/* Audio Library for Teensy 3.X
* Copyright (c) 2019, Paul Stoffregen, paul@pjrc.com
* Development of this audio library was funded by PJRC.COM, LLC by sales of
* Teensy and Audio Adaptor boards. Please support PJRC's efforts to develop
* open source software by purchasing Teensy or other PJRC products.
* THE SOFTWARE.
by Frank Bösing
#if defined(__IMXRT1052__) || defined(__IMXRT1062__)
#include <Arduino.h>
#include "myinput_spdif3.h"
#include "myoutput_spdif3.h"
#include "utility/imxrt_hw.h"
DMAMEM __attribute__((aligned(32)))
static uint32_t spdif_rx_buffer[AUDIO_BLOCK_SAMPLES * 4];
static int16_t inblockL[AUDIO_BLOCK_SAMPLES];
static int16_t inblockR[AUDIO_BLOCK_SAMPLES];
static int16_t Newsmpls;
int16_t *myAudioInputSPDIF3::inblkL=inblockL;
int16_t *myAudioInputSPDIF3::inblkR=inblockR;
int16_t *myAudioInputSPDIF3::newsmpls=&Newsmpls;
static int16_t outblockL[AUDIO_BLOCK_SAMPLES];
static int16_t outblockR[AUDIO_BLOCK_SAMPLES];
static int16_t Getsmpls;
int16_t *myAudioInputSPDIF3::outblkL=outblockL;
int16_t *myAudioInputSPDIF3::outblkR=outblockR;
int16_t *myAudioInputSPDIF3::getsmpls=&Getsmpls;
audio_block_t * myAudioInputSPDIF3::block_left = NULL;
audio_block_t * myAudioInputSPDIF3::block_right = NULL;
uint16_t myAudioInputSPDIF3::block_offset = 0;
bool myAudioInputSPDIF3::update_responsibility = false;
DMAChannel myAudioInputSPDIF3::dma(false);
FLASHMEM
void myAudioInputSPDIF3::begin(void)
dma.begin(true); // Allocate the DMA channel first
myAudioOutputSPDIF3::config_spdif3();
Serial.println("begin");
const int nbytes_mlno = 2 * 4; // 8 Bytes per minor loop
dma.TCD->SADDR = &SPDIF_SRL;
dma.TCD->SOFF = 4;
dma.TCD->ATTR = DMA_TCD_ATTR_SSIZE(2) | DMA_TCD_ATTR_DSIZE(2);
dma.TCD->NBYTES_MLNO = DMA_TCD_NBYTES_MLOFFYES_NBYTES(nbytes_mlno) | DMA_TCD_NBYTES_SMLOE |
DMA_TCD_NBYTES_MLOFFYES_MLOFF(-8);
dma.TCD->SLAST = -8;
dma.TCD->DADDR = spdif_rx_buffer;
dma.TCD->DOFF = 4;
dma.TCD->DLASTSGA = -sizeof(spdif_rx_buffer);
dma.TCD->CITER_ELINKNO = sizeof(spdif_rx_buffer) / nbytes_mlno;
dma.TCD->BITER_ELINKNO = sizeof(spdif_rx_buffer) / nbytes_mlno;
dma.TCD->CSR = DMA_TCD_CSR_INTHALF | DMA_TCD_CSR_INTMAJOR;
dma.triggerAtHardwareEvent(DMAMUX_SOURCE_SPDIF_RX);
update_responsibility = update_setup();
dma.attachInterrupt(isr);
dma.enable();
SPDIF_SRCD = 0;
SPDIF_SCR |= SPDIF_SCR_DMA_RX_EN;
CORE_PIN15_CONFIG = 3;
IOMUXC_SPDIF_IN_SELECT_INPUT = 0; // GPIO_AD_B1_03_ALT3
//myAudioInputSPDIF3::*inblkL=inblockL;
//pinMode(13, OUTPUT);
void myAudioInputSPDIF3::isr(void)
uint32_t daddr/*, offset*/;
const int32_t *src, *end;
//int16_t *dest_left, *dest_right;
//audio_block_t *left, *right;
int16_t *inL=(int16_t *)myAudioInputSPDIF3::inblkL;
int16_t *inR=(int16_t *)myAudioInputSPDIF3::inblkR;
Newsmpls=1;
dma.clearInterrupt();
//digitalWriteFast(13, !digitalReadFast(13));
if (myAudioInputSPDIF3::update_responsibility) AudioStream::update_all();
daddr = (uint32_t)(dma.TCD->DADDR);
if (daddr < (uint32_t)spdif_rx_buffer + sizeof(spdif_rx_buffer) / 2) {
// DMA is receiving to the first half of the buffer
// need to remove data from the second half
src = (int32_t *)&spdif_rx_buffer[AUDIO_BLOCK_SAMPLES * 2];
end = (int32_t *)&spdif_rx_buffer[AUDIO_BLOCK_SAMPLES * 4];
// DMA is receiving to the second half of the buffer
// need to remove data from the first half
src = (int32_t *)&spdif_rx_buffer[0];
end = (int32_t *)&spdif_rx_buffer[AUDIO_BLOCK_SAMPLES*2];
//*inL++=0x12;src++;
//*inR++=0xff34;src++;
