 or 4x4. And some variants with serial.
There is no choice for 8x8.
Now if i understand correct, if i select 16x16 there are 16 virtual in and 16 virtual out cables created. These show up on MIDIOX just fine.
I do not need to use the host function to connected MIDI devices. I just need the virtual cables. But since my device will use 8 cables. I do not want to have 16.
So is there a way to remove the others? Where is the code that defines/creates these cables?
Or is it possible to add an entry for 8x8. and how ?
And i wonder why there is no simpler control over how many virtual cables are created and the combination of usb devices.
thanks for any help
mark
thanks for any help
mark
