Results 1 to 12 of 12
Thread: Next new Teensy , USB-C Please.
    My only gripe with my Teensy 4.1 board. Is no USB-C connector.
    I am so over micro USB connectors.
    I know this will change costs to most likely higher but I myself would love having USB-C style connector. Not like these things are $5000 each.
    I feel like these micro usb ports are always on the brink of falling apart.
    Doing A project where I need to run it out to the garage and back so having to plug and unplug a lot.
    I feel my 4 day old Teensy 4.1 usb port is already loose inside, ala near ruined.
    I don't SEE any wiggle to the port itself.
    But if I tap it, or breath to hard it looses connection
    And yes, swapped out cables.
    and NO, I don't yank the cable out like A gorilla.
    Senior Member blackketter's Avatar
    May 2015
    San Francisco
    352
    +1 for USB-C. It's time.
    Quote Originally Posted by blackketter View Post
    Good to know I am not the only one
    My 2nd Teensy 4.1 that should show up tomorrow, I am gonna epoxy the port to help brace it some.
    Apr 2017
    834
    Some extra solder on the thru hole part of the connector helps as well and is likely more than enough, at least for me it was after breaking one before.
    15,543
    Not had any problems here with repeat plug unplug, especially the newer versions that have through hole feet that will be better secured to PCB.
    Quote Originally Posted by vjmuzik View Post
    +1 to that - have noticed the solder connect may be complete - but not full into the hole. Though I've not added solder fill to any.
    USB-C nice not having an UP - and not having that inner connect 'flap' - but I've only broken one of those on another $30 device that was wasted. And USB-C is a deeper connector taking more PCB space. And can provide much more power.
    I'd gladly take an extra 1/4" longer board for USB C plug on it.
    The firmer, nicer plug just so much more desired. Only plus on big Arduinos is having the big USB B plug. Never hurt one of those since 1996
    I think can get away with USB-C style plug, without being USB 3.0 driven?
    Apr 2017
    834
    Quote Originally Posted by jdredd View Post
    They make ones specifically for power only or USB 2.0 only so it’s not a requirement. All it takes is 2 resistors for basic usage so nothing overly complicated.
    10,025
    I sort of like the type plugs as well...
    But there are always tradeoffs... Like 1/4" longer, or wider or... Well it may not fit into the previous boards I have done. Which may or may not be an issue for you.
    Now for totally different new board, that may not be an issue. But if the goal is to be able to drop in new one into places that use the old ones ...
    Then there is how much else on the board needs to or should be updated because of the plug. Like:
    I think USB-c can go higher voltages... probably don't want this here.
    More current, does that imply the fuse needs to change, plus should the VRs change, what about USBHost. Do you still need the Protection chip? or different one for higher currents. Or not at all like Sparkfun Micromod...
    Note: I don't think I have busted any of these boards in awhile. Did have some older T3.5/6 where the inside contacts had issues...
    But to avoid that I keep a neat tidy area: :P
    But the biggest thing is that I avoid unplugging them all of the time, instead I use powered hub with buttons per USB port, that I can turn on and off as needed
    Germany
    1,707
    I also would prefer USB-C. Especially since good USB cables for the 480MBit T4.x boards tend to be quite stiff.
    While waiting I use this:
ID:	26470Click image for larger version.
    https://github.com/luni64/USB-C---MicroB
    BTW: These days even much smaller boards use USB-C:
    Right now I have A small MicroUSB to USB C adapter plugged in. PLUS, A USB extension cable with a nice on/off switch.
    Working out pretty well.
    Dec 2021
    5
    USB-C connector that is through hole, so it can take some abuse with twisted wires and not pull off.
    Nov 2020
    3
    USB-C would be great, i really need one.
    is there a chance to solder an suitable USB-C?
