Results 1 to 21 of 21
Thread: LED Matrix missing Code
    Junior Member plumped's Avatar
    Nov 2021
    Switzerland
    17
    Good evening all!
    I have been working in C for a while now to get my LED matrix up and running by christmas. Nevertheless the board doesn't want to show me a bmp file anymore. Did I forget something in the code?
    @Mortemkopf was already a huge help for me with the basics and his older code "OctobmpPOVfromSD".
    https://codeshare.io/zy7DP7
    I would be infinitely grateful if someone could contribute the final tip so that I can finally pack the thing
    BR & Have a good one
    Senior Member PaulS's Avatar
    Apr 2015
    Netherlands
    732
    Probably obvious, but did you open the Arduino serial monitor?
      while (!Serial) {
        yield();
    Paul
    Nov 2021
    Switzerland
    17
      while (!Serial) {
        yield();
    Paul
    Yes i did :-) used it for SD debug
    25,508
    First, try running File > Examples > SD > listfiles, just to check that your SD card really is working and has the BMP file. Not much point digging into the details if the problem is as "simple" as the SD card not detected or not having the file.
    Then, a few questions. Which Teensy are you using? Which version of Arduino & Teensyduino do you have installed? (click Help > About to check) Can you share the BMP file, so I or anyone else here could try to reproduce the problem?
    Nov 2021
    Switzerland
    17
    Hi Paul and thank you for your feedback.
    "listfiles" is running as expected with no failures.
Name:	Screenshot 2021-12-01 233018.jpg
    Im using Teensy 4.1 with Arduino 1.8.13 & Teensyduino 1.55
    As files I use for example this kind of files: 2.bmp1.bmp0.bmp
    Of course with the correct naming while using in the code
    Senior Member mortonkopf's Avatar
    Apr 2013
    London, uk
    959
    Hi, I don't recognise chunks of the code you posted. Do you get the serial monitor print statements from the drawbmp functions. Also, I can't see anywhere where the programme sets the leds, whether its leds.show() or whatever. Perhaps i missed it. So, SD can be read, so that can be discounted, leds can be display a general pattern or show that they can be lit?
    Nov 2021
    Switzerland
    17
    Quote Originally Posted by mortonkopf View Post
    Hi Morton
    I am still completely new to the field :-) I do not quite understand what you mean. The one with the leds.show() makes sense to me. that was missing but still is not working.
    SD card is readable and the LEDs are able to lit (in other programs like "rainbow" or "fire"). On the hardware side, everything should be correct. However, I am not familiar with C programming at all. which is why I turned to you. As is well known, one learns best from mistakes :-D
    I'm not sure if I can render this as it is currently with OctoWS2811 or if I need to use some special formatting here (write pixel).
    Apr 2013
    London, uk
    959
    Hi, we all have to learn, and hopefully are still doing so. Exactly which test (rainbow / fire / etc) worked with your leds? under the teensyduino file menu > examples (Fastled or octows2811 or other)? from the above, I assume that you are using ws2811 leds.
    Also, did you get the serial print statements show up from the drawbmp function?
    Nov 2021
    Switzerland
    17
    All the examples under Examples<OctoWS2811<Rainbow are working.
    Im using WS2812B (neopixel) but they are working correctly with the WS2811 library
    I get the following serial print statements as output from serial:
    -=Loading image 'tee.bmp'
    File size: 824
    Image size: 16x16
    File size: 824
    Image size: 16x16
    File size: 824
    Image size: 16x16
    File size: 824
    Image size: 16x16
    File size: 824
    Image size: 16x16
    File size: 824
    Image size: 16x16
    File size: 824
    Image size: 16x16
    File size: 824
    Image size: 16x16
    File size: 824
    Image size: 16x16
    File size: 824
    Image size: 16x16
    File size: 824
    Image size: 16x16
    File size: 824
    Image size: 16x16
    File size: 824
    Image size: 16x16
    File size: 824
    Image size: 16x16
    File size: 824
    Image size: 16x16
    File size: 824
    Image size: 16x16
    File size: 824
    Image size: 16x16
    File size: 824
    Apr 2013
    London, uk
    959
    your code in post #1 never calls the leds to show their colour status, even if the colour status is updated from the buffer. also, in that code (which isn't mine), there are a bunch of other issues related to image size buffers, have a scan through the code placed on this thread post number 27: https://forum.pjrc.com/threads/54440...eensy3-5/page2
    dont forget to set the size parameters for your image / led number
    That code clearly has the call to update and show the leds, and also sets out an example to light up the leds with a pattern, and also has some serial output to check where the programme is falling over. You call comment out or add in serial prints to help debug.
