I am having issues doing USBSerial communication between the Teensy 3.6 and the CP2104. The example code I'm using is:
The CP2104 is correctly identified but I can then not communicate, the output log after enabling debugging is:
I would really appreciate any help with this.
// Simple test of USB Host Mouse/Keyboard
// This example is in the public domain
#include <Arduino.h>
#include "USBHost_t36.h"
#define USBBAUD 115200
uint32_t baud = USBBAUD;
uint32_t format = USBHOST_SERIAL_8N1;
USBHost myusb;
USBSerial userial(myusb);
USBDriver *drivers[] = {&userial};
#define CNT_DEVICES (sizeof(drivers)/sizeof(drivers[0]))
const char * driver_names[CNT_DEVICES] = { "USERIAL1" };
bool driver_active[CNT_DEVICES] = {true};
pinMode(13, OUTPUT);
pinMode(2, OUTPUT);
pinMode(3, OUTPUT);
for (int i = 0; i < 5; i++) {
digitalWrite(2, HIGH);
delayMicroseconds(50);
digitalWrite(2, LOW);
while (!Serial && (millis() < 5000)) ; // wait for Arduino Serial Monitor
Serial.println("\n\nUSB Host Testing - Serial");
myusb.begin();
userial.begin(baud,format);
bool userial_prev = false;
void loop(){
if (userial && !userial_prev) {
userial.begin(baud ,format);
userial_prev = userial; // remember the current state of being connected.
// Print out information about different devices.
for (uint8_t i = 0; i < CNT_DEVICES; i++) {
if (*drivers[i] != driver_active[i]) {
if (driver_active[i]) {
Serial.printf("*** Device %s - disconnected ***\n", driver_names[i]);
driver_active[i] = false;
Serial.printf("*** Device %s %x:%x - connected ***\n", driver_names[i], drivers[i]->idVendor(), drivers[i]->idProduct());
driver_active[i] = true;
const uint8_t *psz = drivers[i]->manufacturer();
if (psz && *psz) Serial.printf(" manufacturer: %s\n", psz);
psz = drivers[i]->product();
if (psz && *psz) Serial.printf(" product: %s\n", psz);
psz = drivers[i]->serialNumber();
if (psz && *psz) Serial.printf(" Serial: %s\n", psz);
// If this is a new Serial device.
// if (drivers[i] == &userial) {
// Serial.println("Try to start Serial...");
// // Lets try first outputting something to our USerial to see if it will go out...
// userial.begin(baud,format);
while (Serial.available()) {
userial.write(Serial.read());
while (userial.available()) {
Serial.println("USerial Available");
Serial.write(userial.read());
port change: 10001803
connect
begin reset
port change: 10001805
port enabled
end recovery
new_Device: 12 Mbit/sec
new_Pipe
enumeration:
enumeration:
enumeration:
Device Descriptor:
12 01 00 02 00 00 00 40 C4 10 60 EA 00 01 01 02 03 01
VendorID = 10C4, ProductID = EA60, Version = 0100
Class/Subclass/Protocol = 0 / 0 / 0
Number of Configurations = 1
enumeration:
enumeration:
Manufacturer: Silicon Labs
enumeration:
Product: CP2104 USB to UART Bridge Controller
enumeration:
Serial Number: 025B6C6B
enumeration:
Config data length = 32
enumeration:
Configuration Descriptor:
09 02 20 00 01 01 00 80 32
NumInterfaces = 1
ConfigurationValue = 1
09 04 00 00 02 FF 00 00 02
Interface = 0
Number of endpoints = 2
Class/Subclass/Protocol = 255 / 0 / 0
07 05 01 02 40 00 00
Endpoint = 1 OUT
Type = Bulk
Max Size = 64
Polling Interval = 0
07 05 82 02 40 00 00
Endpoint = 2 IN
Type = Bulk
Max Size = 64
enumeration:
USBSerial claim this=1FFF2020
vid=10C4, pid=EA60, bDeviceClass = 0, bDeviceSubClass = 0, bDeviceProtocol = 0
09 04 00 00 02 FF 00 00 02 07 05 01 02 40 00 00 07 05 82 02 40 00 00
len = 23
USBSerial, rxep=2(64), txep=1(64)
rx buffer size:196
tx buffer size:196
new_Pipe
new_Pipe
CP210X: 0x41, 0x11, 0, 0, 0 - reset port
control callback (serial) F
control callback (serial) E
control callback (serial) C
control callback (serial) 8
ERROR Followup
remain on followup list
*** Device USERIAL1 10c4:ea60 - connected ***
manufacturer: Silicon Labs
product: CP2104 USB to UART Bridge Controller
