#pragma once
#define SPLIT16(a) ((a) & 255), ((a) >> 8)
#define SPLIT32(a) (uint8_t)((a) & 255), (uint8_t)(((a) >> 8) & 255), (uint8_t)(((a) >> 16) & 255), (uint8_t)(((a) >> 24) & 255)
#define DEV_INIT_MAGIC 0xDEADF00D
#define DEV_INIT_HEADER(v, w, h, offset, bpp, mhz, code_enable, code_disable, code_normal, code_invert) \
SPLIT32(DEV_INIT_MAGIC), \
SPLIT16(v), SPLIT16(w), SPLIT16(h), (offset), (bpp), (mhz), \
(code_enable), (code_disable), (code_normal), (code_invert)
#define DRV_RESET_LOW 255
#define DRV_RESET_HIGH 254
#define DRV_DELAY_MS 243
struct __attribute__((packed)) strInitHeader // caution with alignment *** make sure header uint16 don't cross 4 byte boundary!!!!
uint32_t m_magic; // allows us to see if pointing to what we expect 0xDEADF00D
uint16_t m_version; // ie 1305, 7789, etc
int16_t m_width;
int16_t m_height;
int8_t m_offset; // some 1 bit modes have an offset
uint8_t m_bpp; // 1, 4, 8, 16
uint8_t m_mhz; // usually 20 for 20Mhz but if chip can go faster adjust
uint8_t m_code_enable; // command to disable display or 0
uint8_t m_code_disable; // command to enable display or 0
uint8_t m_code_normal; // code for normal display or 0
uint8_t m_code_invert; // code of inverted display or 0
ST7789 240*240 1.3"
#define ST7789_240x240_XSTART 0
#define ST7789_240x240_YSTART 80
#define ST77XX_NOP 0x00
#define ST77XX_SWRESET 0x01
#define ST77XX_RDDID 0x04
#define ST77XX_RDDST 0x09
#define ST77XX_SLPIN 0x10
#define ST77XX_SLPOUT 0x11
#define ST77XX_PTLON 0x12
#define ST77XX_NORON 0x13
#define ST77XX_INVOFF 0x20
#define ST77XX_INVON 0x21
#define ST77XX_DISPOFF 0x28
#define ST77XX_DISPON 0x29
#define ST77XX_CASET 0x2A
#define ST77XX_RASET 0x2B
#define ST77XX_RAMWR 0x2C
#define ST77XX_RAMRD 0x2E
#define ST77XX_PTLAR 0x30
#define ST77XX_COLMOD 0x3A
#define ST77XX_MADCTL 0x36
#define ST77XX_MADCTL_MY 0x80
#define ST77XX_MADCTL_MX 0x40
#define ST77XX_MADCTL_MV 0x20
#define ST77XX_MADCTL_ML 0x10
#define ST77XX_MADCTL_RGB 0x00
#define ST77XX_RDID1 0xDA
#define ST77XX_RDID2 0xDB
#define ST77XX_RDID3 0xDC
#define ST77XX_RDID4 0xDD
// https://www.reddit.com/r/RASPBERRY_PI_PROJECTS/comments/9b3nun/has_anyone_gotten_the_waveshare_st7789v_13_lcd/
// https://www.waveshare.com/wiki/File:1.3inch_LCD_Module_code.7z
const PROGMEM uint8_t TFT_initST7789_240_240_16BPP[] = // if no CS must be mode 3
DEV_INIT_HEADER(7789, 240, 240, 0, 16, 20, ST77XX_DISPON, ST77XX_DISPOFF, ST77XX_INVOFF, ST77XX_INVON),
DRV_DELAY_MS, 200,
