I am in the process of laying out a PCB which will have a Teensy 4.1 on it. My question is should I, or should I not, connect to all the GND pins? On my PCB there will be a ground plane, so I would think it would be a good idea, and not create ground loops. Maybe I'm wrong?
Taking this a step further, when using any of the Teensys on hand soldered proto-boards, which I do a fair amount, my question is the same; is it a good or bad idea to connect the GND in multiple places on the Teensys? I have always kept it to one GND connection, but is that correct procedure?
C.
C.
