Page 1 of 3 1 2 3 LastLast
Results 1 to 25 of 66
Thread: Teensy 4.1 USB-Host USB-Hub Mouse-Keyboard Problem
    Jan 2022
    10
    i tested this with different usb-hubs, keyboards and mouses, can someone confirm that bug and give a hint to fix it?
    My problem is that the keyboard is only working if i connect it before i connect the mouse.
    Test:
    1. Mouse connected -> working
    2. Keyboard connected -> working
    3. Keyboard connected and after that Mouse -> working
    4. Mouse+Keyboard connected -> Keyboard not working
    5. Mouse connected after that Keyboard -> Keyboard not working
    Tested with the Example Script "Mouse_KeyboardBT" and Arduino 1.8.19/Teensyduino 1.56
    // Simple test of USB Host Mouse/Keyboard
    // This example is in the public domain
    #include "USBHost_t36.h"
    USBHost myusb;
    USBHub hub1(myusb);
    USBHub hub2(myusb);
    KeyboardController keyboard1(myusb);
    //KeyboardController keyboard2(myusb);
    USBHIDParser hid1(myusb);
    USBHIDParser hid2(myusb);
    USBHIDParser hid3(myusb);
    USBHIDParser hid4(myusb);
    USBHIDParser hid5(myusb);
    MouseController mouse1(myusb);
    //JoystickController joystick1(myusb);
    //BluetoothController bluet(myusb, true, "0000");   // Version does pairing to device
    BluetoothController bluet(myusb);   // version assumes it already was paired
    USBDriver *drivers[] = {&hub1, &hub2, &keyboard1, &bluet, &hid1, &hid2, &hid3, &hid4, &hid5};
    #define CNT_DEVICES (sizeof(drivers)/sizeof(drivers[0]))
    const char * driver_names[CNT_DEVICES] = {"Hub1", "Hub2", "KB1", "Bluet", "HID1" , "HID2", "HID3", "HID4", "HID5"};
    bool driver_active[CNT_DEVICES] = {false, false, false, false};
    // Lets also look at HID Input devices
    USBHIDInput *hiddrivers[] = {&mouse1};
    #define CNT_HIDDEVICES (sizeof(hiddrivers)/sizeof(hiddrivers[0]))
    const char * hid_driver_names[CNT_HIDDEVICES] = {"Mouse1"};
    bool hid_driver_active[CNT_HIDDEVICES] = {false};
    BTHIDInput *bthiddrivers[] = {&keyboard1, &mouse1};
    #define CNT_BTHIDDEVICES (sizeof(bthiddrivers)/sizeof(bthiddrivers[0]))
    const char * bthid_driver_names[CNT_BTHIDDEVICES] = {"Keyboard(BT)", "Mouse(BT)"};
    bool bthid_driver_active[CNT_BTHIDDEVICES] = {false};
    bool show_changed_only = false;
    uint8_t joystick_left_trigger_value = 0;
    uint8_t joystick_right_trigger_value = 0;
    uint64_t joystick_full_notify_mask = (uint64_t) - 1;
      while (!Serial) ; // wait for Arduino Serial Monitor
      Serial1.begin(115200);
      Serial.println("\n\nUSB Host Testing");
      Serial.println(sizeof(USBHub), DEC);
      myusb.begin();
      keyboard1.attachPress(OnPress);
      //keyboard2.attachPress(OnPress);
      keyboard1.attachExtrasPress(OnHIDExtrasPress);
      keyboard1.attachExtrasRelease(OnHIDExtrasRelease);
      //keyboard2.attachExtrasPress(OnHIDExtrasPress);
      //keyboard2.attachExtrasRelease(OnHIDExtrasRelease);
      // check to see if the device list has changed:
      UpdateActiveDeviceInfo();
      myusb.Task();
      if (mouse1.available()) {
        Serial.print("Mouse: buttons = ");
        Serial.print(mouse1.getButtons());
        Serial.print(",  mouseX = ");
        Serial.print(mouse1.getMouseX());
        Serial.print(",  mouseY = ");
        Serial.print(mouse1.getMouseY());
        Serial.print(",  wheel = ");
        Serial.print(mouse1.getWheel());
        Serial.print(",  wheelH = ");
        Serial.print(mouse1.getWheelH());
        mouse1.mouseDataClear();
    void OnPress(int key)
      Serial.print("key '");
      switch (key) {
        case KEYD_UP       : Serial.print("UP"); break;
        case KEYD_DOWN    : Serial.print("DN"); break;
        case KEYD_LEFT     : Serial.print("LEFT"); break;
        case KEYD_RIGHT   : Serial.print("RIGHT"); break;
        case KEYD_INSERT   : Serial.print("Ins"); break;
        case KEYD_DELETE   : Serial.print("Del"); break;
        case KEYD_PAGE_UP  : Serial.print("PUP"); break;
        case KEYD_PAGE_DOWN: Serial.print("PDN"); break;
        case KEYD_HOME     : Serial.print("HOME"); break;
        case KEYD_END      : Serial.print("END"); break;
        case KEYD_F1       : Serial.print("F1"); break;
        case KEYD_F2       : Serial.print("F2"); break;
        case KEYD_F3       : Serial.print("F3"); break;
        case KEYD_F4       : Serial.print("F4"); break;
        case KEYD_F5       : Serial.print("F5"); break;
        case KEYD_F6       : Serial.print("F6"); break;
        case KEYD_F7       : Serial.print("F7"); break;
        case KEYD_F8       : Serial.print("F8"); break;
        case KEYD_F9       : Serial.print("F9"); break;
        case KEYD_F10      : Serial.print("F10"); break;
        case KEYD_F11      : Serial.print("F11"); break;
        case KEYD_F12      : Serial.print("F12"); break;
        default: Serial.print((char)key); break;
      Serial.print("'  ");
      Serial.print(key);
      Serial.print(" MOD: ");
      if (keyboard1) {
        Serial.print(keyboard1.getModifiers(), HEX);
        Serial.print(" OEM: ");
        Serial.print(keyboard1.getOemKey(), HEX);
        Serial.print(" LEDS: ");
        Serial.println(keyboard1.LEDS(), HEX);
        //} else {
        //Serial.print(keyboard2.getModifiers(), HEX);
        //Serial.print(" OEM: ");
        //Serial.print(keyboard2.getOemKey(), HEX);
        //Serial.print(" LEDS: ");
        //Serial.println(keyboard2.LEDS(), HEX);
      //Serial.print("key ");
      //Serial.print((char)keyboard1.getKey());
      //Serial.print("  ");
      //Serial.print((char)keyboard2.getKey());
      //Serial.println();
    void OnHIDExtrasPress(uint32_t top, uint16_t key)
      Serial.print("HID (");
      Serial.print(top, HEX);
      Serial.print(") key press:");
      Serial.print(key, HEX);
      if (top == 0xc0000) {
        switch (key) {
          case  0x20 : Serial.print(" - +10"); break;
          case  0x21 : Serial.print(" - +100"); break;
          case  0x22 : Serial.print(" - AM/PM"); break;
          case  0x30 : Serial.print(" - Power"); break;
          case  0x31 : Serial.print(" - Reset"); break;
          case  0x32 : Serial.print(" - Sleep"); break;
          case  0x33 : Serial.print(" - Sleep After"); break;
          case  0x34 : Serial.print(" - Sleep Mode"); break;
          case  0x35 : Serial.print(" - Illumination"); break;
          case  0x36 : Serial.print(" - Function Buttons"); break;
          case  0x40 : Serial.print(" - Menu"); break;
          case  0x41 : Serial.print(" - Menu  Pick"); break;
          case  0x42 : Serial.print(" - Menu Up"); break;
          case  0x43 : Serial.print(" - Menu Down"); break;
          case  0x44 : Serial.print(" - Menu Left"); break;
          case  0x45 : Serial.print(" - Menu Right"); break;
          case  0x46 : Serial.print(" - Menu Escape"); break;
          case  0x47 : Serial.print(" - Menu Value Increase"); break;
          case  0x48 : Serial.print(" - Menu Value Decrease"); break;
          case  0x60 : Serial.print(" - Data On Screen"); break;
          case  0x61 : Serial.print(" - Closed Caption"); break;