DRV_RESET_LOW,
DRV_DELAY_MS, 200,
DRV_RESET_HIGH,
DRV_DELAY_MS, 200,
2,ST77XX_MADCTL, 0x00,
2,ST77XX_COLMOD,0x55, //1=na, 2=na 4=display latch order, 8=RGB/BGR, 16=line address order, 32= page/col oder, 64=col addr order, 128=page addr order
6,0xB2,0x0C,0x0C,0x00,0x33,0x33,
2,0xB7,0x35,
2,0xBB,0x19,
2,0xC0,0x2C,
2,0xC2,0x01,
2,0xC3,0x12,
2,0xC4,0x20,
2,0xC6,0x0F,
3,0xD0,0xA4,0xA1,
15,0xE0,0xD0,0x04,0x0D,0x11,0x13,0x2B,0x3F,0x54,0x4C,0x18,0x0D,0x0B,0x1F,0x23,
15,0xE1,0xD0,0x04,0x0C,0x11,0x13,0x2C,0x3F,0x44,0x51,0x2F,0x1F,0x1F,0x20,0x23,
// 1,ST77XX_INVOFF,
1,ST77XX_SLPOUT,
//1,ST77XX_DISPON,
0 };
Nokia 5110
http://skpang.co.uk/catalog/images/lcd/graphic/docs/User_Manual_ET_LCD5110.pdf
const PROGMEM uint8_t LCD_initNokia5110_84_48_1BPP[] = // untested
DEV_INIT_HEADER(5110, 84, 48, 0, 1, 20, 0, 0, 0x08, 0x0c),
1, 0x20, // normal instructuion set default
0
ST7735 - LCD
https://www.edaboard.com/showthread.php?258790-Initializing-a-ST7735-driven-lcd-spi-display
//setReset(0,
//DelayMs(500,
//setReset(1,
//DelayMs(500,
// Some register settings
#define ST7735_MADCTL_BGR 0x08
#define ST7735_MADCTL_MH 0x04
#define ST7735_FRMCTR1 0xB1
#define ST7735_FRMCTR2 0xB2
#define ST7735_FRMCTR3 0xB3
#define ST7735_INVCTR 0xB4
#define ST7735_DISSET5 0xB6
#define ST7735_PWCTR1 0xC0
#define ST7735_PWCTR2 0xC1
#define ST7735_PWCTR3 0xC2
#define ST7735_PWCTR4 0xC3
#define ST7735_PWCTR5 0xC4
#define ST7735_VMCTR1 0xC5
#define ST7735_PWCTR6 0xFC
#define ST7735_GMCTRP1 0xE0
#define ST7735_GMCTRN1 0xE1
const PROGMEM uint8_t TFT_init7735B_128_160_16BPP[] = // untested
DEV_INIT_HEADER(7735, 128, 160, 0, 16, 20, 0x29, 0x28, 0x20, 0x21),
DRV_DELAY_MS, 200,
DRV_RESET_LOW,
DRV_DELAY_MS, 200,
DRV_RESET_HIGH,
DRV_DELAY_MS, 200,
2, ST77XX_COLMOD, // 3: Set color mode, 1 arg + delay:
0x05, // 16-bit color
4, ST7735_FRMCTR1, // 4: Frame rate control, 3 args + delay:
0x00, // fastest refresh
0x06, // 6 lines front porch
0x03, // 3 lines back porch
2, ST77XX_MADCTL, // 5: Mem access ctl (directions), 1 arg:
0xc0, // Row/col addr, bottom-top refresh
3, ST7735_DISSET5, // 6: Display settings #5, 2 args:
0x15, // 1 clk cycle nonoverlap, 2 cycle gate
// rise, 3 cycle osc equalize
0x02, // Fix on VTL
2, ST7735_INVCTR, // 7: Display inversion control, 1 arg:
0x0, // Line inversion
3, ST7735_PWCTR1, // 8: Power control, 2 args + delay:
0x02, // GVDD = 4.7V
0x70, // 1.0uA
2, ST7735_PWCTR2, // 9: Power control, 1 arg, no delay:
0x05, // VGH = 14.7V, VGL = -7.35V
3, ST7735_PWCTR3, // 10: Power control, 2 args, no delay:
0x01, // Opamp current small
0x02, // Boost frequency
3, ST7735_VMCTR1, // 11: Power control, 2 args + delay:
0x3C, // VCOMH = 4V
0x38, // VCOML = -1.1V
3, ST7735_PWCTR6, // 12: Power control, 2 args, no delay:
0x11, 0x15,
17, ST7735_GMCTRP1, // 13: Gamma Adjustments (pos. polarity), 16 args + delay:
0x09, 0x16, 0x09, 0x20, // (Not entirely necessary, but provides
0x21, 0x1B, 0x13, 0x19, // accurate colors)
0x17, 0x15, 0x1E, 0x2B,
0x04, 0x05, 0x02, 0x0E,
17, ST7735_GMCTRN1, // 14: Gamma Adjustments (neg. polarity), 16 args + delay:
0x0B, 0x14, 0x08, 0x1E, // (Not entirely necessary, but provides
0x22, 0x1D, 0x18, 0x1E, // accurate colors)
0x1B, 0x1A, 0x24, 0x2B,
0x06, 0x06, 0x02, 0x0F,
0};
//LCD_Rectangle(0, 0, 128, 160, 0, // black it out
//LCD_Command(0x29,//Display on
SSD1327 16 color grayscale 128*128 etc
https://www.crystalfontz.com/controllers/SolomonSystech/SSD1327/434/
const PROGMEM uint8_t OLED_init1327_128_128_4BPP[] =
DEV_INIT_HEADER(1327, 128, 128, 0, 4, 40, 0xaf, 0xae, 0xa4, 0xa7), // 40Mhz
DRV_DELAY_MS, 200,
DRV_RESET_LOW,
DRV_DELAY_MS, 200,
DRV_RESET_HIGH,
DRV_DELAY_MS, 200,
1, 0xAE, // display off
2, 0xA8, 127, //0x5F, // mux ratio ... 5f = 96
2, 0xA0, 0x51, // set remap
2, 0xAB, 0x01, // function selection A
2, 0xA1, 0, // display start line
2, 0xA2, 0, // vertical offset was 0x60
2, 0x81, 0x80, // contrast
2, 0xB1, 0xf1, // set phase length ... 0x51
2, 0xB3, 0x00, // Set Front Clock Divider / Oscillator Frequency //80Hz:0xc1 90Hz:0xe1 100Hz:0x00 110Hz:0x30 120Hz:0x50 130Hz:0x70 01
1, 0xB9, // linear LUT
2, 0xBC, 0x08, // Set Pre - charge voltage
2, 0xBE, 0x0f, // Set VCOMH .. 0x07
2, 0xB6, 0x0f, // Set Second precharge Period 0x01
2, 0xD5, 0x62, // Function Selection B
// 1, 0xA4, // normal display - reset
1, 0x2E, // stop scrolling
2, 0xFD, 0x12, // command lock
0 };
SSD1331 - 8 bit BGR8 mode
#define D1331_A0_MODE_256 0x00
#define D1331_A0_MODE_65K 0x40
#define D1331_A0_HORZ_INC 0x00
#define D1331_A0_VERT_INC 0x01
#define D1331_A0_RAM_COL_0_95 0x00
#define D1331_A0_RAM_COL_95_0 0x02
#define D1331_A0_ORDER_RGB 0x00
#define D1331_A0_ORDER_BGR 0x04
#define D1331_A0_LR_SWAP_COM_DISABLE 0x00
#define D1331_A0_LR_SWAP_COM_ENABLE 0x08
#define D1331_A0_SCAN_FROM_COM_MIN_MAX 0x00
#define D1331_A0_SCAN_FROM_COM_MAX_MIN 0x10
#define D1331_A0_COM_SPLIT_ODD_EVEN_ENABLE 0x00
#define D1331_A0_COM_SPLIT_ODD_EVEN_DISABLE 0x20
