Page 1 of 2 1 2 LastLast
Results 1 to 25 of 27
Thread: Teensyduino 1.56 Beta #6
    Administrator Paul's Avatar
    Oct 2012
    428
    Here is a sixth beta test for Teensyduino 1.56.
    This beta is meant to be the final release candidate for 1.56.
    Linux 32 bit:
    https://www.pjrc.com/teensy/td_156-b...nstall.linux32
    Linux 64 bit:
    https://www.pjrc.com/teensy/td_156-b...nstall.linux64
    Linux ARM:
    https://www.pjrc.com/teensy/td_156-b...stall.linuxarm
    Linux ARM64:
    https://www.pjrc.com/teensy/td_156-b...l.linuxaarch64
    MacOS 10.10 to 12.x:
    https://www.pjrc.com/teensy/td_156-b...S_Catalina.zip
    MacOS 10.7 to 10.14:
    https://www.pjrc.com/teensy/td_156-b...inoInstall.dmg
    Windows:
    https://www.pjrc.com/teensy/td_156-b...inoInstall.exe
    Changes since Teensyduino 1.56-beta5:
    Fix SD example SdFat_Usage on Teensy 2.0
    Fix SdFat example BackwardCompatibility on Teensy 2.0
    SoftwareSerial add bool operator
    Fix SD src-utility conflict when installed on top of 1.53 with Arduino 1.8.5-1.8.9
    Audio fix compiler errors & warnings with Teensy LC
    Audio Fix MidiSynthKeyboard example on Teensy 4
    Audio async spdif example to compile on all boards
    ILI9488_t3 fix compile errors in examples (KurtE)
    ILI9488_t3 better document examples (mjs513)
    LittleFS fix RAM Test_Integrity on Teensy 3.5 & 3.6 (Defragster)
    LittleFS add Cypress and Fuji 2MBit FRAM support (KurtE)
    MIDI fix DualMerger example
    Fix Snooze hibernate/sd_datalogger example
    15,890
    Still First?
    TD 1.56b6 on IDE 1.8.19 installed good and proper.
    A couple of sketches on T_3.6 and T_4.1 upload in the great PJRC Teensy way.
    Mar 2017
    Oakland, CA, USA
    467
    15,890
    Quote Originally Posted by shawn View Post
    The web shows this : cplusplus.com/reference/cstdarg/va_end/:
    void va_end (va_list ap);
    End using variable argument list
    Performs the appropriate actions to facilitate a normal return by a function that has used the va_list object ap to retrieve its additional arguments.
    This macro should be invoked before the function returns whenever va_start has been invoked from that function.
    And the linked code does use va_start(ap, format);
    Also: The C library macro void va_end(va_list ap) allows a function with variable arguments which used the va_start macro to return. If va_end is not called before returning from the function, the result is undefined.
    New York
    8,146
    Updated over previous beta - tested examples Using the Fuse written Lockabel TMM from
    1. FastLED
    2. ILI9341
    3. Entropy
    4. FastCRC
    5. ILI9488
    Some non TD Libraries
    1. Adafruit GFX demo
    2. EloquentTinyML
    3. Bill G's ChiRT (chibos)
    4. EigenTest sketch
    Only issue is my TeensyOpenGL (this is my OpenGL lib) seems to hang the Teensy Micromod board - yellow light flashes 7 times ) which I have to see whats causing the problem in the sketch.
    Also the testing FS with MTP, ie., SD, LittleFS, etc.
    26,233
    I tested Ethernet Webclient with W5500 on Teensy 4.0 and Teensy 3.6, WavFilePlayer on Teensy 4.0 with rev D audio shield and Teensy 3.2 with rev C audio, and HM01B0 testv3 on MicroMod. So far all looking good.
    Then I noticed we might have a problem with SD listfiles. When I run it with BUILTIN_SDCARD, all 5 files on my card print, but it never gets to "done!" and reboots after several seconds. Same on Teensy 3.6, but hangs. But it works fine with SPI.
    Running SD listfiles from 1.55 seems to work.
    Is anyone else able to reproduce this SD listfiles issue?
    New York
    8,146
    Ran it with @KurtE's SD version with the sdCard CS pin function and it worked with 1.56beta6. Reloaded the stock version installed with beta6 and still seems to be working on a T4.1:
    Initializing SD card...initialization done.
    MemoryHexDump_git/
      .gitattributes                                   68    08:42  December 17, 2021
      .gitignore                                       32    08:42  December 17, 2021
      examples/
        memdump/
          memdump.ino                                1100    08:42  December 17, 2021
        SDFileDump/
          SDFileDump.ino                             4586    08:42  December 17, 2021
      keywords.txt                                     24    08:42  December 17, 2021
      library.properties                              295    08:42  December 17, 2021
      LICENSE                                        1083    08:42  December 17, 2021
      README.md                                      3157    08:42  December 17, 2021
      src/
        MemoryHexDump.cpp                            3882    08:42  December 17, 2021
        MemoryHexDump.h                               550    08:42  December 17, 2021
    222/
      aaa.txt                                         256    20:40  December 17, 2021
      bbb.txt                                         512    20:40  December 17, 2021
      ccc.txt                                         768    20:40  December 17, 2021
    333/
    111/
    done!