          case  0x62 : Serial.print(" - Closed Caption Select"); break;
          case  0x63 : Serial.print(" - VCR/TV"); break;
          case  0x64 : Serial.print(" - Broadcast Mode"); break;
          case  0x65 : Serial.print(" - Snapshot"); break;
          case  0x66 : Serial.print(" - Still"); break;
          case  0x80 : Serial.print(" - Selection"); break;
          case  0x81 : Serial.print(" - Assign Selection"); break;
          case  0x82 : Serial.print(" - Mode Step"); break;
          case  0x83 : Serial.print(" - Recall Last"); break;
          case  0x84 : Serial.print(" - Enter Channel"); break;
          case  0x85 : Serial.print(" - Order Movie"); break;
          case  0x86 : Serial.print(" - Channel"); break;
          case  0x87 : Serial.print(" - Media Selection"); break;
          case  0x88 : Serial.print(" - Media Select Computer"); break;
          case  0x89 : Serial.print(" - Media Select TV"); break;
          case  0x8A : Serial.print(" - Media Select WWW"); break;
          case  0x8B : Serial.print(" - Media Select DVD"); break;
          case  0x8C : Serial.print(" - Media Select Telephone"); break;
          case  0x8D : Serial.print(" - Media Select Program Guide"); break;
          case  0x8E : Serial.print(" - Media Select Video Phone"); break;
          case  0x8F : Serial.print(" - Media Select Games"); break;
          case  0x90 : Serial.print(" - Media Select Messages"); break;
          case  0x91 : Serial.print(" - Media Select CD"); break;
          case  0x92 : Serial.print(" - Media Select VCR"); break;
          case  0x93 : Serial.print(" - Media Select Tuner"); break;
          case  0x94 : Serial.print(" - Quit"); break;
          case  0x95 : Serial.print(" - Help"); break;
          case  0x96 : Serial.print(" - Media Select Tape"); break;
          case  0x97 : Serial.print(" - Media Select Cable"); break;
          case  0x98 : Serial.print(" - Media Select Satellite"); break;
          case  0x99 : Serial.print(" - Media Select Security"); break;
          case  0x9A : Serial.print(" - Media Select Home"); break;
          case  0x9B : Serial.print(" - Media Select Call"); break;
          case  0x9C : Serial.print(" - Channel Increment"); break;
          case  0x9D : Serial.print(" - Channel Decrement"); break;
          case  0x9E : Serial.print(" - Media Select SAP"); break;
          case  0xA0 : Serial.print(" - VCR Plus"); break;
          case  0xA1 : Serial.print(" - Once"); break;
          case  0xA2 : Serial.print(" - Daily"); break;
          case  0xA3 : Serial.print(" - Weekly"); break;
          case  0xA4 : Serial.print(" - Monthly"); break;
          case  0xB0 : Serial.print(" - Play"); break;
          case  0xB1 : Serial.print(" - Pause"); break;
          case  0xB2 : Serial.print(" - Record"); break;
          case  0xB3 : Serial.print(" - Fast Forward"); break;
          case  0xB4 : Serial.print(" - Rewind"); break;
          case  0xB5 : Serial.print(" - Scan Next Track"); break;
          case  0xB6 : Serial.print(" - Scan Previous Track"); break;
          case  0xB7 : Serial.print(" - Stop"); break;
          case  0xB8 : Serial.print(" - Eject"); break;
          case  0xB9 : Serial.print(" - Random Play"); break;
          case  0xBA : Serial.print(" - Select DisC"); break;
          case  0xBB : Serial.print(" - Enter Disc"); break;
          case  0xBC : Serial.print(" - Repeat"); break;
          case  0xBD : Serial.print(" - Tracking"); break;
          case  0xBE : Serial.print(" - Track Normal"); break;
          case  0xBF : Serial.print(" - Slow Tracking"); break;
          case  0xC0 : Serial.print(" - Frame Forward"); break;
          case  0xC1 : Serial.print(" - Frame Back"); break;
          case  0xC2 : Serial.print(" - Mark"); break;
          case  0xC3 : Serial.print(" - Clear Mark"); break;
          case  0xC4 : Serial.print(" - Repeat From Mark"); break;
          case  0xC5 : Serial.print(" - Return To Mark"); break;
          case  0xC6 : Serial.print(" - Search Mark Forward"); break;
          case  0xC7 : Serial.print(" - Search Mark Backwards"); break;
          case  0xC8 : Serial.print(" - Counter Reset"); break;
          case  0xC9 : Serial.print(" - Show Counter"); break;
          case  0xCA : Serial.print(" - Tracking Increment"); break;
          case  0xCB : Serial.print(" - Tracking Decrement"); break;
          case  0xCD : Serial.print(" - Pause/Continue"); break;
          case  0xE0 : Serial.print(" - Volume"); break;
          case  0xE1 : Serial.print(" - Balance"); break;
          case  0xE2 : Serial.print(" - Mute"); break;
          case  0xE3 : Serial.print(" - Bass"); break;
          case  0xE4 : Serial.print(" - Treble"); break;
          case  0xE5 : Serial.print(" - Bass Boost"); break;
          case  0xE6 : Serial.print(" - Surround Mode"); break;
          case  0xE7 : Serial.print(" - Loudness"); break;
          case  0xE8 : Serial.print(" - MPX"); break;
          case  0xE9 : Serial.print(" - Volume Up"); break;
          case  0xEA : Serial.print(" - Volume Down"); break;
          case  0xF0 : Serial.print(" - Speed Select"); break;
          case  0xF1 : Serial.print(" - Playback Speed"); break;
          case  0xF2 : Serial.print(" - Standard Play"); break;
          case  0xF3 : Serial.print(" - Long Play"); break;
          case  0xF4 : Serial.print(" - Extended Play"); break;
          case  0xF5 : Serial.print(" - Slow"); break;
          case  0x100: Serial.print(" - Fan Enable"); break;
          case  0x101: Serial.print(" - Fan Speed"); break;
          case  0x102: Serial.print(" - Light"); break;
          case  0x103: Serial.print(" - Light Illumination Level"); break;
          case  0x104: Serial.print(" - Climate Control Enable"); break;
          case  0x105: Serial.print(" - Room Temperature"); break;
          case  0x106: Serial.print(" - Security Enable"); break;
          case  0x107: Serial.print(" - Fire Alarm"); break;
          case  0x108: Serial.print(" - Police Alarm"); break;
          case  0x150: Serial.print(" - Balance Right"); break;
          case  0x151: Serial.print(" - Balance Left"); break;
          case  0x152: Serial.print(" - Bass Increment"); break;
          case  0x153: Serial.print(" - Bass Decrement"); break;
          case  0x154: Serial.print(" - Treble Increment"); break;
          case  0x155: Serial.print(" - Treble Decrement"); break;
          case  0x160: Serial.print(" - Speaker System"); break;
          case  0x161: Serial.print(" - Channel Left"); break;
          case  0x162: Serial.print(" - Channel Right"); break;
          case  0x163: Serial.print(" - Channel Center"); break;
          case  0x164: Serial.print(" - Channel Front"); break;
          case  0x165: Serial.print(" - Channel Center Front"); break;
          case  0x166: Serial.print(" - Channel Side"); break;
          case  0x167: Serial.print(" - Channel Surround"); break;
          case  0x168: Serial.print(" - Channel Low Frequency Enhancement"); break;