const PROGMEM uint8_t OLED_initSSD1331_96_64_8BPP[] = // untested ... once working add 65K mode
DEV_INIT_HEADER(1331, 96, 64, 0, 8, 20, 0xaf, 0xae, 0xa4, 0xa7), //
DRV_DELAY_MS, 200,
DRV_RESET_LOW,
DRV_DELAY_MS, 200,
DRV_RESET_HIGH,
DRV_DELAY_MS, 200,
1, 0xae, //Display off
2, 0x81, 128, //set contrast for colorA
2, 0x82, 128 ,//set contrast for colorB
2, 0x83, 128, //set contrast for colorC
2, 0x87, 6, //master current control
2, 0x8a, 100, //Set Second Pre-change Speed For ColorA
2, 0x8b, 120, //Set Second Pre-change Speed For ColorB
2, 0x8c, 100, //Set Second Pre-change Speed For ColorC
2, 0xa0, D1331_A0_HORZ_INC | D1331_A0_RAM_COL_95_0 | D1331_A0_ORDER_BGR | D1331_A0_MODE_256 | D1331_A0_SCAN_FROM_COM_MAX_MIN | D1331_A0_COM_SPLIT_ODD_EVEN_DISABLE, //set re=map & data format .. 0x76
2, 0xa1, 0, //set display start line
2, 0xa2, 0, //set display offset
//1, 0xa4, //set display mode normal
2, 0xa8, 0x3f, //set multiplex ratio
2, 0xad, 0x8e, //set master configuration
2, 0xb0, 0, //set power save
2, 0xb1, 0x31, //phase 1 and 2 period adjustment
2, 0xb3, 0xf0, //display clock divider / oscillator frequency
2, 0xbb, 58, //Set Pre-Change Level
2, 0xbe, 62, //set vcomh
//1, 0xaf, //set display on
0
#define ILI9341_TFTWIDTH 240 ///< ILI9341 max TFT width
#define ILI9341_TFTHEIGHT 320 ///< ILI9341 max TFT height
#define ILI9341_NOP 0x00 ///< No-op register
#define ILI9341_SWRESET 0x01 ///< Software reset register
#define ILI9341_RDDID 0x04 ///< Read display identification information
#define ILI9341_RDDST 0x09 ///< Read Display Status
#define ILI9341_SLPIN 0x10 ///< Enter Sleep Mode
#define ILI9341_SLPOUT 0x11 ///< Sleep Out
#define ILI9341_PTLON 0x12 ///< Partial Mode ON
#define ILI9341_NORON 0x13 ///< Normal Display Mode ON
#define ILI9341_RDMODE 0x0A ///< Read Display Power Mode
#define ILI9341_RDMADCTL 0x0B ///< Read Display MADCTL
#define ILI9341_RDPIXFMT 0x0C ///< Read Display Pixel Format
#define ILI9341_RDIMGFMT 0x0D ///< Read Display Image Format
#define ILI9341_RDSELFDIAG 0x0F ///< Read Display Self-Diagnostic Result
#define ILI9341_INVOFF 0x20 ///< Display Inversion OFF
#define ILI9341_INVON 0x21 ///< Display Inversion ON
#define ILI9341_GAMMASET 0x26 ///< Gamma Set
#define ILI9341_DISPOFF 0x28 ///< Display OFF
#define ILI9341_DISPON 0x29 ///< Display ON
#define ILI9341_CASET 0x2A ///< Column Address Set
#define ILI9341_PASET 0x2B ///< Page Address Set
#define ILI9341_RAMWR 0x2C ///< Memory Write