    Nov 2021
    Switzerland
    17
    Hi Mortom, I finally found time to test this and it helped me a lot! I have now additionally noticed that I am missing power accordingly and the colors drift off..
    Therefore, I ordered a sufficient power supply and am still waiting for delivery. But the bpm is successfully displayed with your snippet!
    Apr 2013
    London, uk
    959
    glad you got the BMP showing with the 'real' code. not sure where your original code came from, but whatever the case, you need to break it down into smaller parts and check the flow, otherwise its just garbage and you wont be able to leverage it to make your own project work how you want it to work.
    Nov 2021
    Switzerland
    17
    Hi Morton!
    I have received my powersupply which is now working brilliant. One last thing is the LED coloring. WS2811_GRB is the correct setting if i try to calibrate with your code snipped
    //do a colour wipe to set all leds to red
      for (int i=0; i < leds.numPixels(); i++) {
        leds.setPixel(i, RED);
        leds.show();
        delay(5);
    Means red/green/blue are shown correctly when i change the hexcode in
    #define RED    0x0000ff
    Anyhow, if I load up a bmp file, the colors are completely messed up. Not sure if it has to do with your
    //------- HELPER FUNCTION------//
    // Create a 24 bit color value from R,G,B ////these strips are BGR, but you might need to change this
    unsigned int Color(byte r, byte b, byte g)
    But i have tried different settings with no success.
    This is my calibration picture, i never get black (off) and white for the face "contures"
    Any idea? I think there is something mixing up in your code from your first post here, isnt it?
    Teensy 4.1
    WS2812B
    5V
    Apr 2013
    London, uk
    959
    hi, so easiest way to get the colours sorts is to load a bmp that has three sections, one each of R,G and B, so that you can focus in on things. The priority would be to set the set the LEDs call "WS2811_whatever" to the description on what you bought, and then set the defines to that order. then test your RGB blocks image, and reorder the helper function.
    Another way is to run the colour wipe test routine for #define RED 0x0000ff, but move the ff value to the location of R that the seller states is the order of R and G and B. if leds are RGB, then try 0xff0000
    Nov 2021
    Switzerland
    17
    Hi Morton & thank you so much for your inputs!
    I have created a template with all needed colors (plus indicator 2 white squares for rotation control)
Name:	Screenshot 2021-12-08 232754.jpg
    After calibration the output looks like this:
    Looks okay!!
    But then i open up a normal bmp for example this one:
    Name:  Screenshot 2021-12-08 234746.jpg
    First: rotated 90 degrees counterclockwise and looks like this
Name:	Screenshot 2021-12-08 234647.jpg
    So how the hell is that happening?