          case  0x169: Serial.print(" - Channel Top"); break;
          case  0x16A: Serial.print(" - Channel Unknown"); break;
          case  0x170: Serial.print(" - Sub-channel"); break;
          case  0x171: Serial.print(" - Sub-channel Increment"); break;
          case  0x172: Serial.print(" - Sub-channel Decrement"); break;
          case  0x173: Serial.print(" - Alternate Audio Increment"); break;
          case  0x174: Serial.print(" - Alternate Audio Decrement"); break;
          case  0x180: Serial.print(" - Application Launch Buttons"); break;
          case  0x181: Serial.print(" - AL Launch Button Configuration Tool"); break;
          case  0x182: Serial.print(" - AL Programmable Button Configuration"); break;
          case  0x183: Serial.print(" - AL Consumer Control Configuration"); break;
          case  0x184: Serial.print(" - AL Word Processor"); break;
          case  0x185: Serial.print(" - AL Text Editor"); break;
          case  0x186: Serial.print(" - AL Spreadsheet"); break;
          case  0x187: Serial.print(" - AL Graphics Editor"); break;
          case  0x188: Serial.print(" - AL Presentation App"); break;
          case  0x189: Serial.print(" - AL Database App"); break;
          case  0x18A: Serial.print(" - AL Email Reader"); break;
          case  0x18B: Serial.print(" - AL Newsreader"); break;
          case  0x18C: Serial.print(" - AL Voicemail"); break;
          case  0x18D: Serial.print(" - AL Contacts/Address Book"); break;
          case  0x18E: Serial.print(" - AL Calendar/Schedule"); break;
          case  0x18F: Serial.print(" - AL Task/Project Manager"); break;
          case  0x190: Serial.print(" - AL Log/Journal/Timecard"); break;
          case  0x191: Serial.print(" - AL Checkbook/Finance"); break;
          case  0x192: Serial.print(" - AL Calculator"); break;
          case  0x193: Serial.print(" - AL A/V Capture/Playback"); break;
          case  0x194: Serial.print(" - AL Local Machine Browser"); break;
          case  0x195: Serial.print(" - AL LAN/WAN Browser"); break;
          case  0x196: Serial.print(" - AL Internet Browser"); break;
          case  0x197: Serial.print(" - AL Remote Networking/ISP Connect"); break;
          case  0x198: Serial.print(" - AL Network Conference"); break;
          case  0x199: Serial.print(" - AL Network Chat"); break;
          case  0x19A: Serial.print(" - AL Telephony/Dialer"); break;
          case  0x19B: Serial.print(" - AL Logon"); break;
          case  0x19C: Serial.print(" - AL Logoff"); break;
          case  0x19D: Serial.print(" - AL Logon/Logoff"); break;
          case  0x19E: Serial.print(" - AL Terminal Lock/Screensaver"); break;
          case  0x19F: Serial.print(" - AL Control Panel"); break;
          case  0x1A0: Serial.print(" - AL Command Line Processor/Run"); break;
          case  0x1A1: Serial.print(" - AL Process/Task Manager"); break;
          case  0x1A2: Serial.print(" - AL Select Tast/Application"); break;
          case  0x1A3: Serial.print(" - AL Next Task/Application"); break;
          case  0x1A4: Serial.print(" - AL Previous Task/Application"); break;
          case  0x1A5: Serial.print(" - AL Preemptive Halt Task/Application"); break;
          case  0x200: Serial.print(" - Generic GUI Application Controls"); break;
          case  0x201: Serial.print(" - AC New"); break;
          case  0x202: Serial.print(" - AC Open"); break;
          case  0x203: Serial.print(" - AC Close"); break;
          case  0x204: Serial.print(" - AC Exit"); break;
          case  0x205: Serial.print(" - AC Maximize"); break;
          case  0x206: Serial.print(" - AC Minimize"); break;
          case  0x207: Serial.print(" - AC Save"); break;
          case  0x208: Serial.print(" - AC Print"); break;
          case  0x209: Serial.print(" - AC Properties"); break;
          case  0x21A: Serial.print(" - AC Undo"); break;
          case  0x21B: Serial.print(" - AC Copy"); break;
          case  0x21C: Serial.print(" - AC Cut"); break;
          case  0x21D: Serial.print(" - AC Paste"); break;
          case  0x21E: Serial.print(" - AC Select All"); break;
          case  0x21F: Serial.print(" - AC Find"); break;
          case  0x220: Serial.print(" - AC Find and Replace"); break;
          case  0x221: Serial.print(" - AC Search"); break;
          case  0x222: Serial.print(" - AC Go To"); break;
          case  0x223: Serial.print(" - AC Home"); break;
          case  0x224: Serial.print(" - AC Back"); break;
          case  0x225: Serial.print(" - AC Forward"); break;
          case  0x226: Serial.print(" - AC Stop"); break;
          case  0x227: Serial.print(" - AC Refresh"); break;
          case  0x228: Serial.print(" - AC Previous Link"); break;
          case  0x229: Serial.print(" - AC Next Link"); break;
          case  0x22A: Serial.print(" - AC Bookmarks"); break;
          case  0x22B: Serial.print(" - AC History"); break;
          case  0x22C: Serial.print(" - AC Subscriptions"); break;
          case  0x22D: Serial.print(" - AC Zoom In"); break;
          case  0x22E: Serial.print(" - AC Zoom Out"); break;
          case  0x22F: Serial.print(" - AC Zoom"); break;
          case  0x230: Serial.print(" - AC Full Screen View"); break;
          case  0x231: Serial.print(" - AC Normal View"); break;
          case  0x232: Serial.print(" - AC View Toggle"); break;
          case  0x233: Serial.print(" - AC Scroll Up"); break;
          case  0x234: Serial.print(" - AC Scroll Down"); break;
          case  0x235: Serial.print(" - AC Scroll"); break;
          case  0x236: Serial.print(" - AC Pan Left"); break;
          case  0x237: Serial.print(" - AC Pan Right"); break;
          case  0x238: Serial.print(" - AC Pan"); break;
          case  0x239: Serial.print(" - AC New Window"); break;
          case  0x23A: Serial.print(" - AC Tile Horizontally"); break;
          case  0x23B: Serial.print(" - AC Tile Vertically"); break;
          case  0x23C: Serial.print(" - AC Format"); break;
    void OnHIDExtrasRelease(uint32_t top, uint16_t key)
      Serial.print(") key release:");
      Serial.println(key, HEX);
    // UpdateActiveDeviceInfo
    void UpdateActiveDeviceInfo() {
      for (uint8_t i = 0; i < CNT_DEVICES; i++) {
        if (*drivers[i] != driver_active[i]) {
          if (driver_active[i]) {
            Serial.printf("*** Device %s - disconnected ***\n", driver_names[i]);
            driver_active[i] = false;
            Serial.printf("*** Device %s %x:%x - connected ***\n", driver_names[i], drivers[i]->idVendor(), drivers[i]->idProduct());
            driver_active[i] = true;
            const uint8_t *psz = drivers[i]->manufacturer();
            if (psz && *psz) Serial.printf("  manufacturer: %s\n", psz);
            psz = drivers[i]->product();
            if (psz && *psz) Serial.printf("  product: %s\n", psz);
            psz = drivers[i]->serialNumber();
            if (psz && *psz) Serial.printf("  Serial: %s\n", psz);
            if (drivers[i] == &bluet) {
              const uint8_t *bdaddr = bluet.myBDAddr();
              // remember it...