#define ILI9341_RAMRD 0x2E ///< Memory Read
#define ILI9341_PTLAR 0x30 ///< Partial Area
#define ILI9341_VSCRDEF 0x33 ///< Vertical Scrolling Definition
#define ILI9341_MADCTL 0x36 ///< Memory Access Control
#define ILI9341_VSCRSADD 0x37 ///< Vertical Scrolling Start Address
#define ILI9341_PIXFMT 0x3A ///< COLMOD: Pixel Format Set
#define ILI9341_FRMCTR1 0xB1 ///< Frame Rate Control (In Normal Mode/Full Colors)
#define ILI9341_FRMCTR2 0xB2 ///< Frame Rate Control (In Idle Mode/8 colors)
#define ILI9341_FRMCTR3 0xB3 ///< Frame Rate control (In Partial Mode/Full Colors)
#define ILI9341_INVCTR 0xB4 ///< Display Inversion Control
#define ILI9341_DFUNCTR 0xB6 ///< Display Function Control
#define ILI9341_PWCTR1 0xC0 ///< Power Control 1
#define ILI9341_PWCTR2 0xC1 ///< Power Control 2
#define ILI9341_PWCTR3 0xC2 ///< Power Control 3
#define ILI9341_PWCTR4 0xC3 ///< Power Control 4
#define ILI9341_PWCTR5 0xC4 ///< Power Control 5
#define ILI9341_VMCTR1 0xC5 ///< VCOM Control 1
#define ILI9341_VMCTR2 0xC7 ///< VCOM Control 2
#define ILI9341_RDID1 0xDA ///< Read ID 1
#define ILI9341_RDID2 0xDB ///< Read ID 2
#define ILI9341_RDID3 0xDC ///< Read ID 3
#define ILI9341_RDID4 0xDD ///< Read ID 4
#define ILI9341_GMCTRP1 0xE0 ///< Positive Gamma Correction
#define ILI9341_GMCTRN1 0xE1 ///< Negative Gamma Correction
const PROGMEM uint8_t TFT_initILI9341_240_320_16BPP[] =
DEV_INIT_HEADER(9341, 240, 320, 0, 16, 20, 0x29, 0x28, 0x20, 0x21),
DRV_DELAY_MS, 200,
DRV_RESET_LOW,
DRV_DELAY_MS, 200,
DRV_RESET_HIGH,
DRV_DELAY_MS, 200,
1, 0x28, // disable
4, 0xEF, 0x03, 0x80, 0x02,
4, 0xCF, 0x00, 0xC1, 0x30,
5, 0xED, 0x64, 0x03, 0x12, 0x81,
4, 0xE8, 0x85, 0x00, 0x78,
6, 0xCB, 0x39, 0x2C, 0x00, 0x34, 0x02,
2, 0xF7, 0x20,
3, 0xEA, 0x00, 0x00,
2, ILI9341_PWCTR1 , 0x23, // Power control VRH[5:0]
2, ILI9341_PWCTR2 , 0x10, // Power control SAP[2:0];BT[3:0]
3, ILI9341_VMCTR1 , 0x3e, 0x28, // VCM control
2, ILI9341_VMCTR2 , 0x86, // VCM control2
2, ILI9341_MADCTL , 0x48, // Memory Access Control
2, ILI9341_VSCRSADD, 0x00, // Vertical scroll zero
2, ILI9341_PIXFMT , 0x55,
3, ILI9341_FRMCTR1 , 0x00, 0x18,
4, ILI9341_DFUNCTR , 0x08, 0x82, 0x27, // Display Function Control
2, 0xF2, 0x00, // 3Gamma Function Disable
2, ILI9341_GAMMASET , 0x01, // Gamma curve selected
16, ILI9341_GMCTRP1 , 0x0F, 0x31, 0x2B, 0x0C, 0x0E, 0x08, 0x4E, 0xF1, 0x37, 0x07, 0x10, 0x03, 0x0E, 0x09, 0x00,
