diode no longer in audio design tool
Import Vocoder19Bands and see what happens. Rectifier is allowed by the compiler, but the asset is no longer in the gui. You can't select it and if a Rectifier is in the ini list it will get ignored.
Tried it just now. Opened File > Examples > Audio > Effects > Vocoder19Band. Then copied all the audio instances and connections to clipboard. Clicked Import in the design tool and pasted.
Here's the result I see. The "Rect1" and other rectifier objects seem to import fine and are clickable.
Check the URL you're using for the design tool. Any chance you're accessing an old copy? Or a local copy?
(some old copies are on the server... I should probably delete them)
