I'm trying to make an infinity cube with a teensy 3.2 and a ws2812 string. If I use a mega I can light each pixel of the string, using fastLED. I am only able to get the first pixel to light with what I've done with the teensy3.2
The sketch I'm using on the teensy is:
#include <WS2812Serial.h>
const int numled = 105;
const int colorStep = 65536/numled; //several loops would benefit from this constant
const int led_pin = 10; //Pin to connect LED ring data in
byte drawingMemory[numled*3]; // 3 bytes per LED
DMAMEM byte displayMemory[numled*12]; // 12 bytes per LED
WS2812Serial ring(numled, displayMemory, drawingMemory, led_pin, WS2812_RGB);
ring.begin();
ring.show(); // Initialize all pixels to 'off'
ring.setBrightness(84);
delay(3000);
pinMode(13,OUTPUT);
static uint32_t c,color = 0x0f0f00;
// First slide the led in one direction
for(int i = 0; i < numled; i++) {
// digitalWrite(13,LOW);
// Set the i'th led to red
ring.setPixelColor(c, 0xff0000 );
ring.show();
Serial.println(i);
// Show the leds
delay(200);
digitalWrite(13,HIGH);
delay(200);
// now that we've shown the leds, reset the i'th led to black
ring.setPixelColor(c, 0 );
for what it's worth the Mega code is:
#include "FastLED.h"
// How many leds in your strip?
#define NUM_LEDS 105
// For led chips like Neopixels, which have a data line, ground, and power, you just
// need to define DATA_PIN. For led chipsets that are SPI based (four wires - data, clock,
// ground, and power), like the LPD8806, define both DATA_PIN and CLOCK_PIN
#define DATA_PIN 6
#define CLOCK_PIN 13
// Define the array of leds
CRGB leds[NUM_LEDS];
Serial.begin(57600);
Serial.println("resetting");
LEDS.addLeds<WS2812,DATA_PIN,RGB>(leds,NUM_LEDS);
LEDS.setBrightness(84);
void fadeall() { for(int i = 0; i < NUM_LEDS; i++) { leds[i].nscale8(250); } }
static uint8_t hue = 0;
//Serial.print("x");
leds[i] = CHSV(hue++, 255, 255);
// Show the leds
FastLED.show();
leds[i] = CRGB::Black;
I presume my issue is electrical rather than software. The IC is a SN54AHCT125. On the mega I did not use a capacitor or resistor, just plugged into D6 and 5V and GND directly on the board.