    Tried a Teensy Micromod and showed same list - I just moved the card over that I tested with on the T4.1
    26,233
    Looks like it's crashing with the specific card I had in the SDIO socket. When I move the card to SPI, same crash.
    New York
    8,146
    Well guess that good news - at least its not the library
    26,233
    The MTP index file is causing the problem. Looks like we end up with DateTimeFields having an invalid month. This fix prevents the crash.
    https://github.com/PaulStoffregen/SD...70c17f755f96ed
    Should probably dig deeper and look at why we're returning an invalid date.
    SDTEST1.WAV                                  16787550    09:00  September 24, 2021
    SDTEST2.WAV                                  16425698    09:00  September 24, 2021
    SDTEST3.WAV                                  13617358    09:00  September 24, 2021
    SDTEST4.WAV                                  17173152    09:00  September 24, 2021
    mtpindex.dat                                        0    00:00  ??? 0, 1980
    done!
    10,350
    Was going to post worked on MMOD running using SD and SD out of my libraries folder, but I synced them both up to what is up on github (main branches)
    Might be interesting with your disk to take to pc and see if they complain about the validity of the disk...
    222/
      aaa.txt                                         256    17:18  December 17, 2021
      bbb.txt                                         512    17:18  December 17, 2021
      ccc.txt                                         768    17:18  December 17, 2021
    333/
    111/
    done!
    New York
    8,146
    Agree. Been setting the sketch up to put the index file in flash or ram like @KurtE as set up so have seen that error
    Have been testing the MM with the ILI9341 display with Kris Kasprzak Graph function library and testing the Quad encoder and all seems to be working.
    10,350
    Will take a look at the index file... I have avoided the index file on SD for awhile as there are issues with index files on removable media, like what happens if there is no disk... Or the disk is read only or...
    Need to add more fallback code in to allow it then either move to different storage or make a limited index in memory...
    New York
    8,146
    The index in memory seems to working out as the best option so far but never tested on other than T3.6, T4x and TMM. So probably a good approach.
    10,350
    I ran the Simple mtp_teensy sketch commented out making ram drive, so index created on SD... I walked the directories and did a 1 command and a list... Note first time I faulted, as I have not updated this sketch to default which storage the commands are talking to (2 command) and so it walks off using null pointer.
    Dump Storage list(2)
    store:0 storage:10001 name:SD_Card fs:20005724
    store:1 storage:20001 name:Program fs:20005db4
    Dump Index List
    0: 0 1 1 -1 0 23 0 0 /
    1: 1 1 0 -1 0 0 0 0 /
    20: 0 1 1 0 0 29 1639892384 1639892384 222
    21: 0 1 1 0 20 32 1639892388 1639892388 333
    22: 0 1 1 0 21 26 1639892392 1639892392 111
    23: 0 0 0 0 22 0 1640152166 928540800 mtpindex.dat
    24: 0 0 0 22 0 256 1639892394 1639761498 aaa.txt
    25: 0 0 0 22 24 512 1639892394 1639761498 bbb.txt
    26: 0 0 0 22 25 768 1639892396 1639761498 ccc.txt
    27: 0 0 0 20 0 256 1639892384 1639761498 aaa.txt
    28: 0 0 0 20 27 512 1639892386 1639761498 bbb.txt
    29: 0 0 0 20 28 768 1639892386 1639761498 ccc.txt
    30: 0 0 0 21 0 256 1639892388 1639761498 aaa.txt
    31: 0 0 0 21 30 512 1639892390 1639761498 bbb.txt
    32: 0 0 0 21 31 768 1639892392 1639761498 ccc.txt
     Space Used = 491520
    Filesystem Size = 31902400512
    Directory
    222/
      aaa.txt                             256
      bbb.txt                             512
      ccc.txt                             768
    333/
      aaa.txt                             256
      bbb.txt                             512
      ccc.txt                             768
    111/
      aaa.txt                             256
      bbb.txt                             512
      ccc.txt                             768
    mtpindex.dat                          0
    You will notice the index file has strange looking modify date(928540800)... Maybe because the file stays open... Will now reprogram to the SD List...
    Edit: the SD list now does walk off deep end and fault/reset...
    CrashReport:
      A problem occurred at (system time) 6:17:7
      Code was executing from address 0xA90
      CFSR: 8200
    	(PRECISERR) Data bus error(address in BFAR)
    	(BFARVALID) Accessed Address: 0x200702A4
      Temperature inside the chip was 40.56 C
      Startup CPU clock speed is 600MHz
      Reboot was caused by auto reboot after fault or bad interrupt detected
    222/
      aaa.txt                                         256    (17 18 18 32 121 11 17):17:18  December 17, 2021
      bbb.txt                                         512    (17 18 18 32 121 11 17):17:18  December 17, 2021
      ccc.txt                                         768    (17 18 18 32 121 11 17):17:18  December 17, 2021
    333/
    111/
    mtpindex.dat                                        0    (0 0 0 32 80 255 0):00:00
    This is with:
       Serial.printf("(%u %u %u %u %u %u %u):", tm.hour, tm.min, tm.sec, tm.wday, tm.year, tm.mon, tm.mday);
      Serial.flush();
    Need to look at how these numbers translate. That is did SD return 0...
