Results 1 to 20 of 20
Thread: Teensyduino 1.56 Beta #4
    Administrator Paul's Avatar
    Oct 2012
    428
    Here is a fourth beta test for Teensyduino 1.56.
    Linux 32 bit:
    https://www.pjrc.com/teensy/td_156-b...nstall.linux32
    Linux 64 bit:
    https://www.pjrc.com/teensy/td_156-b...nstall.linux64
    Linux ARM:
    https://www.pjrc.com/teensy/td_156-b...stall.linuxarm
    Linux ARM64:
    https://www.pjrc.com/teensy/td_156-b...l.linuxaarch64
    MacOS 10.10 to 12.x:
    https://www.pjrc.com/teensy/td_156-b...S_Catalina.zip
    MacOS 10.7 to 10.14:
    https://www.pjrc.com/teensy/td_156-b...inoInstall.dmg
    Windows:
    https://www.pjrc.com/teensy/td_156-b...inoInstall.exe
    Changes since Teensyduino 1.56-beta3:
    Support for Arduino 1.8.18
    SD faster detection of SDIO media change (KurtE)
    SdFat fix SDIO on MicroMod (mjs513)
    Fix pins 38 & 39 on MicroMod
    LittleFS improve erase+write speed for NOR flash chips
    LittleFS fix FRAM defines
    LittleFS add Write_Speed_Test example
    Fix PXP_PS_CTRL register defines
    Fix USB receive packet loss with MTP on Teensy 4
    Audio fixes for very small buffer size (Eric Fontaine)
    FreqCount fix 1st reading on Teensy 4 (mjs513)
    Teensy Loader verbose info clearer Standard vs Lockable
    26,233
    Arduino's software download page hasn't updated, but the 1.8.18 files are on their server. Like with old versions of Teensyduino, it's pretty easy to copy the URL and edit the version number if you want to download the file.
    New York
    8,146
    Just installed over TD1.56beta3 no issues. Re-ran a few MTP/LFS quick tests on flash speed-up and File transfer and all is working at least so far
    10,350
    Looks like 18 is now released!
    26,233
    Looks like they got rid of the donation request and the links just download the file now. Or maybe it's just my browser or ad blocking?
    New York
    8,146
    Think depends which link you wind up using, just now got the donation page but earlier when I checked went right to download without the donation page.
    Anyways - installed 1.1.18 and beta4 without issue. Reran a couple of the MTP/LFS tests and all seems well for now.
    10,350
    It took me a couple of attempts to install the zip file...
    Norton decided to remove arduino.exe and arduino_debug.exe... tried to restore and system not happy, so deleted, rebooted, and then unziped again...
    This time went through... Also needed to update my norton to exclude ...
    15,889
    Downloaded so far ...
    Paul, you missed this interesting trivia:
    Support the Arduino IDE
    Since the release 1.x release in March 2015, the Arduino IDE has been downloaded 57,348,600 times — impressive! Help its development with a donation.
    26,233
    Looks like Arduino's donation request is back. Or whatever happened with my browser & ad blocking isn't happening anymore.
    15,889
    IDE 1.8.18 installed(unzipped) and TD 1.56b4 on top of it: okay - not run yet
    Ide 1.8.16 (current) beta 4 won't install because teensy_serialmon.exe is active, and TaskMan cannot terminate this task ??? > 'End Task' requests are ignored.
    > machine been up 8 days, there is a pending restart for updates so will do that.
    Question: What is the state of FS/MTP inclusions and what current libs from github are needed ?
    ANSWER HERE :: Teensyduino-File-System-Integration-including-MTP-and-MSC
    Oct 2019
    285
    Quote Originally Posted by Paul View Post
    If I may ask, what was the issue with these pins on the MM?
    15,889
    Quote Originally Posted by Rezo View Post
    See here : github.com/PaulStoffregen/cores :: Fix pin 38 & 39 on MicroMod for PWM & Serial5
    Internal ref address for those pin features were swapped
    26,233
    The definitions were swapped, so if you used digitalWrite, digitalRead, analogWrite on pin 38, it would actually control pin 39, and vise versa. For Serial5.setTX and Serial5.setRX, you had to use the other pin number, not the pin actually controlled.
    However, the definitions were correct for SDIO, so if you connect a SD card as Sparkfun's documentation shows and use SD.begin(BUILTIN_SDCARD), that has always worked properly. Initially most of the software testing with those pins focused on their main usage for high speed access to a SD card.
    Installed 1.8.18 and TD 1.56 B4 and ran test sketch on FreqCount fix. Looks good.
    15,889
    Using unzipped IDE 1.8.18 and TD 1.56 b4 T_4.1 sketch works with that fresh install.
    > only Win 11 secure complaints were unzipped Arduino.exe (wanted to block, not usually seen?) and the typical 'JAVA' approve access on first run.
    Also a couple of sketches of T_MM (new lockable Beta board: unlocked): Blink, USB-speed-print-test, MTP-test (more on MTP/FS thread)
    RE p#10 - TD install okay after restart - but [unrelated] that involved failed Win update three times and Run of release Win 11 Setup.exe to current update - overwriting original summer beta Win11 series of WIP upgrades.
