Results 1 to 3 of 3
Thread: Two SPI devices on Teensy 4.0
    Nov 2020
    Czech Republic
    80
    Hi all,
    is possible to conenct two SPI devices, display and 24-bit ADC on Teensy 4.0? I have no clue hot to do it.
    Wiring you can see on picture.
    Could I use same pins and control both devices by software?
    Thanks for any advice.
    Michal
    15,878
    See Better SPI Bus Design in 3 Steps
    It is possible, as long as the devices are designed to tri-state their MISO to keep the Pin #12 usable.
    SPI BUS on Teensy pins 11, 12, 13 can then be shared to multiple devices for use 'in turn' where each requires a unique CS pin connected.
    And for Teensy 4.0, those pins must see only 3.3V from the device.
    Dec 2016
    Montreal, Canada
    4,033
    the MISO/MOSI/SCK can be ran in parallel provided the devices tri-state their MISO pin on deassertion of the CS pin. However, the other pins should be different: CS, RST, DRDY, RST etc
