Results 1 to 6 of 6
Thread: how to track filter frequency with midi note (keyboard tracking) ?
    Dec 2018
    186
    I try to find the correct formula to map the frequency of a filter with the note played on a keyboard. I first thought that was easy... but I am not happy with what I have tried so far. My approach is very simple :
    Freq(filter) = Freq(note) * k
    But it doesn't work. For instance when I set k = 2 with a low pass filter, the low pitch notes are filtered much more than the high pitch ones. I try to find a formula to get an even effect for low and high pitch notes but I can't find.
    If some of you could point me to articles or ressources that explain this subject, I would appreciate.
    Emmanuel
    Jul 2020
    1,748
    Can you post the actual code involved?
    Senior Member oddson's Avatar
    Feb 2013
    Isle in the Salish Sea
    1,414
    Typically when a filter cutoff is modulated by pitch it's normalized relative to one half the sample rate and then some parameter for slope. You might also want an offset to move the cutoff from the fundamental.
    Feb 2013
    1,414
    Sorry... I don't really know the audio library and I didn't read your post carefully.
    Dec 2018
    186
    Here is a simple test code to demonstrate the problem.
    My issue is getting an even filtering "impact" from low to high pitch notes.
    MY guess :
    - less filtering for lower pitch notes.
    - more filtering for high pitch range.
    Emmanuel
    AudioSynthWaveformModulated waveformMod1;   //xy=371,328
    AudioFilterStateVariable filter1;        //xy=601,332
    AudioEffectEnvelope      envelope1;      //xy=796,337
    AudioOutputI2S           i2s1;           //xy=963,339
    AudioConnection          patchCord1(waveformMod1, 0, filter1, 0);
    AudioConnection          patchCord2(filter1, 0, envelope1, 0);
    AudioConnection          patchCord3(envelope1, 0, i2s1, 0);
    AudioConnection          patchCord4(envelope1, 0, i2s1, 1);
    const float noteFreqs[128] = {8.176, 8.662, 9.177, 9.723, 10.301, 10.913, 11.562, 12.25, 12.978, 13.75, 14.568, 15.434, 16.352, 17.324, 18.354, 19.445, 20.602, 21.827, 23.125, 24.5, 25.957, 27.5, 29.135, 30.868, 32.703, 34.648, 36.708, 38.891, 41.203, 43.654, 46.249, 48.999, 51.913, 55, 58.27, 61.735, 65.406, 69.296, 73.416, 77.782, 82.407, 87.307, 92.499, 97.999, 103.826, 110, 116.541, 123.471, 130.813, 138.591, 146.832, 155.563, 164.814, 174.614, 184.997, 195.998, 207.652, 220, 233.082, 246.942, 261.626, 277.183, 293.665, 311.127, 329.628, 349.228, 369.994, 391.995, 415.305, 440, 466.164, 493.883, 523.251, 554.365, 587.33, 622.254, 659.255, 698.456, 739.989, 783.991, 830.609, 880, 932.328, 987.767, 1046.502, 1108.731, 1174.659, 1244.508, 1318.51, 1396.913, 1479.978, 1567.982, 1661.219, 1760, 1864.655, 1975.533, 2093.005, 2217.461, 2349.318, 2489.016, 2637.02, 2793.826, 2959.955, 3135.963, 3322.438, 3520, 3729.31, 3951.066, 4186.009, 4434.922, 4698.636, 4978.032, 5274.041, 5587.652, 5919.911, 6271.927, 6644.875, 7040, 7458.62, 7902.133, 8372.018, 8869.844, 9397.273, 9956.063, 10548.08, 11175.3, 11839.82, 12543.85};
    float k = 1;
    float oscFreq;
      AudioMemory(10);
      usbMIDI.setHandleNoteOn(myNoteOn);
      usbMIDI.setHandleNoteOff(myNoteOff);
      usbMIDI.setHandleControlChange(myControlChange);
      waveformMod1.begin(0.2, 0, WAVEFORM_BANDLIMIT_SQUARE);
      filter1.resonance(1.1);
      usbMIDI.read();
    void myNoteOn(byte channel, byte note, byte velocity) {
      oscFreq = noteFreqs[note];
      waveformMod1.frequency(oscFreq);
      envelope1.noteOn();
      filter1.frequency(oscFreq * k);
      Serial.println(oscFreq * k);
    void myNoteOff(byte channel, byte note, byte velocity) {
      envelope1.noteOff();
    void myControlChange(byte channel, byte control, byte value) {
      if (control == 15) {
        k = powf((float)value/127, 3) * 50;  //log scale
        Serial.println(k);
    Dec 2018
    186
    controller #15 is mapped to filter FC.