    Actual code:
    #include <WS2812Serial.h>
    //----------set the three below------//
    const int ledsPerStrip = 256;
    const int pin = 1;
    #define imageHeight 16
    #define imageWidth 16
    DMAMEM int displayMemory[ledsPerStrip * 6];
    int drawingMemory[ledsPerStrip * 6];
    const int config = WS2812_GRB;
    WS2812Serial leds(ledsPerStrip, displayMemory, drawingMemory, pin, config);
    const int chipSelect = BUILTIN_SDCARD;
    //buffer to hold pixel data. remains size of pixel number//
    const int ARRAY_SIZE = imageHeight * imageWidth;
    const int byteBuffSize = ARRAY_SIZE * 3;
    byte pixelBUFFER[byteBuffSize];
    byte ArrayB[ARRAY_SIZE];
    byte ArrayR[ARRAY_SIZE];
    byte ArrayG[ARRAY_SIZE];
    void setup(void) {
      leds.begin();
      leds.show();
      // if you dont get all leds lighting then going off, check your wiring
      Serial.println("init");
      Serial.print("Initializing SD card…");
      if (!SD.begin(chipSelect)) {
        Serial.println("initialization failed!");
        while (1);
      Serial.println("SD OK!");
      bmpDraw("rgb.bmp");
      for (int i = 0; i < leds.numPixels(); i++) {
        leds.show();
        delay(5);
    int32_t readNbytesInt(File *p_file, int position, byte nBytes)
      if (nBytes > 4)
        return 0;
      p_file->seek(position);
      int32_t weight = 1;
      int32_t result = 0;
      for (; nBytes; nBytes--)
        result += weight * p_file->read();
        weight <<= 8;
      return result;
    void bmpDraw( char* fileName)
      // Open file
      File bmpImage = SD.open(fileName, FILE_READ);
      int32_t dataStartingOffset = readNbytesInt(&bmpImage, 0x0A, 4);
      // Change their types to int32_t (4byte)
      int32_t width = readNbytesInt(&bmpImage, 0x12, 4); //0x12 - dec18
      int32_t height = readNbytesInt(&bmpImage, 0x16, 4); //0x16 - dec22
      int32_t ImgSize = readNbytesInt(&bmpImage, 0x22, 4); //-dec34
      Serial.println(width);
      Serial.println(height);
      Serial.println(ImgSize);
      int16_t pixelsize = readNbytesInt(&bmpImage, 0x1C, 2);
      if (pixelsize != 24)
        Serial.println("Image is not 24 bpp");
        while (1);
      bmpImage.seek(dataStartingOffset);//skip bitmap header
      byte R, G, B;
      for (int i = 0; i < ARRAY_SIZE; i++) {
        ArrayB[i] = bmpImage.read();
        ArrayG[i] = bmpImage.read();
        ArrayR[i] = bmpImage.read();
      bmpImage.close();
      Serial.println("done writing to Buffer");
      // Test
      uint32_t ledCount = 0;
      uint32_t ledLocation = 0;
      for (int y = 0; y < imageHeight; y++) { //for each row
        for (int x =  0; x < imageWidth; x++) { //go through each coloumn
          //use the & bitwise method to see if an odd or even row, we start rows at zero, so if row is odd, we go backwards
          if ( y & 0x01) {
            ledLocation =  (y * imageWidth) + ((imageWidth - 1) - x);
            // Even rows go forwards
            ledLocation = (y * imageWidth) + x;
          //set the pixel at ledLocation with the next colour in the colour array
          leds.setPixel(ledLocation, Color(ArrayR[ledCount], ArrayG[ledCount], ArrayB[ledCount]));
          //move on the colour array location by one.
          ledCount = ledCount + 1;
      leds.show();
      //  int ledCount =0;
      //    for(int i=0; i<width*height;i++){
      //      leds.setPixel(ledCount,Color(ArrayB[i],ArrayG[i],ArrayR[i]));
      //        ledCount = ledCount+1;
      //    leds.show();
    unsigned int Color(byte g, byte b, byte r)
      //Take the lowest 8 bits of each value and append them end to end
      return ( ((unsigned int)g & 0x1F ) << 16 | ((unsigned int)r & 0x1F) << 8 | (unsigned int)b & 0x1F);
    //end of helper function
    Apr 2013
    London, uk
    959
    that is odd. The four colour test BMP file comes out correct, but the next BMP file doesn't. Both files were formatted to the same BMP type, 24bit?
    Nov 2021
    Switzerland
    17
    Yes they are the same (i have recreated both the same way).
    And this is a new try with a Bird:
    Name:  Screenshot 2021-12-09 114312.jpg
    Results in:
    what strikes me immediately, the image is mirrored vertically... Could it be related to this?
