Rename / Change SD Card Volume NAME using SDfat Library when Reformatting
KickOnBro
Hi all,
I have begun exploring the default SD card libraries built into Teensyduino, however, I cannot seem to find any options to rename the SD card (the active volume I believe, not sure I have the correct terminology, sorry!). Specifically, I have been using the "SdFormatter" example from the SDfat library, and it doesn't make any mention of naming the volume during formatting and I couldn't seem to find anything in the library reference. I am not sure if this is possible or if I'm missing something simple, I would just like to be able to name the card "Teensy" or something so that when I plug it into my computer it is formatted AND named!
I am using a Teensy 4.1 and currently formatting with exfat, however, if this is only possible in fat32 that is okay too.
Thanks in advance for any help,
I have attached the reformat example code below for reference.
 * This program will format SD/SDHC/SDXC cards.
 * Warning all data will be deleted!
 * This program attempts to match the format
 * generated by SDFormatter available here:
 * http://www.sdcard.org/consumers/formatter/
 * For very small cards this program uses FAT16
 * and the above SDFormatter uses FAT12.
#include "SdFat.h"
#include "sdios.h"
  Set DISABLE_CS_PIN to disable a second SPI device.
  For example, with the Ethernet shield, set DISABLE_CS_PIN
  to 10 to disable the Ethernet controller.
const int8_t DISABLE_CS_PIN = -1;
  Change the value of SD_CS_PIN if you are using SPI
  and your hardware does not use the default value, SS.
  Common values are:
  Arduino Ethernet shield: pin 4
  Sparkfun SD shield: pin 8
  Adafruit SD shields and modules: pin 10
// SDCARD_SS_PIN is defined for the built-in SD on some boards.
#ifndef SDCARD_SS_PIN
const uint8_t SD_CS_PIN = SS;
#else  // SDCARD_SS_PIN
// Assume built-in SD is used.
const uint8_t SD_CS_PIN = SDCARD_SS_PIN;
#endif  // SDCARD_SS_PIN
// Try max SPI clock for an SD. Reduce SPI_CLOCK if errors occur.
#define SPI_CLOCK SD_SCK_MHZ(50)
// Try to select the best SD card configuration.
#if HAS_SDIO_CLASS
#define SD_CONFIG SdioConfig(FIFO_SDIO)
#elif  ENABLE_DEDICATED_SPI
#define SD_CONFIG SdSpiConfig(SD_CS_PIN, DEDICATED_SPI, SPI_CLOCK)
#else  // HAS_SDIO_CLASS
#define SD_CONFIG SdSpiConfig(SD_CS_PIN, SHARED_SPI, SPI_CLOCK)
#endif  // HAS_SDIO_CLASS
// Serial output stream
ArduinoOutStream cout(Serial);
uint32_t cardSectorCount = 0;
uint8_t  sectorBuffer[512];
// SdCardFactory constructs and initializes the appropriate card.
SdCardFactory cardFactory;
// Pointer to generic SD card.
SdCard* m_card = nullptr;
#define sdError(msg) {cout << F("error: ") << F(msg) << endl; sdErrorHalt();}
void sdErrorHalt() {
  if (!m_card) {
    cout << F("Invalid SD_CONFIG") << endl;
  } else if (m_card->errorCode()) {
    if (m_card->errorCode() == SD_CARD_ERROR_CMD0) {
      cout << F("No card, wrong chip select pin, or wiring error?") << endl;
    cout << F("SD errorCode: ") << hex << showbase;
    printSdErrorSymbol(&Serial, m_card->errorCode());
    cout << F(" = ") << int(m_card->errorCode()) << endl;
    cout << F("SD errorData = ") << int(m_card->errorData()) << endl;
  SysCall::halt();
void clearSerialInput() {
  uint32_t m = micros();
  do {
    if (Serial.read() >= 0) {
      m = micros();
  } while (micros() - m < 10000);
// flash erase all data
uint32_t const ERASE_SIZE = 262144L;
void eraseCard() {
  cout << endl << F("Erasing\n");
  uint32_t firstBlock = 0;
  uint32_t lastBlock;
  uint16_t n = 0;
  do {
    lastBlock = firstBlock + ERASE_SIZE - 1;
    if (lastBlock >= cardSectorCount) {
      lastBlock = cardSectorCount - 1;
    if (!m_card->erase(firstBlock, lastBlock)) {
      sdError("erase failed");
    cout << '.';
    if ((n++)%64 == 63) {
      cout << endl;
    firstBlock += ERASE_SIZE;
  } while (firstBlock < cardSectorCount);
  cout << endl;
  if (!m_card->readSector(0, sectorBuffer)) {
    sdError("readBlock");
  cout << hex << showbase << setfill('0') << internal;
  cout << F("All data set to ") << setw(4) << int(sectorBuffer[0]) << endl;
  cout << dec << noshowbase << setfill(' ') << right;
  cout << F("Erase done\n");
void formatCard() {
  ExFatFormatter exFatFormatter;
  FatFormatter fatFormatter;
  // Format exFAT if larger than 32GB.
