Hi all,
I am new to teensy but have experience in microcontroller programming on multiple platforms. I have recently started working on a project using vs code and platformIO with teensy boards. I was using teensy 3.2 first, but then decided to switch to teensy 4.1 because I expect to need more I/Os. My problem is: I can't flash a single teensy 4.1 on my system (tried 4 different ones, see below). 3.2 works fine. This is driving me crazy.
The error is always the same: the loader software does not recognize that the board is in programming mode. I am confident that my USB cable is functioning properly (it works with all other microcontrollers, including a teensy 3.2). Here is what I have done so far:
As I mentioned, I have used a teensy 3.2 before with the same setup, and it works fine. The udev-rules file is installed. To be absolutely sure, I flashed your sample blink hexfile on to that same teensy 3.2 using the same command line tool and options as above (except for --mcu=TEENSY32 of course), with the same cable, and that works fine too.
However, it seems there is something wrong with the teensy's (all of them?). This is a sample dmesg output when I plug/unplug my boards:
I understand and expect that one board could just be faulty. But I have four, which are all new, and they all show the exact same problem. What am I missing here?
Do you have any ideas what I could still try? Or what is causing the problem?
I am using an up-to-date Ubuntu 20.04 with an Intel Core i7-10875H CPU.
Best wishes,
J.
- Tried to upload a simple blink program using vs code and platformIO with the default GUI loader. The loader says it can't detect the board and I should press the programming button. I press it, the blinking LED goes off and the red indicator goes on, but the board is not detected.
- Switched to command line loader with vs code and platformIO. Same result (see output below).
- Tried every USB port of my laptop. Same result.
- Power off and power on computer, same result.
- Did 15s reset, tried to flash the board again. Same result.
- Tried four (4) different teensy 4.1 boards. Same result.
- Compiled the latest teensy_loader_cli (2.2) from source, downloaded sample blink program from pjrc.com, tried flashing on the command line. This is the output (same as before):
Code:$ ./teensy_loader_cli --mcu=TEENSY41 -v ../blink_fast_Teensy41.hex Teensy Loader, Command Line, Version 2.2 Read "../blink_fast_Teensy41.hex": 14452 bytes, 0.2% usage Unable to open device (hint: try -w option)
- If I use the -w option on the command line tool it just waits for my board forever. I can press the button as often as I like, it doesn't change anything. I tried waiting for 3 minutes, the board is still not detected.
[ 5420.076998] usb usb1-port3: attempt power cycle
[ 5420.488758] usb 1-3: new high-speed USB device number 12 using xhci_hcd
[ 5420.488932] usb 1-3: Device not responding to setup address.
[ 5420.696938] usb 1-3: Device not responding to setup address.
[ 5420.904919] usb 1-3: device not accepting address 12, error -71
[ 5421.032975] usb 1-3: new high-speed USB device number 13 using xhci_hcd
[ 5421.033150] usb 1-3: Device not responding to setup address.
[ 5421.241516] usb 1-3: Device not responding to setup address.
[ 5421.448934] usb 1-3: device not accepting address 13, error -71
[ 5421.449060] usb usb1-port3: unable to enumerate USB device
[ 5448.097185] usb 1-3: new high-speed USB device number 14 using xhci_hcd
[ 5448.224838] usb 1-3: device descriptor read/64, error -71
[ 5448.461222] usb 1-3: device descriptor read/64, error -71
[ 5448.697192] usb 1-3: new high-speed USB device number 15 using xhci_hcd
[ 5448.825220] usb 1-3: device descriptor read/64, error -71
[ 5449.061246] usb 1-3: device descriptor read/64, error -71
[ 5449.168922] usb usb1-port3: attempt power cycle
[ 5449.580880] usb 1-3: new high-speed USB device number 16 using xhci_hcd
[ 5449.581420] usb 1-3: Device not responding to setup address.
[ 5449.789111] usb 1-3: Device not responding to setup address.
Best wishes,
J.