16, ILI9341_GMCTRN1 , 0x00, 0x0E, 0x14, 0x03, 0x11, 0x07, 0x31, 0xC1, 0x48, 0x08, 0x0F, 0x0C, 0x31, 0x36, 0x0F,
1, ILI9341_SLPOUT, // Exit Sleep
//1, ILI9341_DISPON, // Display on
0
const PROGMEM uint8_t OLED_init1351_128_128_16BPP[] = // note 40Mhz
DEV_INIT_HEADER(1351, 128, 128, 0, 16, 40, 0xaf, 0xae, 0xa6, 0xa7),
DRV_DELAY_MS, 200,
DRV_RESET_LOW,
DRV_DELAY_MS, 200,
DRV_RESET_HIGH,
DRV_DELAY_MS, 200,
2, 0xfd, 0x12,
2, 0xfd, 0xb1, // Set Command Lock
1, 0xae, // Display off
2, 0xa0, 0x04, // 0x70 = ABC ... 0x74 = CBA color sequence
2, 0xa2, 0, // Set display offset
//1, 0xa6, // Normal display
2, 0xab, 0x01, // Set Function selection
2, 0xb1, 0x32, // Set pre & dis_charge
2, 0xb3, 0xf1, // clock & frequency
4, 0xb4, 0xa0, 0xb5, 0x55, // Set Segment LOW Voltage
2, 0xb5, 0x0A, // Set GPIO
2, 0xb6, 0x01, // Set Second Pre-charge Period
65, 0xb8, //Set Gray Table
0, //0
2, //1
3, //2
4, //3
5, //4
6, //5
7, //6
8, //7
9, //8
10, //9
11, //10
12, //11
13, //12
14, //13
15, //14
16, //15
17, //16
18, //17
19, //18
21, //19
23, //20
25, //21
27, //22
29, //23
31, //24
33, //25
35, //26
37, //27
39, //28
42, //29
45, //30
48, //31
51, //32
54, //33
57, //34
60, //35
63, //36
66, //37
69, //38
72, //39
76, //40
80, //41
84, //42
88, //43
92, //44
96, //45
100, //46
104, //47
108, //48
112, //49
116, //50
120, //51
125, //52
130, //53
135, //54
140, //55
145, //56
150, //57
155, //58
160, //59
165, //60
170, //61
175, //62
180, //63
2, 0xbb, 0x17, // Set pre-charge voltage of color A B C
2, 0xbe, 0x05, // Set VcomH
4, 0xc1, 0x88, 0x70, 0x88, // Set contrast current for A B C
//2, 0xc7, 0x0f, // Set master contrast
2, 0xca, 0x7f, // Duty
//1, 0xaf, // Display on
0 };
const PROGMEM uint8_t OLED_init1305_128_64_1BPP_096[] =
DEV_INIT_HEADER(1305, 128, 64, 0, 1, 20, 0xaf, 0xae, 0xa4, 0xa7), // check a7
DRV_DELAY_MS, 200,
DRV_RESET_LOW,
DRV_DELAY_MS, 200,
DRV_RESET_HIGH,
DRV_DELAY_MS, 200,
1, 0xae, // turn off oled panel
2, 0xd5, 0x80, // set display clock divide ratio/oscillator frequency
2, 0xa8, 0x3f, // set multiplex ratio(1 to 64)
2, 0xd3, 0, // set display offset --- zero offset
2, 0xad, 0x8e, // Set Master Configuration
2, 0xd8, 0x14, // ... was 0x05 --Set Area Color Mode On/Off & Low Power Display Mode
2, 0x8d, 0x14, //--set Charge Pump enable/disable
2, 0xa1, 0xc8, //--set segment re-map 132 to 0
2, 0xda, 0x12, //--Set COM Pins Hardware Configuration
5, 0x91, 0x3f, 0x3f, 0x3f, 0x3f, //--Set current drive pulse width of BANK0, Color A, B and C.