    New York
    8,146
    @KurtE
    Looking at Storage.cpp not sure we ever do a UpdateDates call to set a create/modify dates for the index file:
    10,350
    Follow on:
    From SDFile class:
    	virtual bool getModifyTime(DateTimeFields &tm) {
    		uint16_t fat_date, fat_time;
    		if (!sdfatfile.getModifyDateTime(&fat_date, &fat_time)) return false;
    		tm.sec = FS_SECOND(fat_time);
    		tm.min = FS_MINUTE(fat_time);
    		tm.hour = FS_HOUR(fat_time);
    		tm.mday = FS_DAY(fat_date);
    		tm.mon = FS_MONTH(fat_date) - 1;
    		tm.year = FS_YEAR(fat_date) - 1900;
    		return true;
    So with the data printed above: mtpindex.dat 0 (0 0 0 32 80 255 0):00:00
    FS_YEAR returned 1980...
    static inline uint16_t FS_YEAR(uint16_t fatDate) {
      return 1980 + (fatDate >> 9);
    So the file did not have a date/time... i.e. 0.
    Likewise Month:
    static inline uint8_t FS_MONTH(uint16_t fatDate) {
      return (fatDate >> 5) & 0XF;
    Returned 0 and we subtracted 1 so we get the 255...
    We probably should detect this and print no date...
    New York
    8,146
    not a bad idea.
    10,350
    @KurtE
    I don't think we should be....
    That is for normal local files, the file system is in charge of setting dates and times. We should only manually update the dates if we receive a file from the host and the host says
    the dates should be xyz...
    I think the main issue is the file is never closed and the FS probably updates this on closure. So value is 0...
    New York
    8,146
    Yep -dates are updated on file close so if its never closed then dates will never be updated.
    10,350
    Here is a modified version of:
    void printTime(const DateTimeFields tm) {
      const char *months[12] = {
        "January", "February", "March", "April", "May", "June",
        "July", "August", "September", "October", "November", "December"
      //Serial.printf("(%u %u %u %u %u %u %u):", tm.hour, tm.min, tm.sec, tm.wday, tm.year, tm.mon, tm.mday);
      //Serial.flush();
      // Check for year 1980 and invalid month as indicator that the file did not have a date/time stamp
      if ((tm.year == 80) && (tm.mon == 255)) {
        Serial.print("<No Modify date>");
        if (tm.hour < 10) Serial.print('0');
        Serial.print(tm.hour);
        Serial.print(':');
        if (tm.min < 10) Serial.print('0');
        Serial.print(tm.min);
        Serial.print("  ");
        Serial.print(months[tm.mon]);
        Serial.print(" ");
        Serial.print(tm.mday);
        Serial.print(", ");
        Serial.print(tm.year + 1900);
    222/
    333/
    111/
    mtpindex.dat                                        0    <No Modify date>
    done!
    10,350
    Looks like we have the same code in 3 different sketches, this one as well as the two in LittleFS(ListFiles and LittleFS_Program_Simple_Datalogger-dates)
    Edit: but this may be specific to SD as of their differences in date/time storage
    10,350
    @Paul @mjs513, could fix in the example as I showed above.
    Or maybe better: in SD.h
    	virtual bool getCreateTime(DateTimeFields &tm) {
    		if (!sdfatfile.getCreateDateTime(&fat_date, &fat_time)) return false;
    		if ((fat_date == 0) && (fat_time == 0)) return false;
    		return true;
    		return true;
    Note I added the lines: if ((fat_date == 0) && (fat_time == 0)) return false;
    222/
    333/
    111/
    mtpindex.dat                                        0
    done!
    This feels cleaner to me... So did PR
    https://github.com/PaulStoffregen/SD/pull/39
    Jun 2016
    Rennes France
    42
    Hello. I have upgraded my project to Arduino 1.8.19 because Log4J problem, and I upgrade Teensyduino to 1.56 Beta6. And now when I compile my project using this https://github.com/wwatson4506/UsbMscFat library, I obtain this error:
    C:\Users\bobiller\Documents\Arduino\libraries\UsbM scFat-UsbMscFat\src\PFsLib\PFsExFatFormatter.cpp: In member function 'bool PFsExFatFormatter::format(PFsVolume&, uint8_t*, print_t*)':
    C:\Users\bobiller\Documents\Arduino\libraries\UsbM scFat-UsbMscFat\src\PFsLib\PFsExFatFormatter.cpp:105:5: error: 'DBG_FAIL_MACRO' was not declared in this scope
    DBG_FAIL_MACRO;
    Before with 1.8.15 and Teensy 1.55 there isn't this error.
    9,756
    Is CDC fixed?