do
*inL++=int16_t((*src++)>>8);
*inR++=int16_t((*src++)>>8);
} while (src < end);
left = myAudioInputSPDIF3::block_left;
right = myAudioInputSPDIF3::block_right;
if (left != NULL && right != NULL) {
offset = myAudioInputSPDIF3::block_offset;
if (offset <= AUDIO_BLOCK_SAMPLES*2) {
dest_left = &(left->data[offset]);
dest_right = &(right->data[offset]);
myAudioInputSPDIF3::block_offset = offset + AUDIO_BLOCK_SAMPLES*2;
do {
#if IMXRT_CACHE_ENABLED >=1
SCB_CACHE_DCIMVAC = (uintptr_t)src;
asm("dsb":::"memory");
*dest_left++ = (*src++) >> 8;
*dest_right++ = (*src++) >> 8;
else if (left != NULL) {
do {
src++;
src++;
src++;
src++;
else if (right != NULL) {
do {
src++;
src++;
src++;
src++;
//Serial.println("isr");
void myAudioInputSPDIF3::update(void)
int i;
audio_block_t *new_left=NULL, *new_right=NULL, *out_left=NULL, *out_right=NULL;
// allocate 2 new blocks, but if one fails, allocate neither
new_left = allocate();
if (new_left != NULL) {
new_right = allocate();
if (new_right == NULL) {
release(new_left);
new_left = NULL;
__disable_irq();
if (block_offset >= AUDIO_BLOCK_SAMPLES) {
// the DMA filled 2 blocks, so grab them and get the
// 2 new blocks to the DMA, as quickly as possible
out_left = block_left;
block_left = new_left;
out_right = block_right;
block_right = new_right;
block_offset = 0;
__enable_irq();
// then transmit the DMA's former blocks
transmit(out_left, 0);
release(out_left);
transmit(out_right, 1);
release(out_right);
//Serial.print(".");
} else if (new_left != NULL) {
// the DMA didn't fill blocks, but we allocated blocks
if (block_left == NULL) {
// the DMA doesn't have any blocks to fill, so
// give it the ones we just allocated
block_offset = 0;
__enable_irq();
// the DMA already has blocks, doesn't need these
__enable_irq();
release(new_left);
release(new_right);
// The DMA didn't fill blocks, and we could not allocate
// memory... the system is likely starving for memory!
// Sadly, there's nothing we can do.
__enable_irq();
// configure();
// monitorResampleBuffer(); //important first call 'monitorResampleBuffer' then 'resample'
audio_block_t *block_left =allocate();
audio_block_t *block_right =nullptr;
if (block_left!= nullptr)
block_right = allocate();
if (block_right == nullptr)
release(block_left);
block_left = nullptr;
if (block_left && block_right)
int32_t block_offset=0;
// resample(block_left->data, block_right->data,block_offset);
for (i=0;i<AUDIO_BLOCK_SAMPLES;i++)
block_left->data[block_offset+i]=(int16_t)outblockL[i];
block_right->data[block_offset+i]=(int16_t)outblockR[i];
Getsmpls=1;
// if(block_offset < AUDIO_BLOCK_SAMPLES)
// memset(block_left->data+block_offset, 0, (AUDIO_BLOCK_SAMPLES-block_offset)*sizeof(int16_t));
// memset(block_right->data+block_offset, 0, (AUDIO_BLOCK_SAMPLES-block_offset)*sizeof(int16_t));
//#ifdef DEBUG_SPDIF_IN
// Serial.print("filled only ");
// Serial.print(block_offset);
// Serial.println(" samples.");
//#endif
transmit(block_left, 0);
block_left=nullptr;
transmit(block_right, 1);
release(block_right);
block_right=nullptr;
Serial.println("Not enough blocks available. Too few audio memory?");
//#endif
bool myAudioInputSPDIF3::pllLocked(void)
return (SPDIF_SRPC & SPDIF_SRPC_LOCK) == SPDIF_SRPC_LOCK ? true:false;
unsigned int myAudioInputSPDIF3::sampleRate(void) {
if (!pllLocked()) return 0;
return (float)((uint64_t)F_BUS_ACTUAL * SPDIF_SRFM) / (0x8000000ULL * myAudioOutputSPDIF3::dpll_Gain()) + 0.5F;
