desgeneradotv
New member
Hi there friends.
Im into a project which was using teensy 3.5 or 3.6 and i moved to 4.1
i was using mostly 45 pins on the 3.5. however when i switched to 4.1 there was not enought pins on the board for my project . then i found that i could use the MicroSD contacts as gpio pins and i came to solder some wires to it and it worked just fine except for the 46 and 47 pins. which im not really in need to use but after testing it just didnt work for me.
anyway im moving ahead now to PCB design to gather all the components into a single board and im concerned if would it be possible to make a custom request for 1000 units to PJRC that provide thru hole pins 42 to 47 and inbetween used as the MicroSD port instead that microsd that im not gonna use. so that i can place pin headers and solder the teensy board to my pcb design instead of having to solder kind of a wires bus and bring it to the pcb like im doing now?
sort of a custom board but all i need is easy access to those pins
