urbanvisuals
New member
I'm getting this following error when trying to compile for any Teensy board I select.
The last two lines show up in red. I've checked out the tools directory, and it looks like the permissions are just like everywhere else. A google search let me know that fork/exec should point at a file and not a directory, but I'm not sure if that's the case here.
I've tried my desired sketch, and the blink example, and it won't compile, but if I select Arduino Uno as board type it will compile. It won't compile for any teensy board i select. (I've also tried the 1.56b2 download, and I get the same error.) I'm on Catalina 10.15.7.
Here's the error:
/Applications/Teensyduino.app/Contents/Java/arduino-builder -dump-prefs -logger=machine -hardware /Applications/Teensyduino.app/Contents/Java/hardware -hardware /Users/nathan/Library/Arduino15/packages -hardware /Users/nathan/Documents/Arduino/hardware -tools /Applications/Teensyduino.app/Contents/Java/tools-builder -tools /Applications/Teensyduino.app/Contents/Java/hardware/tools/avr -tools /Users/nathan/Library/Arduino15/packages -built-in-libraries /Applications/Teensyduino.app/Contents/Java/libraries -libraries /Users/nathan/Documents/Arduino/libraries -fqbn=teensy:avr:teensy31:usb=serial,speed=96,opt=o2std,keys=en-us -ide-version=10816 -build-path /var/folders/zq/th1x6d2d6pl_xtqtjmj1y_000000gn/T/arduino_build_175386 -warnings=none -build-cache /var/folders/zq/th1x6d2d6pl_xtqtjmj1y_000000gn/T/arduino_cache_838545 -verbose /Applications/Teensyduino.app/Contents/Java/examples/01.Basics/Blink/Blink.ino
/Applications/Teensyduino.app/Contents/Java/arduino-builder -compile -logger=machine -hardware /Applications/Teensyduino.app/Contents/Java/hardware -hardware /Users/nathan/Library/Arduino15/packages -hardware /Users/nathan/Documents/Arduino/hardware -tools /Applications/Teensyduino.app/Contents/Java/tools-builder -tools /Applications/Teensyduino.app/Contents/Java/hardware/tools/avr -tools /Users/nathan/Library/Arduino15/packages -built-in-libraries /Applications/Teensyduino.app/Contents/Java/libraries -libraries /Users/nathan/Documents/Arduino/libraries -fqbn=teensy:avr:teensy31:usb=serial,speed=96,opt=o2std,keys=en-us -ide-version=10816 -build-path /var/folders/zq/th1x6d2d6pl_xtqtjmj1y_000000gn/T/arduino_build_175386 -warnings=none -build-cache /var/folders/zq/th1x6d2d6pl_xtqtjmj1y_000000gn/T/arduino_cache_838545 -verbose /Applications/Teensyduino.app/Contents/Java/examples/01.Basics/Blink/Blink.ino
Using board 'teensy31' from platform in folder: /Applications/Teensyduino.app/Contents/Java/hardware/teensy/avr
Using core 'teensy3' from platform in folder: /Applications/Teensyduino.app/Contents/Java/hardware/teensy/avr
Detecting libraries used...
/Applications/Teensyduino.app/Contents/Java/hardware/teensy/../tools/ -w -x c++ -E -CC -DF_CPU= -DARDUINO=10816 -DARDUINO_TEENSY32 -DARDUINO_ARCH_AVR -I/Applications/Teensyduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3 /var/folders/zq/th1x6d2d6pl_xtqtjmj1y_000000gn/T/arduino_build_175386/sketch/Blink.ino.cpp -o /dev/null
fork/exec /Applications/Teensyduino.app/Contents/Java/hardware/teensy/../tools/: permission denied
Error compiling for board Teensy 3.2 / 3.1.
Thanks,
Here's the error:
Thanks,