  bool rtn = cardSectorCount > 67108864 ?
    exFatFormatter.format(m_card, sectorBuffer, &Serial) :
    fatFormatter.format(m_card, sectorBuffer, &Serial);
  if (!rtn) {
    sdErrorHalt();
  cout << F("Run the SdInfo example for format details.") << endl;
void printConfig(SdSpiConfig config) {
  if (DISABLE_CS_PIN < 0) {
    cout << F(
           "\nAssuming the SD is the only SPI device.\n"
           "Edit DISABLE_CS_PIN to disable an SPI device.\n");
    cout << F("\nDisabling SPI device on pin ");
    cout << int(DISABLE_CS_PIN) << endl;
    pinMode(DISABLE_CS_PIN, OUTPUT);
    digitalWrite(DISABLE_CS_PIN, HIGH);
  cout << F("\nAssuming the SD chip select pin is: ") << int(config.csPin);
  cout << F("\nEdit SD_CS_PIN to change the SD chip select pin.\n");
void printConfig(SdioConfig config) {
  (void)config;
  cout << F("Assuming an SDIO interface.\n");
  char c;
  // Wait for USB Serial
  while (!Serial) {
    SysCall::yield();
  printConfig(SD_CONFIG);
  cout << F("\nType any character to start\n");
  while (!Serial.available()) {
    SysCall::yield();
  // Discard any extra characters.
  clearSerialInput();
  cout << F(
         "\n"
         "This program can erase and/or format SD/SDHC/SDXC cards.\n"
         "\n"
         "Erase uses the card's fast flash erase command.\n"
         "Flash erase sets all data to 0X00 for most cards\n"
         "and 0XFF for a few vendor's cards.\n"
         "\n"
         "Cards up to 2 GiB (GiB = 2^30 bytes) will be formated FAT16.\n"
         "Cards larger than 2 GiB and up to 32 GiB will be formatted\n"
         "FAT32. Cards larger than 32 GiB will be formatted exFAT.\n"
         "\n"
         "Warning, all data on the card will be erased.\n"
         "Enter 'Y' to continue: ");
    SysCall::yield();
  c = Serial.read();
  cout << c << endl;
  if (c != 'Y') {
    cout << F("Quiting, you did not enter 'Y'.\n");
    return;
  // Read any existing Serial data.
  clearSerialInput();
  // Select and initialize proper card driver.
  m_card = cardFactory.newCard(SD_CONFIG);
  if (!m_card || m_card->errorCode()) {
    sdError("card init failed.");
    return;
  cardSectorCount = m_card->sectorCount();
  if (!cardSectorCount) {
    sdError("Get sector count failed.");
    return;
  cout << F("\nCard size: ") << cardSectorCount*5.12e-7;
  cout << F(" GB (GB = 1E9 bytes)\n");
  cout << F("Card size: ") << cardSectorCount/2097152.0;
  cout << F(" GiB (GiB = 2^30 bytes)\n");
  cout << F("Card will be formated ");
  if (cardSectorCount > 67108864) {
    cout << F("exFAT\n");
  } else if (cardSectorCount > 4194304) {
    cout << F("FAT32\n");
    cout << F("FAT16\n");
  cout << F(
         "\n"
         "Options are:\n"
         "E - erase the card and skip formatting.\n"
         "F - erase and then format the card. (recommended)\n"
         "Q - quick format the card without erase.\n"
         "\n"
         "Enter option: ");
    SysCall::yield();
  c = Serial.read();
  cout << c << endl;
  if (!strchr("EFQ", c)) {
    cout << F("Quiting, invalid option entered.") << endl;
    return;
  if (c == 'E' || c == 'F') {
    eraseCard();
  if (c == 'F' || c == 'Q') {
    formatCard();
SDFat - Note the version shipped with Teensyduino is only a slightly modified version of the https://github.com/greiman/SdFat
Which is the original and principle developer of SDFat.
As far as I remember, he has not added any methods for setting or query of the volume label. There is code in the library to ignore it when walking the root directory...
In the short term I am not sure what to suggest. Longer term, we have as part of our work in progress to integrate some additional functionality into Teensyduino, including MTP and MSC (ability to plug usb drives into t3.6/t4.x), we have added that capability into some of this. We have an extended version of the SDFat sub-library FSLib called PFSLib where we added this and use it in our formatting code, that when we do a format of a volume, we first read in volume label and then reset it after...
Warning: this is all work in progress and not part of any current release of Teensyduino. It is currently contained within my fork of the USBHost_t36 in a branch that a few of us or working out of, and specifically the
format and volume label code is up in: https://github.com/KurtE/USBHost_t36/tree/FS_Integration_MSC/src/PFsLib
And it is unclear where this code will end up, by the time this functionality is released.
Thank you so much for this! I'll have a look into that, thank you guys so much for all the work you put into Teensy, it definatly pays off! Best experience with microcontrollers I've had so far :)
