BriComp
DISREGARD FOR TIME BEING.
The code below does not work reliably with USB Serial.
It intermittently prints out nothing.
This shows the use of the Snooze USB
Serial driver when using sleep. The USB
Serial driver does not wake the processor
it only aids in using the USB Serial in
sleeping appilcations.
Supported Micros: T-LC/3.x/4.0
#include <Snooze.h>
// Load drivers
// Always use SnoozeUSBSerial with T4.0.
// SnoozeUSBSerial driver does what Serial does like "print", -
// "println", "prinf", etc and also handles the effects of using -
// the Arduino Serial monitor and sleeping. Use it when you -
// want to print to serial monitor for sleeping applications.
SnoozeUSBSerial usb;
SnoozeTimer timer;
#if defined(__MKL26Z64__)
// configures the lc's 5v data buffer (OUTPUT, LOW) for low power
Snoozelc5vBuffer lc5vBuffer;
Install drivers, timer to wake and USB Serial to fix
printing to serial monitor after sleeping.
#if defined(__IMXRT1062__)
SnoozeBlock config_teensy40(usb, timer);
#elif defined(__MK66FX1M0__)
SnoozeBlock config_teensy36(usb, timer);
#elif defined(__MK64FX512__)
SnoozeBlock config_teensy35(usb, timer);
#elif defined(__MK20DX256__)
SnoozeBlock config_teensy32(usb, timer);
#elif defined(__MKL26Z64__)
SnoozeBlock config_teensyLC(usb, lc5vBuffer, timer);
int idx;
pinMode(LED_BUILTIN, OUTPUT);
// USBSerial does what Serial and handles usb -
// when sleeping.
while (!usb);
usb.println("Starting...");
Set Low Power Timer wake up in Seconds(T4) or milliseconds
all other Teensy's.
timer.setTimer(5);// seconds
#else
timer.setTimer(5000);// milliseconds
idx = 0;
int who = 0;
feed the sleep function its wakeup parameters. Then go
to sleep.
who = Snooze.sleep( config_teensy40 );// return module that woke processor
who = Snooze.sleep( config_teensy36 );// return module that woke processor
who = Snooze.sleep( config_teensy35 );// return module that woke processor
who = Snooze.sleep( config_teensy32 );// return module that woke processor
who = Snooze.sleep( config_teensyLC );// return module that woke processor
// wait for serial monitor
elapsedMillis time = 0;
while (!usb && time < 1000) {
#if !defined(__IMXRT1062__)
// print out a bunch of NULLS to serial monitor
// T3.x/LC only
usb.write(0x00);
digitalWriteFast(LED_BUILTIN, HIGH);
delay(20);
digitalWriteFast(LED_BUILTIN, LOW);
delay(20);
delay(200); // normal delay for Arduino Serial Monitor
usb.printf("Timer Driver number indicator: %i | index: %i\n", who, idx); // print who woke up, i.e. timer
idx++;
