13:00:59.072 (post_compile 1): Begin, version=1.53, high-res time
13:00:59.210 (loader): Teensy Loader 1.53, begin program
13:00:59.265 (loader): File "Blinkxxx1.ino.hex". 8412 bytes, 3% used
13:00:59.277 (loader): Listening for remote control on port 3149
13:00:59.277 (loader): initialized, showing main window
13:00:59.386 (loader): remote connection 1356 opened
13:00:59.386 (loader): remote cmd from 1356: "comment: Teensyduino 1.53 - WINDOWS (teensy_post_compile)"
13:00:59.386 (post_compile 1): Sending command: comment: Teensyduino 1.53 - WINDOWS (teensy_post_compile)
13:00:59.387 (loader): remote cmd from 1356: "status"
13:00:59.389 (loader): HID/win32: vid:413C pid:2113 ver:3308
13:00:59.390 (loader): HID/win32: vid:413C pid:2113 ver:3308
13:00:59.391 (loader): remote cmd from 1356: "dir:C:\Users\abc\AppData\Local\Temp\arduino_build_370782\"
13:00:59.391 (loader): remote cmd from 1356: "file:Blinkxxx1.ino.hex"
13:00:59.392 (post_compile 1): Status: 1, 0, 0, 0, 0, 0, C:\Users\abc\AppData\Local\Temp\arduino_build_370782\, Blinkxxx1.ino.hex
13:00:59.392 (post_compile 1): Sending command: dir:C:\Users\abc\AppData\Local\Temp\arduino_build_370782\
13:00:59.392 (post_compile 1): Sending command: file:Blinkxxx1.ino.hex
13:00:59.398 (loader): File "Blinkxxx1.ino.hex". 8412 bytes, 3% used
13:00:59.405 (loader): remote cmd from 1356: "status"
13:00:59.406 (loader): remote cmd from 1356: "auto
n"
13:00:59.407 (post_compile 1): Status: 1, 0, 0, 0, 0, 0, C:\Users\abc\AppData\Local\Temp\arduino_build_370782\, Blinkxxx1.ino.hex
13:00:59.407 (post_compile 1): Sending command: auto
n
13:00:59.408 (post_compile 1): Disconnect
13:00:59.422 (loader): remote connection 1356 closed
13:00:59.477 (post_compile 2): Begin, version=1.53, high-res time
13:00:59.542 (loader): remote connection 1360 opened
13:00:59.542 (loader): remote cmd from 1360: "comment: Teensyduino 1.53 - WINDOWS (teensy_post_compile)"
13:00:59.542 (loader): remote cmd from 1360: "status"
13:00:59.542 (loader): remote cmd from 1360: "dir:C:\Users\abc\AppData\Local\Temp\arduino_build_370782\"
13:00:59.542 (loader): remote cmd from 1360: "file:Blinkxxx1.ino.hex"
13:00:59.542 (loader): File "Blinkxxx1.ino.hex". 8412 bytes, 3% used
13:00:59.547 (post_compile 2): Sending command: comment: Teensyduino 1.53 - WINDOWS (teensy_post_compile)
13:00:59.549 (post_compile 2): Status: 1, 1, 0, 0, 0, 0, C:\Users\abc\AppData\Local\Temp\arduino_build_370782\, Blinkxxx1.ino.hex
13:00:59.549 (post_compile 2): Sending command: dir:C:\Users\abc\AppData\Local\Temp\arduino_build_370782\
13:00:59.549 (post_compile 2): Sending command: file:Blinkxxx1.ino.hex
13:00:59.558 (loader): remote cmd from 1360: "status"
13:00:59.564 (post_compile 2): Status: 1, 1, 0, 0, 0, 0, C:\Users\abc\AppData\Local\Temp\arduino_build_370782\, Blinkxxx1.ino.hex
13:00:59.564 (post_compile 2): Disconnect
13:00:59.589 (loader): remote connection 1360 closed
13:00:59.589 (loader): remote connection 1360 opened
13:00:59.589 (post_compile 3): Running teensy_reboot: "D:\MyProgramFiles\Arduino1813T153\arduino-1.8.13-windows\arduino-1.8.13\hardware\teensy\..\tools\teensy_reboot.exe" teensy_reboot.exe "-board=TEENSY32" "-port=usb:0/140000/0/6" "-portlabel=hid#vid_16c0&pid_0478 Bootloader" "-portprotocol=Teensy"
13:00:59.643 (reboot 4): Begin, version=1.53, high-res time
13:00:59.643 (reboot 4): location = usb:0/140000/0/6
13:00:59.643 (reboot 4): portlabel = hid#vid_16c0&pid_0478 Bootloader
13:00:59.643 (reboot 4): Only location usb:0/140000/0/6 will be tried
13:00:59.643 (reboot 4): portprotocol = Teensy
13:00:59.643 (reboot 4): LoadLibrary cfgmgr32 ok
13:00:59.643 (reboot 4): LoadLibrary ntdll ok
13:00:59.645 (reboot 4): nothing new, skipping HID & Ports enum
13:00:59.651 (loader): remote connection 1364 opened
13:00:59.653 (reboot 4): Disconnect
13:00:59.667 (loader): remote connection 1364 closed
13:00:59.667 (loader): remote connection 1360 closed
13:01:05.322 (loader): Verbose Info event
This is what is at bottom or Arduino IDE Screen.........................
Opening Teensy Loader...
Sketch uses 8408 bytes (3%) of program storage space. Maximum is 262144 bytes.
Global variables use 3120 bytes (4%) of dynamic memory, leaving 62416 bytes for local variables. Maximum is 65536 bytes.
D:\MyProgramFiles\Arduino1813T153\arduino-1.8.13-windows\arduino-1.8.13\hardware\teensy/../tools/teensy_post_compile -file=Blinkxxx1.ino -path=C:\Users\abc\AppData\Local\Temp\arduino_build_910137 -tools=D:\MyProgramFiles\Arduino1813T153\arduino-1.8.13-windows\arduino-1.8.13\hardware\teensy/../tools -board=TEENSY32 -reboot -port=usb:0/140000/0/6 -portlabel=hid#vid_16c0&pid_0478 Bootloader -portprotocol=Teensy
No Teensy boards were found on any USB ports of your computer.
