Generating pulses
Cr2O7
Hi!
I am currently working on project aiming at connecting fuel meters, etc to the NMEA2000-network in my boat.
A part of the work is to create a simulator for the devices on the boat. My first task is to emulate the flow meters.
They transmit pulses of which is proportional to the volume of fuel passed. The boat is equipped with two diesel engines,
so four meters are needed.
The current setup is two Teensy chips (4.0 and 4.1), of which the 4.0 is acting as simulator.
I've programmed this as four threads acting on four pins, one for each flow meter. My intention was to be able to
pulse rates between 20 - 100 Hz.However, some problem appears...
When the following rates are used, it works nicely:
Pin #2 50 Hz
Pin #3 25 Hz
Pin #5 50 Hz
Pin #6 25 Hz
The scope reports: 45 Hz and 22 Hz, which is not dead on, but reasonable for my purpose. (See attachment. The frequency is shown in the bottom left hand corner.)
However, when I run it with the following:
Pin #2 80 Hz
Pin #3 25 Hz
Pin #5 50 Hz
Pin #6 25 Hz
I get the same 45 Hz output and I am surprised. I would have anticipated something around 90 Hz here.
Am I doing something wrong, if so please enlighten me.
Rgds,
Göran
#include "JeevesIISimulatorNMEA2000.h"
  Function name:
  Description:
  Parameters:
  Return:
  Written by:     Göran Andersson
  Date:           2021-MM-DD
  Version history
  First issue ver 1.0
  	TODO
		+	Separate the start of pulse generating threds, so maybe better performance can be acheived?
bool TraceFlag   = true,
     TraceFlag2  = false,
     SyncTimePC  = true,
     TestOnly    = true,
     FuncTest    = false;
// Containing all data we need for the threads.
ThreadsDef_t FlowmeterThread[NbrOfThreads];
  if(TraceFlag
     TraceFlag2)
    while(!Serial)
       delay(10);
    delay(2000);
    Serial.println("Buuu");
    Serial.print("FlowmeterHz: ");
    Serial.println(FlowmeterHz);
  Initialise();
  Function name:   BBPrimaryFlowMeter
  Description:
  Parameters:
  Return:          None
  Date:           2021-12-20
  Version history
  First issue ver 1.0
void BBPrimaryFlowMeter(void)
 int State = HIGH;
 threads.delay(ThreadStartDelay + 13);
	while(Forever)
		digitalWriteFast(PrimaryBBFlowmeterPin, State);
		State = (~State) & StateMask;
    if(DelayTimeBBPrimary < 30)
      threads.delay_us((1000*DelayTimeBBPrimary) >> 1);
     threads.delay(DelayTimeBBPrimary >> 1);
  Function name:   BBReturnFlowMeter
  Description:
  Parameters:
  Return:          None
  Date:           2021-12-20
  Version history
  First issue ver 1.0
void BBReturnFlowMeter(void)
 int State = HIGH;
 threads.delay(ThreadStartDelay + 7);
	while(Forever)
		digitalWriteFast(ReturnBBFlowmeterPin, State);
    if(DelayTimeBBReturn < 30)
      threads.delay_us((1000*DelayTimeBBReturn) >> 1);
     threads.delay(DelayTimeBBReturn >> 1);
  Function name:   SBPrimaryFlowMeter
  Description:
  Parameters:
  Return:          None
  Date:           2021-12-20
  Version history
  First issue ver 1.0
void SBPrimaryFlowMeter(void)
	int State = HIGH;
  threads.delay(ThreadStartDelay + 5);
	while(Forever)
		digitalWriteFast(PrimarySBFlowmeterPin, State);
    if(DelayTimeSBPrimary < 30)
      threads.delay_us((1000*DelayTimeSBPrimary) >> 1);
     threads.delay(DelayTimeSBPrimary >> 1);
  Function name:   SBReturnFlowMeter
  Description:
  Parameters:
  Return:          None
  Date:           2021-12-20
  Version history
  First issue ver 1.0
void SBReturnFlowMeter(void)
	int State = HIGH;
  threads.delay(ThreadStartDelay + 3);
	while(Forever)
		digitalWriteFast(ReturnSBFlowmeterPin, State);
    if(DelayTimeSBReturn < 30)
      threads.delay_us((1000*DelayTimeSBReturn) >> 1);
     threads.delay(DelayTimeSBReturn >> 1);
  Function name:   Initialise
  Description:
  Parameters:
  Return:          None
  Date:           2021-12-20
  Version history
  First issue ver 1.0
void Initialise(void)
	ThreadIdx_t ThreadIdx;
  FlowmeterThread[BBPrimaryThread]  = {
                                             	BBPrimaryFlowMeter,
                                             	"BBPrimaryFlowMeter",
                                             	ThreadFailed
  FlowmeterThread[BBReturnThread]  = {
                                             	BBReturnFlowMeter,
                                             	"BBReturnFlowMeter",
                                             	ThreadFailed
  FlowmeterThread[SBPrimaryThread]  = {
                                             	SBPrimaryFlowMeter,
                                             	"SBPrimaryFlowMeter",
                                             	ThreadFailed
  FlowmeterThread[SBReturnThread]  = {
                                             	SBReturnFlowMeter,
                                             	"SBReturnFlowMeter",
                                             	ThreadFailed
  pinMode(PrimaryBBFlowmeterPin, OUTPUT);
  pinMode(PrimarySBFlowmeterPin, OUTPUT);
  pinMode(ReturnSBFlowmeterPin, OUTPUT);
  pinMode(ReturnBBFlowmeterPin, OUTPUT);
  StartFlowmeterThreads();
  Function name:    AddFlowmeterThread
  Description:      The function starts a thread that is defined in the control structure 'FlowmeterThread'.
