Results 1 to 7 of 7
Thread: 5V clock speed vs 3.3V clock speed
    Jul 2021
    5
    For a Teensy 4.0, is the maximum clock speed (600MHz) reached at 3.3V or 5V?
    When I read about clock speed in the "Power" section of the Teensy description, it says "Teensy 4.0 has a voltage regulator which reduces the 5V VUSB / VIN power to 3.3V for use by the main processor and most other parts." (https://www.pjrc.com/store/teensy40.html#power) This makes me think that there isn't a need to run more than 3.3V to the board. However, when I read about powering the Teensy from a battery, I read that the maximum clock speed drops when running under 4.5V: https://www.pjrc.com/teensy/external_power.html The table listed in the "External Power" section only lists a max clock speed of 16MHz, so I'm guessing it is old info for the 1.0 or 2.0.
    Thanks!
    15,527
    Indeed that page is for the older AVR Teensy units.
    Jul 2020
    1,458
    The board as is requires 5V power, it cannot accept power on the 3.3V pin without modification: https://forum.pjrc.com/threads/64468...l=1#post259469
    15,527
    Good link @MarkT - didn't have time to note that and find that ref.
    Jul 2021
    5
    I saw this and considered doing it; I just wasn't sure if my 4.0's clock speed would suffer for it like the older ones do.
    Jul 2020
    1,458
    No, the processor is 3.3V however you power/modify the board.
    Germany
    9,626
    The cpu internally works with a even less voltage - it's adjustable, and the teesy core automatically adjusts it with the CPU speed.