              Serial.printf("  BDADDR: %x:%x:%x:%x:%x:%x\n", bdaddr[0], bdaddr[1], bdaddr[2], bdaddr[3], bdaddr[4], bdaddr[5]);
      for (uint8_t i = 0; i < CNT_HIDDEVICES; i++) {
        if (*hiddrivers[i] != hid_driver_active[i]) {
          if (hid_driver_active[i]) {
            Serial.printf("*** HID Device %s - disconnected ***\n", hid_driver_names[i]);
            hid_driver_active[i] = false;
            Serial.printf("*** HID Device %s %x:%x - connected ***\n", hid_driver_names[i], hiddrivers[i]->idVendor(), hiddrivers[i]->idProduct());
            hid_driver_active[i] = true;
            const uint8_t *psz = hiddrivers[i]->manufacturer();
            psz = hiddrivers[i]->product();
            psz = hiddrivers[i]->serialNumber();
      // Then Bluetooth devices
      for (uint8_t i = 0; i < CNT_BTHIDDEVICES; i++) {
        if (*bthiddrivers[i] != bthid_driver_active[i]) {
          if (bthid_driver_active[i]) {
            Serial.printf("*** BTHID Device %s - disconnected ***\n", bthid_driver_names[i]);
            bthid_driver_active[i] = false;
            Serial.printf("*** BTHID Device %s - connected ***\n", bthid_driver_names[i]); Serial.flush();
            bthid_driver_active[i] = true;
            #if 0
            const uint8_t *psz = bthiddrivers[i]->manufacturer();
            psz = bthiddrivers[i]->product();
            psz = bthiddrivers[i]->serialNumber();
    Jan 2022
    10
    after some more testing two mouses works without problems so it must be a problem with the keyboard code in the USBHost_t36.h or somewhere else where the keyboard is detected
    would be nice if someone can confirm the same problem or let me know that he has not that problem so maybe my teensy is broken.
    The only problem I have had is with a wireless mouse that registers as a keyboard as well. So if I plug the keyboard in after the mouse it is registers as a 2nd keyboard and needs to be handled.
    Regards
    Jan 2022
    10
    thanks you are right the keyboard has been registered as 2nd keyboard (KB2) if there is a mouse present.
    *** Device KB1 45e:7b2 - connected ***
    manufacturer: Microsoft
    product: Microsoft� Nano Transceiver v1.0
    *** Device KB2 413c:2107 - connected ***
    manufacturer: Dell
    product: Dell USB Entry Keyboard
    The problem is that even with keyboard2 in the code the keys are disabled and the numlock led is not working.
    If I should rat, the problem is that the mouse is recognized as keyboard1 and the keyboard controller crashes
    USBDriver *drivers[] = {&hub1, &hub2, &keyboard1, &keyboard2, &hid1, &hid2, &hid3, &hid4, &hid5};
    const char * driver_names[CNT_DEVICES] = {"Hub1", "Hub2", "KB1", "KB2", "HID1" , "HID2", "HID3", "HID4", "HID5"};
    USBHost myusb;
    USBHub hub1(myusb);
    USBHub hub2(myusb);
    MouseController mouse2(myusb);
      myusb.begin();
    Jan 2022
    10
    ok here some more tests that proves its not a problem that the wireless reciever is registered as keyboard1.
    because my logitech reciever is working without problems with my wired dell keyboard.
    only the microsoft reciever kills my wired dell keyboard.
    the question is what is it that the microsoft wireless reciever is doing that kills the keyboard controller.
