Hi all,
Found a weird issue and am wondering what folks think. I'm reading values from the SD card out of a single file. The file is a text file containing simply:
16 bit int # + \n
16 bit int # + \n
so I read values from the card, and set those values to an analog output.
Normally the read operation in it's entirety takes 7-8us (awesome!), but, once in every ~ 171 reads, the system requires ~ 200us to return it's value.
I've tested multiple SD cards and it seems that the faster card will run @ 180-200us or so, where the slow cards are 2x that speed (7-8us on normal reads, 400us on this delay interval read).
So - AFAIKT this is some buffer issue on the card or something? Only other issue is it may be the readstringuntil function?
Just curious if someone had an obvious answer - my next approach will be trying a char read and then possibly playing with a buffer of some kind on the read. Ultimately this function produces an arbitrary waveform - so right now I have shelves in the form and am seeking to eliminate those.
I'd note that I HAVE isolated the delay to this read - all other functions run consistently - so the delay is in this chunk of code for sure.
Here is the serial output on the monitor:
Where line # = the current read line from the card, val = the 16 bit int number read in, D = the micros() delay in reading the value.
Line#: 1, val: 33715, D: 200
Line#: 25, val: 33581, D: 5
Line#: 49, val: 33447, D: 5
Line#: 73, val: 33313, D: 5
Line#: 97, val: 33179, D: 5
Line#: 121, val: 33045, D: 5
Line#: 145, val: 32911, D: 5
Line#: 169, val: 32777, D: 5
Line#: 171, val: 32766, D: 182
Line#: 195, val: 32632, D: 5
Line#: 219, val: 32498, D: 5
Line#: 243, val: 32364, D: 5
Line#: 267, val: 32230, D: 5
Line#: 291, val: 32096, D: 5
Line#: 315, val: 31962, D: 5
Line#: 339, val: 31828, D: 5
Line#: 341, val: 31817, D: 182
Line#: 365, val: 31683, D: 5
Line#: 389, val: 31549, D: 5
Line#: 413, val: 31415, D: 5
Line#: 437, val: 31281, D: 5
Line#: 461, val: 31147, D: 5
Line#: 485, val: 31013, D: 6
Line#: 513, val: 30857, D: 182
Line#: 537, val: 30723, D: 5
Line#: 561, val: 30589, D: 5
Line#: 585, val: 30455, D: 5
Line#: 609, val: 30321, D: 5
Line#: 633, val: 30187, D: 5
Line#: 657, val: 30053, D: 5
Line#: 681, val: 29919, D: 5
Line#: 683, val: 29908, D: 182
Line#: 707, val: 29796, D: 5
Line#: 731, val: 29919, D: 5
Line#: 755, val: 30053, D: 5
Line#: 779, val: 30187, D: 5
Line#: 803, val: 30321, D: 5
Line#: 827, val: 30455, D: 5
Line#: 851, val: 30589, D: 5
Line#: 853, val: 30600, D: 182
etc....
16 bit int # + \n
16 bit int # + \n
etc....
HTML:
//Serial.println(millis() -e);
unsigned long ms = micros();
String v = df[0].readStringUntil('\n');
currentval = currentval+1;
if((micros()-ms) >3 ){
Serial.print("Line#: "); Serial.print(currentval); Serial.print(", val: "); Serial.print(v); Serial.print(", D: "); Serial.println(micros()-ms );
