class Voice
public:
const float noteFreqs[128] = {8.176, 8.662, 9.177, 9.723, 10.301, 10.913, 11.562, 12.25, 12.978, 13.75, 14.568, 15.434, 16.352, 17.324, 18.354, 19.445, 20.602, 21.827, 23.125, 24.5, 25.957, 27.5, 29.135, 30.868, 32.703, 34.648, 36.708, 38.891, 41.203, 43.654, 46.249, 48.999, 51.913, 55, 58.27, 61.735, 65.406, 69.296, 73.416, 77.782, 82.407, 87.307, 92.499, 97.999, 103.826, 110, 116.541, 123.471, 130.813, 138.591, 146.832, 155.563, 164.814, 174.614, 184.997, 195.998, 207.652, 220, 233.082, 246.942, 261.626, 277.183, 293.665, 311.127, 329.628, 349.228, 369.994, 391.995, 415.305, 440, 466.164, 493.883, 523.251, 554.365, 587.33, 622.254, 659.255, 698.456, 739.989, 783.991, 830.609, 880, 932.328, 987.767, 1046.502, 1108.731, 1174.659, 1244.508, 1318.51, 1396.913, 1479.978, 1567.982, 1661.219, 1760, 1864.655, 1975.533, 2093.005, 2217.461, 2349.318, 2489.016, 2637.02, 2793.826, 2959.955, 3135.963, 3322.438, 3520, 3729.31, 3951.066, 4186.009, 4434.922, 4698.636, 4978.032, 5274.041, 5587.652, 5919.911, 6271.927, 6644.875, 7040, 7458.62, 7902.133, 8372.018, 8869.844, 9397.273, 9956.063, 10548.08, 11175.3, 11839.82, 12543.85};
byte note = 0;
byte isNoteOn = 0;
byte isSustain = 0;
byte oscApitchMult = 64; // set at middle
byte oscBpitchMult = 64; // set at middle
byte oscCpitchMult = 64; // set at middle
float newAmp = 0.0;
AudioSynthWaveform oscA;
AudioSynthWaveform oscB;
AudioSynthWaveform oscC;
AudioSynthWavetable waveTable;
AudioMixer4 mix;
AudioEffectEnvelope env;
AudioConnection *patchCord[5]; // total patchCordCount:5 including array typed ones.
Voice() // constructor (this is called when class-object is created)
int pci = 0; // used only for adding new patchcords
patchCord[pci++] = new AudioConnection(oscA, 0, mix, 0);
patchCord[pci++] = new AudioConnection(oscB, 0, mix, 1);
patchCord[pci++] = new AudioConnection(oscC, 0, mix, 2);
patchCord[pci++] = new AudioConnection(waveTable, 0, mix, 3);
patchCord[pci++] = new AudioConnection(mix, 0, env, 0);
void begin()
* this takes care of all the tasks that
* needs to be taken care of when doing
* a note on/off
void noteOn(byte Note, byte velocity)
float newAmp = 0.0f;
if (Note >= sizeof(noteFreqs)) return;
note = Note;
isNoteOn = 1;
newAmp = (float)velocity*(1.0f / 127.0f);
oscA.frequency(GetBendedFreq(oscApitchMult));
oscB.frequency(GetBendedFreq(oscBpitchMult));
oscC.frequency(GetBendedFreq(oscCpitchMult));
oscA.amplitude(newAmp);
oscB.amplitude(newAmp);
oscC.amplitude(newAmp);
waveTable.playNote(note, velocity);
env.noteOn();
void noteOff()
isNoteOn = 0;
if (!isSustain)
env.noteOff();
waveTable.stop();
bool isNotPlaying()
if (!env.isActive())
return true;
else if(!waveTable.isPlaying())
return true;
return false;
float GetBendedFreq(byte pitchMult)
if (pitchMult < 64)
return noteFreqs[note - 12*(64-pitchMult)];
else if (pitchMult > 64)
return noteFreqs[note + 12*(pitchMult-64)];
return noteFreqs[note];