    two wireless reciever:
    1. microsoft wireless reciever buyed as mouse only
    *** Device HID1 45e:7b2 - connected ***
    *** Device HID2 45e:7b2 - connected ***
    *** HID Device Mouse1 45e:7b2 - connected ***
    2. logitech wireless reciever buyed as mouse & keyboard
    *** Device KB1 46d:c52b - connected ***
    manufacturer: Logitech
    product: USB Receiver
    *** Device HID1 46d:c52b - connected ***
    *** Device HID2 46d:c52b - connected ***
    *** HID Device Mouse1 46d:c52b - connected ***
    microsoft wireless reciever full debug log
    USB Host Testing
    960
    USB2 PLL running
     reset waited 6
    USBHS_ASYNCLISTADDR = 0
    USBHS_PERIODICLISTBASE = 20005000
    periodictable = 20005000
    port change: 10001803
        connect
      begin reset
    port change: 18001205
      port enabled
      end recovery
    new_Device: 480 Mbit/sec
    new_Pipe
    enumeration:
    enumeration:
    enumeration:
    Device Descriptor:
      12 01 00 02 09 00 01 40 40 1A 01 01 11 01 00 01 00 01
        VendorID = 1A40, ProductID = 0101, Version = 0111
        Class/Subclass/Protocol = 9(Hub) / 0 / 1(Single-TT)
        Number of Configurations = 1
    enumeration:
    enumeration:
    Product: USB 2.0 Hub
    enumeration:
    Config data length = 25
    enumeration:
    Configuration Descriptor:
      09 02 19 00 01 01 00 E0 32
        NumInterfaces = 1
        ConfigurationValue = 1
      09 04 00 00 01 09 00 00 00
        Interface = 0
        Number of endpoints = 1
        Class/Subclass/Protocol = 9(Hub) / 0 / 0
      07 05 81 03 01 00 0C
        Endpoint = 1 IN
        Type = Interrupt
        Max Size = 1
        Polling Interval = 12
    enumeration:
    USBHub memory usage = 960
    USBHub claim_device this=200073A0
    found possible interface, altsetting=0
    number of interfaces found = 1
    USBHub control callback
    09 29 04 00 00 32 64 00 FF 00 00 00 00 00 00 00
    Hub ports = 4
    power turned on to all ports
    device addr = 1
    new_Pipe
    allocate_interrupt_pipe_bandwidth
      ep interval = 12
      interval = 256
     best_bandwidth = 2, at offset = 0
    pipe cap1 = F0012101
    HUB Callback (member)
    status = C
    getstatus, port = 2
    deferred getstatus, port = 3
    01 01 01 00
    New Port Status
      status=10101  port=2
      state=0
      Device is present:
      Has Power
    Port Status Cleared, port=2
    getstatus, port = 3
    01 03 01 00
    New Port Status
      status=10301  port=3
      state=0
      Device is present:
      Has Power
    Port Status Cleared, port=3
    timer event (19999 us): Debounce Timer, this = 200073A0, timer = 200076B8
    ports in use bitmask = C
    getstatus, port = 2
    01 01 00 00
    New Port Status
      status=101  port=2
      state=2
      Device is present:
      Has Power
    getstatus, port = 3
    01 03 00 00
    New Port Status
      status=301  port=3
      state=2
      Device is present:
      Has Power
    timer event (20000 us): Debounce Timer, this = 200073A0, timer = 200076B8
    getstatus, port = 2
    01 01 00 00
    New Port Status
      status=101  port=2
      state=3
      Device is present:
      Has Power
    getstatus, port = 3
    01 03 00 00
    New Port Status
      status=301  port=3
      state=3
      Device is present:
      Has Power
    getstatus, port = 2
    01 01 00 00
    New Port Status
      status=101  port=2
      state=4
      Device is present:
      Has Power
    getstatus, port = 3
    01 03 00 00
    New Port Status
      status=301  port=3
      state=4
      Device is present:
      Has Power
    getstatus, port = 2
    01 01 00 00
    New Port Status
      status=101  port=2
      state=5
      Device is present:
      Has Power
    getstatus, port = 3
    01 03 00 00
    New Port Status
      status=301  port=3
      state=5
      Device is present:
      Has Power
    getstatus, port = 2
    01 01 00 00
    New Port Status
      status=101  port=2
      state=6
      Device is present:
      Has Power
    sending reset
    send_setreset
    unhandled setup, message = 40323
    getstatus, port = 3
    01 03 00 00
    New Port Status
      status=301  port=3
      state=6
      Device is present:
      Has Power
    ports in use bitmask = 8
    getstatus, port = 3
    01 03 00 00
    New Port Status
      status=301  port=3
      state=6
      Device is present:
      Has Power
    status = 4
    getstatus, port = 2
    03 01 10 00
    New Port Status
      status=100103  port=2
      state=7
      Device is present:
      Enabled, speed = 12 Mbit/sec
      Has Power
    unhandled setup, message = 140123
    getstatus, port = 3
    01 03 00 00
    New Port Status
      status=301  port=3
      state=6
      Device is present:
      Has Power
    timer event (24999 us): Hello, I'm resettimer, this = 200073A0, timer = 200076D8
    port_doing_reset = 2
    PORT_RECOVERY
    new_Device: 12 Mbit/sec
    new_Pipe
    enumeration:
    enumeration:
    enumeration:
    Device Descriptor:
      12 01 00 02 00 00 00 40 5E 04 B2 07 44 07 01 02 00 01
        VendorID = 045E, ProductID = 07B2, Version = 0744
        Class/Subclass/Protocol = 0 / 0 / 0
    enumeration:
    enumeration:
    Manufacturer: Microsoft
    enumeration:
    Product: Microsoft® Nano Transceiver v1.0
    enumeration:
    Config data length = 84
    enumeration:
      09 02 54 00 03 01 00 A0 32
        NumInterfaces = 3
      09 04 00 00 01 03 01 01 00
        Interface = 0
        Class/Subclass/Protocol = 3(HID) / 1(Boot) / 1(Keyboard)
      09 21 11 01 00 01 22 4B 00
        HID, 1 report descriptor
      07 05 81 03 08 00 04
        Endpoint = 1 IN
        Type = Interrupt
        Max Size = 8
        Polling Interval = 4
      09 04 01 00 01 03 01 02 00
        Interface = 1
        Class/Subclass/Protocol = 3(HID) / 1(Boot) / 2(Mouse)
      09 21 11 01 00 01 22 DF 00
      07 05 82 03 0A 00 01
        Endpoint = 2 IN
        Type = Interrupt
        Max Size = 10
      09 04 02 00 01 03 00 00 00
        Interface = 2
        Class/Subclass/Protocol = 3(HID) / 0 / 0
      09 21 11 01 00 01 22 3F 01
      07 05 83 03 20 00 01
        Endpoint = 3 IN
        Type = Interrupt
        Max Size = 32
    enumeration:
    USBHub claim_device this=20007760
    KeyboardController claim this=20007B20
    KeyboardController claim this=20007DC0
    HIDParser claim this=200051E0
    HIDParser claim this=200058A0
    HIDParser claim this=20005F60
    HIDParser claim this=20006620
    HIDParser claim this=20006CE0
    Descriptor 4 = INTERFACE