                    The outcome is sent the 'Serial' interface.
  Parameters:       ThreadIdx   An index of the 'FlowmeterThread' array
  Return:           None
  Date:             2021-12-20
  Version history
  First issue ver 1.0
void AddFlowmeterThread(ThreadIdx_t ThreadIdx)
  int TmpThreadID = threads.addThread(FlowmeterThread[ThreadIdx].Tread_F);
  if(TraceFlag)
    Serial.println("####### Entry AddFlowmeterThread #######");
//    Serial.println(TmpThreadID);
//    Serial.println(JeevesIIThread[ThreadIdx].ThreadName);
  if(TmpThreadID == ThreadFailed)
    if(TraceFlag)
      Serial.print("Failed creating thread: ");
      Serial.print(FlowmeterThread[ThreadIdx].ThreadName);
      Serial.println("! Harakiri...");
    exit(1);
    if(TraceFlag)
      Serial.print("Created thread: ");
      Serial.println(FlowmeterThread[ThreadIdx].ThreadName);
      Serial.print("  Thread state: ");
      Serial.println(threads.getState(TmpThreadID));
      Serial.print("  Thread ID: ");
  FlowmeterThread[ThreadIdx].ThreadID = TmpThreadID;
  if(TraceFlag)
    Serial.println("####### Exit AddFlowmeterThread #######");
  Function name:    StartFlowmeterThreads
  Description:      The function starts all the threads
  Parameters:       None
  Return:           None
  Date:             2021-12-20
  Version history
  First issue ver 1.0
void StartFlowmeterThreads(void)
	ThreadIdx_t ThreadIdx = FirstThread;
  while(ThreadIdx < NbrOfThreads)
    AddFlowmeterThread(ThreadIdx);
    ThreadIdx = ThreadIdx_t (ThreadIdx + 1);
#include <strings.h>
//#include <stdint.h>
#include <TeensyThreads.h>
#ifndef _JEEVESII_SIMULATOR_NMEA2000_H
#define _JEEVESII_SIMULATOR_NMEA2000_H
#define MaxTicks              											4294967295 // + 1 -> 0
#define PrimaryBBFlowmeterPin 											2
#define ReturnBBFlowmeterPin  											3
#define PrimarySBFlowmeterPin 											5
#define ReturnSBFlowmeterPin  											6
#define ThreadFailed            										-1
#define FlowmeterHz                                 50  // 83 OK, but not 84!    						 // Hz
// Pulse period
#define DelayTimeBBPrimary                          20 //10      // ms
#define DelayTimeBBReturn                           40       // ms
#define DelayTimeSBPrimary                          20       // ms
#define DelayTimeSBReturn                           40       // ms
#define ThreadStartDelay                            1000
#define StateMask                                   1
typedef enum
	FirstThread, BBPrimaryThread = FirstThread, BBReturnThread, SBPrimaryThread, SBReturnThread, NbrOfThreads
}ThreadIdx_t;
typedef struct ThreadsDef
	ThreadFunctionNone Tread_F;
	char *ThreadName;
	int  ThreadID;
}ThreadsDef_t;
void BBPrimaryFlowMeter(void);
void BBReturnFlowMeter(void);
void SBPrimaryFlowMeter(void);
void SBReturnFlowMeter(void);
void AddFlowmeterThread(ThreadIdx_t ThreadIdx);
void StartFlowmeterThreads(void);
void Initialise(void);
static bool Forever = true;
// #include "JeevesIINMEA2000.h"
I don't know anything about your threading library, but if you only need to generate a few frequencies on pins you can do this:
include "Arduino.h"
    analogWriteFrequency(1, 80);  // 80Hz on pin 1
    analogWrite(1, 128);          // 50% duty cycle
    analogWriteFrequency(3, 25);
    analogWrite(3, 128);
    analogWriteFrequency(5, 50);
    analogWrite(5, 128);
    analogWriteFrequency(6, 25);
    analogWrite(6, 128);
void loop(){
Please note that a few pins share the same PWM timer, e.g. pin 2 and pin 3. You need to make sure that your pins don't share the same timers. I therefore changed you pin2 to pin1. You can find out which pins share the same timer here https://www.pjrc.com/teensy/td_pulse.html Scroll down to the PWM Frequency table.