2, 0x81, 0x16, //--set contrast control register
2, 0x82, 0x80, //--set contrast control register
2, 0xd9, 0xf1, //0xf1, //--set pre-charge period
2, 0xdb, 0x40, //--set vcomh
// 1, 0xa4, //Disable Entire Display On
2, 0x20, 0x00, // Horizontal increment mode - DW
// 1, 0xaf, //--turn on oled panel
0
const PROGMEM uint8_t OLED_init1305_128_64_1BPP[] =
DEV_INIT_HEADER(1305, 128, 64, 2, 1, 20, 0xaf, 0xae, 0xa4, 0xa7), // check a7
DRV_DELAY_MS, 200,
DRV_RESET_LOW,
DRV_DELAY_MS, 200,
DRV_RESET_HIGH,
DRV_DELAY_MS, 200,
2, 0xd5, 0xf0, // set display clock divide ratio/oscillator frequency
2, 0xa8, 63, // set multiplex ratio(1 to 64)
2, 0xd3, 64, // set display offset
2, 0xd8, 0x05, // ... was 0x05 --Set Area Color Mode On/Off & Low Power Display Mode
2, 0xdb, 0x34, //--set vcomh
0
128x64 1309
http://www.buydisplay.com/download/democode/ER-OLEDM024-2_Series_8080-8-bit_8080-4-bit_4-wire-spi_DemoCode.txt
const PROGMEM uint8_t OLED_init1309_128_64_1BPP[] =
DEV_INIT_HEADER(1309, 128, 64, 0, 1, 20, 0xaf, 0xae, 0xa4, 0xa7), // check a7
DRV_DELAY_MS, 200,
DRV_RESET_LOW,
DRV_DELAY_MS, 200,
DRV_RESET_HIGH,
DRV_DELAY_MS, 200,
2, 0xd5, 0xa0, // set display clock divide ratio/oscillator frequency
1, 0x40, // Set Display Start Line
2, 0xd9, 0x25, //0xf1, //--set pre-charge period
0
128x32
http://www.buydisplay.com/default/2-2-inch-128x32-oled-dot-matrix-display-module-with-pcb-blue-on-black
http://www.buydisplay.com/download/democode/ER-OLED0M23-1_8080-8-Bit_DemoCode.txt
const PROGMEM uint8_t OLED_init1305_128_32_1BPP[] =
DEV_INIT_HEADER(1305, 128, 32, 0, 1, 20, 0xaf, 0xae, 0xa4, 0xa7), // check a7
DRV_DELAY_MS, 200,
DRV_RESET_LOW,
DRV_DELAY_MS, 200,
DRV_RESET_HIGH,
DRV_DELAY_MS, 200,
2, 0xa8, 31, // set multiplex ratio(1 to 64)
2, 0xd9, 0xd2, //0xf1, //--set pre-charge period
0
256*64 - 1322
http://www.buydisplay.com/default/spi-oled-manufacturer-256x64-display-panel-supplier-green-on-black
http://www.buydisplay.com/download/democode/ER-OLEDM0.96-1_4-Wire-SPI_DemoCode.txt
const PROGMEM uint8_t OLED_init1322_256_64_4BPP[] = // tested
DEV_INIT_HEADER(1322, 256, 64, 0, 4, 40, 0xaf, 0xae, 0xa6, 0xa7), // 40Mhz
DRV_DELAY_MS, 200,
DRV_RESET_LOW,
DRV_DELAY_MS, 200,
DRV_RESET_HIGH,
DRV_DELAY_MS, 200,
2, 0xfd, 0x12,
1, 0xAE, /*DISPLAY OFF*/
2, 0xB3, 0x91,/*DISPLAYDIVIDE CLOCKRADIO/OSCILLATAR FREQUANCY*/
2, 0xCA, 0x3f, /*multiplex ratio*/
2, 0xA2, 0x00, /*set offset*/
2, 0xA1, 0x00, /*start line*/
3, 0xA0, 0x14, 0x11, /*set remap*/
2, 0xb5, 0, // new
2, 0xAB, 0x01, /*funtion selection*/
3, 0xB4, 0xA0, 0xfd,
2, 0xC7, 0x0f, /*master contrast current control*/
1, 0xB9, // default gray scale table
2, 0xB1, 0xe2, /*SET PHASE LENGTH*/
3, 0xD1, 0x82, 0x20, /**/
2, 0xBB, 0x1f, /*SET PRE-CHANGE VOLTAGE*/
2, 0xB6, 0x08, /*SET SECOND PRE-CHARGE PERIOD*/
2, 0xBE, 0x07, /* SET VCOMH */
// 1, 0xA6, /*normal display*/
// 1, 0xAF, /*display ON*/
0
