I have used this ASM saturation function borrowed from the audio library.
It has been very useful, normally I use it like this example:
I would like to make the bits and shift variables like this:
I have been using a few of these as "black box" functions, and do not know much about the syntax. I tried what seemed "obvious" to me which was changing the "I" to "r" like they are on other functions which do accept 3 variables, (like multiply-accumulate) but that makes it fail to compile.
Is USAT just made to expect a constant number of bits and shift, or is there something else I can do to make it accept all 3 inputs as variables?
I am using a teensy 3.6 for this and that part of the code is in an ISR.
inline int32_t clampU_rsh(int32_t val, int bits, int rshift)
int32_t out;
asm volatile("usat %0, %1, %2, asr %3" : "=r" (out) : "I" (bits), "r" (val), "I" (rshift));
return out;
G_out = clampU_rsh(ms_glideCount[ms], 15 , 1);
G_out = clampU_rsh(ms_glideCount[ms], x , y);