    Nov 2020
    3
    i use a new clean install of IDE1.8.18 and 1.56b4
    my serial monitor size got resized, and i cant save another window size, its always like before.
    15,889
    Quote Originally Posted by Barst View Post
    On Windows? Using that the CTRL+rolling scroll wheel changes textsize.
    But as far as initial size and placement that seems to repeat restoring where it wants, not where last used.
    There is a Serial entry giving screen coords/size in some fasion - the numbers here don't make sense, maybe they are documented and with IDE closed changing that will put it in the desired place and size.
    Nov 2020
    3
    ah yes on Win64
    i fixed it by myself:
    1. tools > port > serial port
    2. then resive/reposition the window and close
    3. tools > port > teensy port
    4. now it is always saved at this size/position
    15,889
    ah yes on Win64
    Congrats! Good to know. Apparently the Teensy SerMon bypasses the save to preferences.txt that IDE SerMon does.
    New York
    8,146
    @PaulStoffregen
    Was playing with the lockable TMM so decided just to start with writing the fuses and that worked without a problem. Thought the following was good to see the status of encryption:
    TMM with Blink Sketch loaded:
    09:09:12.491 (ports 5): usb_add: usb:0/140000/0/2/1  hid#vid_16c0&pid_0478 (Teensy MicroMod) Bootloader
    09:09:12.586 (loader): remote cmd from 1432: "status"
    09:09:12.589 (loader): secure mode can be locked: this is Lockable Teensy
    09:09:12.589 (loader): encryption is possible on this Teensy, but not yet configured
    09:09:12.589 (loader): Device came online, code_size = 16515072
    09:09:12.589 (loader): Board is: Teensy MicroMod (IMXRT1062), version 1.07
    09:09:12.598 (loader): File "C:\Users\Merli\AppData\Local\Temp\arduino_build_347683\Blink.pde.hex", 20480 bytes
    09:09:12.601 (loader): File "C:\Users\Merli\AppData\Local\Temp\arduino_build_347683\Blink.pde.ehex", 20480 bytes, and 5152 loader utility
    09:09:12.601 (loader): ehex is valid, key hash: 3CD8795F ############################################################
    09:09:12.601 (loader): File "Blink.pde.hex". 20480 bytes, 0% used
    09:09:12.604 (loader): set background IMG_ONLINE
    09:09:12.612 (loader): File "C:\Users\Merli\AppData\Local\Temp\arduino_build_347683\Blink.pde.hex", 20480 bytes
    09:09:12.615 (loader): File "C:\Users\Merli\AppData\Local\Temp\arduino_build_347683\Blink.pde.ehex", 20480 bytes, and 5152 loader utility
    09:09:12.615 (loader): ehex is valid, key hash: 3CD8795F 9A168642 4FCF82ED AFC620F1 BCFECAB3 B978FA67 0D47FE2D F09253DD
    09:09:12.615 (loader): File "Blink.pde.hex". 20480 bytes, 0% used
    09:09:12.618 (loader): elf appears to be for Teensy MicroMod (IMXRT1062) (16515072 bytes)
    09:09:12.618 (loader): elf binary data matches hex file
    09:09:12.618 (loader): elf file is for Teensy MicroMod (IMXRT1062)
    09:09:12.618 (loader): using hex file - Teensy not configured for encryption
    Running the Fuse Write Sketch:
    Writing public key hash
    Okay: public key hash is good :-)
    Writing decryption key
    Okay: key written, setting config
    Testing Bus Encryption Engine
    Success: ciphertext decryption test passed :-)
    Notice: JTAG is still enabled
    Notice: Secure mode is not yet set, unencrypted
            programs are still allowed to run
    Now when loading Blink Sketch
    09:16:34.367 (loader): Board is: Teensy MicroMod (IMXRT1062), version 1.07
    09:16:34.377 (loader): File "C:\Users\Merli\AppData\Local\Temp\arduino_build_347683\Blink.pde.hex", 20480 bytes
    09:16:34.380 (loader): File "C:\Users\Merli\AppData\Local\Temp\arduino_build_347683\Blink.pde.ehex", 20480 bytes, and 5152 loader utility
    09:16:34.380 (loader): ehex is valid, key hash: 3CD8795F ########################################################
    09:16:34.380 (loader): File "Blink.pde.hex". 20480 bytes, 0% used
    09:16:34.380 (loader): File "Blink.pde.hex" opened, but "Blink.pde.ehex" will actually be used
    09:16:34.407 (loader): elf appears to be for Teensy MicroMod (IMXRT1062) (16515072 bytes)
    09:16:34.407 (loader): elf binary data matches hex file
    09:16:34.407 (loader): elf file is for Teensy MicroMod (IMXRT1062)
    09:16:34.407 (loader): using encrypted ehex (optional - secure mode not yet locked)
    In both cases you see that the hex and ehex is created but before writing fuses the hex file is used after its uses the ehex. In addition the loader shows that prior to setting the fuses that the Teensy is not configured for encyption and similarly afterwards it shows that the Teensy is not configured for encyption. So pretty nice it shows you the status of encryption.
