bicycleguy
Combined manitou48 gpsgpt.ino
https://github.com/manitou48/teensy4/blob/master/gpsgpt.ino
and Pauls FrequencyCount
https://www.pjrc.com/teensy/td_libs_FreqCount.html
To make a GPS assisted counter. Works from 1MHz to 58MHz within +/- 1 ppm even though my T4.1 is ~27ppm.
Here's output of a 2.1234567 MHz signal from a ~.3ppm signal generator:
(I know the 3 places are nonsense)
I'm still months away, (if ever) from understanding the T4 timers, I/O ect. but have looked at FreqCount.h, IntervalTimer.h, cores and the manual and can't understand why I need the 6.25 (in red below) to make
this work. 6.25 is 150MHz/24MHz but can't figure where its changing it and why it doesn't mess up other stuff.
My ultimate goal is to combine the excellent NTP server:
https://forum.pjrc.com/threads/61581-Teensy-4-1-NTP-server?p=244574&viewfull=1#post244574
with some T4 relevant code to discipline a 10MHz OCXO all in one unit with a pretty display.
starting
1 secs 149996091 ticks -26.060 -26.060 ppm 43.8 C 2123512.500 Hz
2 secs 149996096 ticks -26.027 -26.043 ppm 43.8 C 2123450.000 Hz
3 secs 149996090 ticks -26.067 -26.051 ppm 43.8 C 2123450.000 Hz
4 secs 149996094 ticks -26.040 -26.048 ppm 43.8 C 2123456.250 Hz
5 secs 149996093 ticks -26.047 -26.048 ppm 43.8 C 2123456.250 Hz
6 secs 149996089 ticks -26.073 -26.052 ppm 43.8 C 2123456.250 Hz
7 secs 149996093 ticks -26.047 -26.051 ppm 44.4 C 2123456.250 Hz
8 secs 149996093 ticks -26.047 -26.051 ppm 43.8 C 2123456.250 Hz
...and some more after a few minutes of drifting
2365 secs 149996045 ticks -26.367 -26.234 ppm 45.7 C 2123456.250 Hz
2366 secs 149996047 ticks -26.353 -26.234 ppm 45.7 C 2123456.250 Hz
2367 secs 149996048 ticks -26.347 -26.234 ppm 45.1 C 2123456.250 Hz
2368 secs 149996047 ticks -26.353 -26.235 ppm 45.7 C 2123456.250 Hz
//gpsAssistedCounter.ino
//pin 35 to point per second(pps) of a GPS reciever
//pin 9 to signal generator
#include <FreqCount.h>
#define CLKSRC 1
#define TPS 150000000
#define PREDIV 0
volatile uint32_t tick, ticks;
void pinisr() {
tick = 1;
ticks = GPT1_CNT;
while (!Serial);
delay(3000);
Serial.println("starting");
CCM_CSCMR1 &= ~CCM_CSCMR1_PERCLK_CLK_SEL; // turn off 24mhz mode
CCM_CCGR1 |= CCM_CCGR1_GPT(CCM_CCGR_ON) ; // enable GPT1 module
GPT1_CR = 0;
GPT1_PR = PREDIV; // prescale+1 /1 for 32k, /24 for 24mhz /24 clock 1
GPT1_SR = 0x3F; // clear all prior status
GPT1_CR = GPT_CR_EN | GPT_CR_CLKSRC(CLKSRC) | GPT_CR_FRR ;// 1 ipg 24mhz 4 32khz
attachInterrupt(35, pinisr, RISING); //35 for GPS pps, 22 for sg
FreqCount.begin(1000000); //Time in microseconds
static uint32_t n = 1, prev = 0;
static float sum = 0;
static unsigned long count=0;
if (FreqCount.available()){
count = FreqCount.read();
//Serial.println(count*.99997305);
if (tick) {
if (prev != 0) {
int d = ticks - prev;
float e = (float)(d - TPS) / TPS;
float ppm = 1000000. * e;
sum += ppm;
Serial.printf("%d secs %d ticks %.3f %.3f ppm %.1f C %.3f Hz\n", n, d, ppm, sum / n, tempmonGetTemp(), (float)count*[COLOR="#FF0000"]6.25[/COLOR]);//*1000000.0/(1000000.0-ppm)
n++;
FreqCount.begin(1000000.0/(1.0-e));
tick = 0;
prev = ticks;