    09 04 00 00 01 03 01 01 00 09 21 11 01 00 01 22 4B 00 07 05 81 03 08 00 04 09 04 01 00 01 03 01 02 00 09 21 11 01 00 01 22 DF 00 07 05 82 03 0A 00 01 09 04 02 00 01 03 00 00 00 09 21 11 01 00 01 22 3F 01 07 05 83 03 20 00 01
    ep = 81
    packet size = 8
    polling interval = 4
    new_Pipe
     best_bandwidth = 3, at offset = 0, shift= 1
    Descriptor 33 = HID
    Descriptor 5 = ENDPOINT
     bInterfaceNumber =   1
     bInterfaceClass =    3
     bInterfaceSubClass = 1
     bInterfaceProtocol = 2
    HID Parser Claim: 09 04 01 00 01 03 01 02 00 09 21 11 01 00 01 22 DF 00 07 05 82 03 0A 00 01 09 04 02 00 01 03 00 00 00 09 21 11 01 00 01 22 3F 01 07 05 83 03 20 00 01
    report descriptor size = 223
    Single endpoint HID:
      endpoint = 82
       size = 10
       interval = 1
    new_Pipe
     best_bandwidth = 3, at offset = 1, shift= 0
    Descriptor 33 = HID
     bInterfaceNumber =   2
     bInterfaceClass =    3
     bInterfaceSubClass = 0
     bInterfaceProtocol = 0
    HID Parser Claim: 09 04 02 00 01 03 00 00 00 09 21 11 01 00 01 22 3F 01 07 05 83 03 20 00 01
    report descriptor size = 319
      endpoint = 83
       size = 32
       interval = 1
    new_Pipe
     best_bandwidth = 5, at offset = 1, shift= 3
    Descriptor 33 = HID
    control callback (keyboard)
      mesg = A21
    timer event (22768 us): Debounce Timer, this = 200073A0, timer = 200076B8
    getstatus, port = 3
    01 03 00 00
    New Port Status
      status=301  port=3
      state=6
      Device is present:
      Has Power
    sending reset
    send_setreset
    control callback (hid)
    05 01 09 02 A1 01 05 01 09 02 A1 02 85 1A 09 01 A1 00 05 09 19 01 29 05 95 05 75 01 15 00 25 01 81 02 75 03 95 01 81 01 05 01 09 30 09 31 95 02 75 10 16 01 80 26 FF 7F 81 06 A1 02 85 12 09 48 95 01 75 02 15 00 25 01 35 01 45 0C B1 02 85 1A 09 38 35 00 45 00 95 01 75 10 16 01 80 26 FF 7F 81 06 C0 A1 02 85 12 09 48 75 02 15 00 25 01 35 01 45 0C B1 02 35 00 45 00 75 04 B1 01 85 1A 05 0C 95 01 75 10 16 01 80 26 FF 7F 0A 38 02 81 06 C0 C0 C0 C0 05 0C 09 01 A1 01 05 01 09 02 A1 02 85 1F 05 0C 0A 38 02 95 01 75 10 16 01 80 26 FF 7F 81 06 85 17 06 00 FF 0A 06 FF 0A 0F FF 15 00 25 01 35 01 45 0C 95 02 75 02 B1 02 0A 04 FF 35 00 45 00 95 01 75 01 B1 02 75 03 B1 01 C0 C0
      mesg = 22000681
      got report descriptor
    Found top level collection 10002
    find_driver
      driver 20007B2C
      driver 20007DCC
      driver 20008FEC
    Found top level collection C0001
    find_driver
      driver 20007B2C
    05 0C 09 01 A1 01 85 20 06 00 FF 15 00 26 FF 00 75 08 95 12 0A 0A FA B1 02 85 21 06 00 FF 15 00 25 01 75 01 95 10 1A 10 FA 2A 1F FA 81 02 85 28 06 00 FF 1A 10 FA 2A 1F FA B1 02 85 22 06 00 FF 15 00 26 FF 00 75 08 95 1A 0A 0A FA B1 02 85 23 06 00 FF 0A 0A FA B1 02 85 24 06 00 FF 95 1F 0A 0A FA B1 02 85 25 06 00 FF 0A 0A FA B1 02 85 26 06 00 FF 0A 0A FA B1 02 85 27 06 00 FF 0A 0A FA 81 02 85 14 06 00 FF 15 00 25 03 75 02 95 01 0A 01 FE 81 02 75 06 81 01 85 04 06 00 FF 15 00 25 03 75 02 95 01 0A 01 FE 81 02 75 06 81 01 C0 05 0C 09 01 A1 01 85 07 05 0C 19 00 2A FF 03 95 01 75 10 15 00 26 FF 03 81 00 05 07 19 00 29 FF 75 08 26 FF 00 81 00 81 01 06 00 FF 0A 03 FE 0A 04 FE 75 01 95 02 25 01 81 02 0A 05 FF 95 01 75 05 25 1F 81 02 75 01 81 01 1A 01 FD 2A FF FD 15 01 26 FF 00 75 08 81 00 0A 02 FF 26 FF 00 15 00 81 02 C0 06 BC FF 09 88 A1 01 85 08 19 01 29 FF 15 01 26 FF 00 95 01 75 08 81 00 C0 05 01 09 80 A1 01 85 03 19 00 29 FF 15 00 26 FF 00 81 00 C0
      mesg = 22000681
    find_driver
      driver 20007B2C
    find_driver
      driver 20007B2C
    Found top level collection FFBC0088
    find_driver
      driver 20007B2C
      driver 20007DCC
      driver 20008FEC
    No Driver claimed topusage: FFBC0088
    Found top level collection 10080
    find_driver
      driver 20007B2C
    begin, usage=C0000
           type= 2
           min=  0
           max=  1
           reportcount=16
           usage count=255
    Input, total bits=16
      usage = FF00FA10  data = 0
      usage = FF00FA11  data = 0
      usage = FF00FA12  data = 0
      usage = FF00FA13  data = 0
      usage = FF00FA14  data = 0
      usage = FF00FA15  data = 0
      usage = FF00FA16  data = 0
      usage = FF00FA17  data = 0
      usage = FF00FA18  data = 0
      usage = FF00FA19  data = 0
      usage = FF00FA1A  data = 0
      usage = FF00FA1B  data = 1
      usage = FF00FA1C  data = 0
      usage = FF00FA1D  data = 0
      usage = FF00FA1E  data = 0
      usage = FF00FA1F  data = 0
    ports in use bitmask = 0
    status = 8
    getstatus, port = 3
    03 03 10 00
    New Port Status
      status=100303  port=3
      state=7
      Device is present:
      Enabled, speed = 1.5 Mbit/sec
      Has Power
    port_doing_reset = 3
    PORT_RECOVERY
    new_Device: 1.5 Mbit/sec
    new_Pipe
    enumeration:
    enumeration:
    enumeration:
    Device Descriptor:
      12 01 10 01 00 00 00 08 3C 41 07 21 15 01 01 02 00 01
        VendorID = 413C, ProductID = 2107, Version = 0115
    enumeration:
    enumeration:
    Manufacturer: Dell
    enumeration:
    Product: Dell USB Entry Keyboard
    enumeration:
    Config data length = 34
    enumeration:
      09 02 22 00 01 01 00 A0 32
        NumInterfaces = 1
        Interface = 0
      09 21 10 01 00 01 22 41 00
      07 05 81 03 08 00 0A
        Endpoint = 1 IN
        Type = Interrupt
        Max Size = 8
        Polling Interval = 10
    enumeration:
    09 04 00 00 01 03 01 01 00 09 21 10 01 00 01 22 41 00 07 05 81 03 08 00 0A
    ep = 81
    packet size = 8
    polling interval = 10
    new_Pipe
     best_bandwidth = 6, at offset = 0, shift= 0
    Descriptor 33 = HID
      mesg = A21
    KeyboardController Callback (member)
      KB Data: 00 00 00 00 00 00 00 00
    ERROR Followup
    ERROR Followup
    *** Device Hub1 1a40:101 - connected ***
      product: USB 2.0 Hub
      manufacturer: Dell
    logitech wireless reciever full debug log
    USB Host Testing
    960
    USB2 PLL running
     reset waited 6
        connect
      begin reset
      port enabled
      end recovery
    new_Pipe
    enumeration:
    enumeration:
    enumeration:
    Device Descriptor:
    enumeration:
    enumeration:
    enumeration:
    enumeration:
        NumInterfaces = 1
        Interface = 0
        Endpoint = 1 IN
        Type = Interrupt
        Max Size = 1
    enumeration:
    Hub ports = 4
    device addr = 1
    new_Pipe
      ep interval = 12
      interval = 256
    status = C
    getstatus, port = 2
    01 01 01 00
    New Port Status
      status=10101  port=2
      state=0
