Results 1 to 5 of 5
Thread: Using PWM and DAC in the same sketch
    Nov 2021
    3
    I am trying to use a PWM output and DAC in the same sketch. When I run my code, pin A22 outputs a PWM signal instead of the desired DAC output. I am using the Teensy 3.6.
    #include <ADC.h>
    #include <ADC_util.h>
    const int readPin = A12; // adc1 or ADC1
    const int dacPin = A22;
    ADC *adc = new ADC(); // adc object
    volatile uint32_t value = 0;
    double d_value = 0.0;
    int is_set = 0;
    double err[4];
    double mod[3];
    double Vin = 0;
    double vset = 2.0;
    double Gpwm = 1.2500;
    double kfb = 0.1600;
    double cn[4] = {1.0965, -1.0583, -1.0961, 1.0586};
    double cd[4] = {1.0000, -2.4776, 2.0235, -0.5458};
    pinMode(LED_BUILTIN, OUTPUT);
    analogWriteResolution(10);
    analogWriteFrequency(2, 100000);
    pinMode(readPin, INPUT_PULLUP);
    adc->adc1->setAveraging(4); // set number of averages
    adc->adc1->setResolution(12); // set bits of resolution
    adc->adc1->setConversionSpeed(ADC_CONVERSION_SPEED::MED_SPEE D); // change the conversion speed
    adc->adc1->setSamplingSpeed(ADC_SAMPLING_SPEED::VERY_HIGH_SP EED);
    adc->adc1->enableInterrupts(adc1_isr);
    adc->adc1->wait_for_cal();
    adc->adc1->startContinuous(readPin);
    void adc1_isr(void) {
    err[3] = err[2];
    err[2] = err[1];
    err[1] = err[0];
    value = (uint16_t)adc->adc1->analogReadContinuous();
    double d_value = 5.0 * value / 4096.0;
    err[0] = vset * kfb - d_value * kfb;
    double uterms = cn[0] * err[0] + cn[1] * err[1] + cn[2] * err[2] + cn[3] * err[3];
    double yterms = cd[1] * mod[0] + cd[2] * mod[1] + cd[3] * mod[2];
    mod[2] = mod[1];
    mod[1] = mod[0];
    mod[0] = uterms - yterms;
    uint16_t w_value = round(mod[0] * Gpwm * 1024);
    analogWrite(2, w_value);
    analogWrite(dacPin, w_value);
    25,491
    Which Teensy model are you using?
    Nov 2021
    3
    Teensy 3.6, sorry for not including that.
    2,670
    your sketch didn't compile -- spaces in "MED_SPEE D" and "VERY_HIGH_SP EED"
    that ISR is firing every 11 us -- not sure what settle time is for DAC ... You might print out w_delay (with delay(1000)) in loop()) and confirm number is in range 0-1023
    if i just use a constant analogWrite(dacPin,512) I see a nice 1.64 v with scope on A22, so DAC seems to be working in "analog" mode
    i have no way to reproduce what your hardware is providing in the ADC read's on A14. if i pull A14 to GND, w_value is 2870. If i pull A14 to 3v3, w_value is 61233
    if i toggle dacPin analogwrite between 0 and 512 each time through the isr, i have a nice 45khz square wave on A22 (with scope).
    Nov 2021
    3
    I found the problem in my algorithm, the DAC now works as expected. Thank you for your help.
