frankzappa
I learned some programming in C++ and I've started working on a project. I have difficulties getting started with the coding because of some problems with structuring the program.
I have 10 sensors that I need to read and do some filtering and whatnot. How do I avoid having to add a number to the variable name to differentiate the different operations? Right now I have 10 of everything which is stupid.
For example I have some filters that I put in classes, as an example below a high pass and a low pass filter in two classes:
So lets say I'm reading the sensors in the main loop and I do the following when I need to filter the signal:
So I send the sensor value to the filter class to do the filtering and I get back the filtered value.
This is stupid because I need to copy that code 10 times and then change the 00 to 01, 02, 03 etc. I also need 10 each of those filter classes.
Any suggestions on how to structure the program to avoid this? Is there somewhere I can look at some small real world projects that are simple enough for a noob to understand? A program on how to calculate the mean value or something like that is not helping which is all I can find
Oh and no need to suggest I can use a band pass filter in stead, this is just an example.
class HP_peakTrack //HP bessel 1st order 150Hz
public:
HP_peakTrack()
v[0]=v[1]=0.0;
private:
double v[2];
public:
double filter(double x) //class II
v[0] = v[1];
v[1] = (9.906629452463440177e-1 * x)
+ (0.98132589049268825754 * v[0]);
return
(v[1] - v[0]);
class LP_peakTrack //2nd order LP Butterworth 1000Hz
public:
LP_peakTrack()
v[0]=0.0;
v[1]=0.0;
v[2]=0.0;
private:
double v[3];
public:
v[0] = v[1];
v[1] = v[2];
v[2] = (3.621681514928615665e-3 * x)
+ (-0.83718165125602272969 * v[0])
+ (1.82269492519630826877 * v[1]);
return
(v[0] + v[2])
+2 * v[1];
double peakSignal00 = HP_peakTrack00.filter(g_sensorValue[0]);
peakSignal00 = LP_peakTrack00.filter(peakSignal00);