      Device is present:
      Has Power
    getstatus, port = 3
    01 03 01 00
    New Port Status
      status=10301  port=3
      state=0
      Device is present:
      Has Power
    getstatus, port = 2
    01 01 00 00
    New Port Status
      status=101  port=2
      state=2
      Device is present:
      Has Power
    getstatus, port = 3
    01 03 00 00
    New Port Status
      status=301  port=3
      state=2
      Device is present:
      Has Power
    getstatus, port = 2
    01 01 00 00
    New Port Status
      status=101  port=2
      state=3
      Device is present:
      Has Power
    getstatus, port = 3
    01 03 00 00
    New Port Status
      status=301  port=3
      state=3
      Device is present:
      Has Power
    getstatus, port = 2
    01 01 00 00
    New Port Status
      status=101  port=2
      state=4
      Device is present:
      Has Power
    getstatus, port = 3
    01 03 00 00
    New Port Status
      status=301  port=3
      state=4
      Device is present:
      Has Power
    getstatus, port = 2
    01 01 00 00
    New Port Status
      status=101  port=2
      state=5
      Device is present:
      Has Power
    getstatus, port = 3
    01 03 00 00
    New Port Status
      status=301  port=3
      state=5
      Device is present:
      Has Power
    getstatus, port = 2
    01 01 00 00
    New Port Status
      status=101  port=2
      state=6
      Device is present:
      Has Power
    sending reset
    send_setreset
    getstatus, port = 3
    01 03 00 00
    New Port Status
      status=301  port=3
      state=6
      Device is present:
      Has Power
    getstatus, port = 3
    01 03 00 00
    New Port Status
      status=301  port=3
      state=6
      Device is present:
      Has Power
    status = 4
    getstatus, port = 2
    03 01 10 00
    New Port Status
      state=7
      Device is present:
      Has Power
    getstatus, port = 3
    01 03 00 00
    New Port Status
      status=301  port=3
      state=6
      Device is present:
      Has Power
    PORT_RECOVERY
    new_Pipe
    enumeration:
    enumeration:
    enumeration:
    Device Descriptor:
      12 01 00 02 00 00 00 08 6D 04 2B C5 07 12 01 02 00 01
        VendorID = 046D, ProductID = C52B, Version = 1207
    enumeration:
    enumeration:
    Manufacturer: Logitech
    enumeration:
    Product: USB Receiver
    enumeration:
    enumeration:
      09 02 54 00 03 01 04 A0 31
        NumInterfaces = 3
        Interface = 0
      09 21 11 01 00 01 22 3B 00
      07 05 81 03 08 00 08
        Endpoint = 1 IN
        Type = Interrupt
        Max Size = 8
        Polling Interval = 8
        Interface = 1
      09 21 11 01 00 01 22 94 00
      07 05 82 03 08 00 02
        Endpoint = 2 IN
        Type = Interrupt
        Max Size = 8
        Polling Interval = 2
        Interface = 2
      09 21 11 01 00 01 22 5D 00
      07 05 83 03 20 00 02
        Endpoint = 3 IN
        Type = Interrupt
        Max Size = 32
    enumeration:
    09 04 00 00 01 03 01 01 00 09 21 11 01 00 01 22 3B 00 07 05 81 03 08 00 08 09 04 01 00 01 03 01 02 00 09 21 11 01 00 01 22 94 00 07 05 82 03 08 00 02 09 04 02 00 01 03 00 00 00 09 21 11 01 00 01 22 5D 00 07 05 83 03 20 00 02
    ep = 81
    packet size = 8
    polling interval = 8
    new_Pipe
    Descriptor 33 = HID
     bInterfaceClass =    3
    HID Parser Claim: 09 04 01 00 01 03 01 02 00 09 21 11 01 00 01 22 94 00 07 05 82 03 08 00 02 09 04 02 00 01 03 00 00 00 09 21 11 01 00 01 22 5D 00 07 05 83 03 20 00 02
    report descriptor size = 148
      endpoint = 82
       size = 8
       interval = 2
    new_Pipe
     best_bandwidth = 3, at offset = 2, shift= 0
    Descriptor 33 = HID
     bInterfaceClass =    3
    HID Parser Claim: 09 04 02 00 01 03 00 00 00 09 21 11 01 00 01 22 5D 00 07 05 83 03 20 00 02
    report descriptor size = 93
      endpoint = 83
       size = 32
       interval = 2
    new_Pipe
     best_bandwidth = 4, at offset = 1, shift= 0
    Descriptor 33 = HID
      mesg = A21
    timer event (20824 us): Debounce Timer, this = 200073A0, timer = 200076B8
    getstatus, port = 3
    05 01 09 02 A1 01 85 02 09 01 A1 00 95 10 75 01 15 00 25 01 05 09 19 01 29 10 81 02 95 02 75 0C 16 01 F8 26 FF 07 05 01 09 30 09 31 81 06 95 01 75 08 15 81 25 7F 09 38 81 06 95 01 05 0C 0A 38 02 81 06 C0 C0 05 0C 09 01 A1 01 85 03 95 02 75 10 15 01 26 FF 02 19 01 2A FF 02 81 00 C0 05 01 09 80 A1 01 85 04 95 01 75 02 15 01 25 03 09 82 09 81 09 83 81 00 75 06 81 03 C0 06 BC FF 09 88 A1 01 85 08 95 01 75 08 15 01 26 FF 00 19 01 29 FF 81 00 C0
      mesg = 22000681
    find_driver
      driver 20007B2C
      driver 20007DCC
      driver 20008FEC
    find_driver
      driver 20007B2C
    find_driver
      driver 20007B2C
    find_driver
      driver 20007B2C
      driver 20007DCC
      driver 20008FEC
    06 00 FF 09 01 A1 01 85 10 95 06 75 08 15 00 26 FF 00 09 01 81 00 09 01 91 00 C0 06 00 FF 09 02 A1 01 85 11 95 13 75 08 15 00 26 FF 00 09 02 81 00 09 02 91 00 C0 06 00 FF 09 04 A1 01 85 20 95 0E 75 08 15 00 26 FF 00 09 41 81 00 09 41 91 00 85 21 95 1F 09 42 81 00 09 42 91 00 C0
      mesg = 22000681
    Found top level collection FF000001
    find_driver
      driver 20007B2C
      driver 20007DCC
      driver 20008FEC
    No Driver claimed topusage: FF000001
    Found top level collection FF000002
    find_driver
      driver 20007B2C
      driver 20007DCC
      driver 20008FEC
    No Driver claimed topusage: FF000002
    Found top level collection FF000004
    find_driver
      driver 20007B2C
      driver 20007DCC
      driver 20008FEC
    No Driver claimed topusage: FF000004
    01 03 00 00
    New Port Status
      status=301  port=3
      state=6
      Device is present:
      Has Power
    sending reset
    send_setreset
    status = 8
    getstatus, port = 3
    03 03 10 00
    New Port Status
      state=7
      Device is present:
      Has Power
    PORT_RECOVERY
    new_Pipe
    enumeration:
    enumeration:
    enumeration:
    Device Descriptor:
    enumeration:
    enumeration:
    Manufacturer: Dell
    enumeration:
    enumeration:
    enumeration:
        NumInterfaces = 1
        Interface = 0
        Endpoint = 1 IN
        Type = Interrupt
        Max Size = 8
    enumeration:
    ep = 81
    packet size = 8
    new_Pipe
     best_bandwidth = 5, at offset = 2, shift= 3
    Descriptor 33 = HID
      mesg = A21
      manufacturer: Dell
    Jan 2022
    10
    if i compare the debug logs the following error message is only present in the microsoft wireless reciever debug logs have someone a clue what that error means ?