    Attached Images Attached Images
    • File Type: bmp 0.bmp (824 Bytes, 10 views)
    Apr 2013
    London, uk
    959
    confusing, and i am really not sure why this is happening. It certainly looks like for the non test image (bird) the line leds.setPixel(ledLocation, Color(ArrayR[ledCount], ArrayG[ledCount], ArrayB[ledCount]));
    should have the colour values in a different order. In your image of the leds, red image comes out as blue, and blue comes out as green. might be worth a quick swap test like this:
    leds.setPixel(ledLocation, Color(ArrayG[ledCount], ArrayB[ledCount], ArrayR[ledCount]));
    for the rotation of the pixels, you could use an array to hold the reference pixel location, and reference that. so instead of using
    you would reference an array of pixel locations that are offset by the rotation and flipped. Flipping could be done by filling the array in reverse:
      for (int i = ARRAY_SIZE; i >0; i--) {
    but you still need to shift them around on the rotation. relocating pixels can be done by using a reference array, such that when you say to put the colour data for Red into the ArrayR[] array at location i, you can change that to say put it at location myRealLocations[i] like this ArrayR[ myRealLocations[i] ]. in the array myRealLocations[] you just write out the real locations of the pixels. This can also be done in maths, where locatoin of pixel 15 is actual the nth led on the grid.
    However, there seems to be something fundamentally odd, and this feels like a lash up really.
    Nov 2021
    Switzerland
    17
    I will try the rotation thing of course and the quick swap test!
    Im using #include <WS2812Serial.h> atm. Could that issue any problem or is there something known? Do i have to focus on something special here about the settings? I use Teensy 4.1 with WS2812b pixels. Maybe there is some known Problem?
    @PaulStoffregen maybe any Idea about this combination? (hope this is the right method to mention someone)
    Apr 2013
    London, uk
    959
    no, it should not be anything to do with ws2812serial. its probably just a bit of adjusting how the pixel data is retrieve from the the three colour arrays. for the colours take a look at the "leds.setPixel(ledLocation, Color(ArrayG[ledCount], ArrayB[ledCount], ArrayR[ledCount]));" changes and test
    Nov 2021
    Switzerland
    17
    Okay now its getting funny!
    The "Bird" worked with the quick swap of the array.
    But for all the other pictures it was wrong again (tested 2 different ones)
    I now use my initial code for this picture (without swaping or something) with this bmp:
    Name:  Screenshot 2021-12-09 233004.jpg
    With the Result:
    correct colloring....
    For the "Bird" i need to use the color swap from your answer above to get it shown correctly! ("leds.setPixel(ledLocation, Color(ArrayG[ledCount], ArrayB[ledCount], ArrayR[ledCount]));" )
    I know that I have seen a color converter somewhere in the code of the manufacturer of the "bmps", but I am not quite sure anymore... yet I wonder how the hell this can deviate....
    This is the original repository with all the bmp files & Code:
    https://github.com/Jerware/GameFrameV2
    The position which i mentioned in the code is this one Line 144:
    unsigned long
    prevRemoteMillis = 0, // last time a valid remote code was received
    colorCorrection = 0xFFFFFF, // color correction setting
    colorTemperature = 0xFFFFFF, // color Temperature
    remoteCodeMenu = 0,
    remoteCodeNext = 0,
    remoteCodePower = 0,
    menuPowerCounter = 0, // counter for holding menu button to turn off power
    lastTime = 0, // used to calculate draw time
    drawTime = 0, // time to read from sd
    holdTime = 200, // millisecods to hold each .bmp frame
    swapTime = 0, // system time to advance to next frame
    baseTime = 0, // system time logged at start of each new image sequence
    buttonTime = 0, // time the last button was pressed (debounce code)
    menuEndTime = 0, // pause animation while in menu mode
    menuEnterTime = 0; // time we enter menu
    And also uses
    FastLED.setCorrection(colorCorrection);
    Line 281
