Results 1 to 9 of 9
Thread: 24 Keys Matrix
    Nov 2021
    5
    24 Keys Matrix
    I wrote this code to scan 24 keys matrix, it's work great with Arduino Uno but on teensy 3.2 and 3.6 I got something like "double pulsing".
    when I press on the 7th' key I got 6 and 7 reading , allmost same when I pressed the 16th' key then I got 14 and 16 reading.
    all the rest of the keys works fine.
    thanks for help ,
    the code :
    int pressedKey[25]={0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0};
    int k1_row[6]={1,2,3,4,5,6};
    int k1_col[4]={7,8,9,10};
      for(int i=0;i<=5;i++){
       pinMode(k1_row[i],OUTPUT);
      for(int i=0;i<=3;i++){
        pinMode(k1_col[i],INPUT_PULLUP);
      Serial.println("SETUP DONE");
          for(int i=0; i<=5; i++){
               digitalWriteFast(k1_row[0],HIGH);
               digitalWriteFast(k1_row[1],HIGH);
               digitalWriteFast(k1_row[2],HIGH);
               digitalWriteFast(k1_row[3],HIGH);
               digitalWriteFast(k1_row[4],HIGH);
               digitalWriteFast(k1_row[5],HIGH);
               digitalWriteFast(k1_row[i],LOW);
              for(int j=0; j<=3; j++){
                int strokedKey=i*4+j+1;
                bool col_scan=digitalRead(k1_col[j]);
                    if(col_scan==LOW){
                        if (pressedKey[strokedKey]==0 ){
                                //playMusic(strokedKey);
                                pressedKey[strokedKey]=1 ;
                                Serial.println(strokedKey);
                       delay(10);
                    pressedKey[strokedKey]=0;
                   delay(10);
    May 2017
    255
    Thinking about the differences between a UNO and a Teensy:
    The Teensy is faster and will fail when the program needs more time between steps. I think that is probably the issue and would suggest an added delay.
    Add a delay here to allow the row signals to stabilize before reading the columns.
    The UNO has 5 volt logic and the Teensy has 3 volt logic. The UNO has more margin for error in determining if the signal is high or low. You have your signals going through a long cable and that can cause issues. Short wires are best for speed.
    You are using the internal pullups and they may be different between a UNO and the Teensy. Generally internal pullups are high resistance and the signals will respond slower than if you used external pullups.
    Nov 2021
    5
    Hi Rcarr, thanks for the well-detailed answer.
    I do some extra tests and set the matrix with short wires and it worked well.
    so it's probably a wire length issue. I am trying to figure out if the solution is on the output side mean the matrix lines or maybe on the inputs pins used by the matrix Cullums.
    Practically I see two options :
    1. shift the logic level to 5V and raise the pulldown resistor
    2. stay with the pull-up system using external resistors and looking for the right value
    Nov 2021
    5
    last update :
    A 5.1k external pull-up resistor had solved the problem
    thanks for you're help.
    9,990
    Quote Originally Posted by yinon View Post
    last update :
    Hopefully at least for the T3.6 you are using a PU that uses 3.3v as the T3.6 pins are not tolerant of 5v being applied to them.
    Senior Member houtson's Avatar
    Aug 2015
    Scotland
    212
    also, the keypad library is very effective if you are looking for a ready baked solution
    Nov 2021
    5
    yes, of course.
    I am still dealing with the same issue. the external Pullup don't solve the problem ):
    New York
    7,858
    You may want to check this post out:
    https://forum.pjrc.com/threads/62087...ght=key+matrix
    sounds like a similar problem. Solution may help.
    9,990
    Like @houtson mentioned, you might try the keypad library solution.
    A long time ago I wrote my own code for a 20 button matrix... which does something similar to what you mentioned.
    But there were discussions somewhere (not sure here or Trossen or ...) about concern if multiple buttons were pressed, could I could I short two pins. One digitalWrite HIGH connected to another one digtialWrite LOW...
    So changed my digitalWrite(pin, HIGH), to pinMode(pin, INPUT_PULLUP)...
    I doubt that would help here...
    If it were me, I would try a quick and dirty debounce sort of logic... like:
        if(col_scan==LOW){
            delay(5); // experiment on how long
            if (col_scan==(LOW) {
                // only if still low process it...
    And see if that removes the issues.