    ERROR Followup
    ERROR Followup
    come on guys it's just a microsoft reciever and a wired dell keyboard if we not get microsoft+dell products running we will never fly to the mars ;-)
    Senior Member wwatson's Avatar
    Aug 2017
    744
    @epi - A quick question. I assume you are using a hub. How many physical device are plugged into the wireless receivers, wired keyboard etc.. In the sketch above I noticed that you have:
    USBHub hub1(myusb);
    USBHub hub2(myusb);
    That will support two physical USB devices plugged into the hub. If you use a third port you will need to add another hub port define:
    USBHub hub3(myusb);
    Just a shot in the dark
    Edit: Forget this post I did not fully understand what you were doing. It's not going to help
    Jan 2022
    10
    its a powered 4 port hub and i also tested it with another unpowered 4 port hub.
    just to prove you are wrong i added some USBHub to the code but it not resolve the issue.
    i thinks as the error message in the debug log shows there is a KeyboardController Callback error.
    Hub Example 1
    port1: microsoft reciever (mouse) https://www.amazon.com/Microsoft-Wir.../dp/B002DPUUL4
    port2: dell keyboard (not working):
    port3: empty
    port4: empty
    Hub Example 2:
    port1: logitech reciever (mouse)
    port2: dell keyboard (working)
    port3: empty
    port4: empty
    Aug 2017
    744
    Quote Originally Posted by epi View Post
    Hub Example 1
    port3: empty
    port4: empty
    Hub Example 2:
    port3: empty
    port4: empty
    See the edit in my post. I do not have a Microsoft wireless keyboard/mouse combo but I do have Logitech ones and wired keyboards and wired mice. Going to play with this using your sketch.
    Jan 2022
    10
    i also tried to set the microsoft reciever to "PROTOCOL Boot" with keyboard.cpp but i get the same KeyboardController Callback "Error Followup".
    10,979
    Sorry distracted with other things...
    Who knows, maybe one or more resources are taken up...
    That is if you have two hub objects, each hub actually sets up for N connections, but depending on your Hub some actually are composite hubs. That is a 8 connection hub may be built up with 2 or 3 smaller hubs...
    Also some devices like keyboards have built in hub... I have a dell one like that...
    Also some devices may consume/use multiple HID devices....
    If me, I would turn on debug code look at the define at the start of USBHost_t36.h is a define that turns out lots of the debugging outputs, I would turn that on and see if it shows up anything.
    Also checking each object like hid to see if looks like they are free or not...
    Jan 2022
    10
    hello KurtE thanks for your response
    if i enable all debug msg in USBHost_t36h and ehci.cpp the only output is that there is a USB Error but i don't know where to change the code to just skip the device as keyboard if there is any error.
    a workaround maybe would be if the microsoft reciever is just used as mouse and not also as keyboard by the USBHost_t36h if there is any usb error found or just skip it as keyboard by vendorid.
    ISR: 8C083
     USB Error
     USB Periodic
    ERROR Followup
    10,979
    ISR: 8C083
     USB Error
     USB Periodic
    ERROR Followup
    Which product is this? i.e. do you have link for amazon...
    I hsve used/tested on Microsoft combination mouse, keyboard in the past: Ones like: https://smile.amazon.com/Microsoft-E.../dp/B00DUV01SC
    But they probably have many different versions..
    Jan 2022
    10
    Microsoft Wireless Mobile Mouse 4000
    Same problem, but only for some mice/kbs. Bump.
    bump
    10 chars
    Edit: I am thinking it has to do with occupation order of KeyboardController
    10,979
    Sorry, but hard to know what is going on with this. And details about some of thest things.
    For example the Microsoft Mouse, is it it's own hook up that emulates normal wired keyboard? I have some MS combo units that did that.
    Or is it for example Bluetooth? And then if it is Bluetooth, and it uses BLE, then we don't have support yet. I have such a mouse that does not work.
    So often times we end up needing to know exactly which device as they may not all talk the same.
    I completely understand, but for some people that used a Teensy 4.1 board (that I know of) it works out of the box, and other just wont (depending on their setup), talking Mouse + Keyboard (and USB Hub).
    For example I had a similar issue on this setup: https://forum.pjrc.com/threads/70452...rly-(USB-Host)
    Mostly both work individually connected, but not via USB Hub indidivually connected.
    "Mouse only" works 100% of the time, usually.
    What bothers me the most currently is that for example the Logitech G Pro Superlight (a popular gaming mouse; the only mouse that does this in 20+ mices!), keeps holding the Control Button on a Keyboard Interface, as well as keeps turning off after a while and never wakes up (internal battery save mode). Although directly connected to a Windows/Linux/Mac machine it works perfectly fine, also wakes again w/o additional software.
    If you could look into the Logitech G Pro Superlight (with a KeyboardController inside the flashed script; https://www.amazon.de/Logitech-Gamin.../dp/B07W4DHKTD), that be great.
    I would love to discuss this and help fix those nasty bugs.
    Last version I tested these things was on 1.56.
    10,979
    With some of these mice, I have purchased different ones. But not sure about $150 mouse 8)
    Might be interesting to see what messages it generates when plugged in. and/or turned on. And compare it to others
    I do not have any access to the Logitech Superlight right now, but this is a USBLyzer dump from the mouse:
    https://www.file-upload.net/download...ight.html.html
    Its a bit more detailed compared to Teensy HID dumper.
    @KurtE
    Okay, I did some more testings, sometimes it picks up the devices in the wrong order. Making the kb light up, but not work. Replugging the hub (with Mouse+KB) multiple times fixes it.
    For example it takes the Keyboard from your mouse as keyboardcontroller, which makes these things happen (my assumption). The MouseController does not have these issues, because only one exists (from the Mouse).
    Maybe its possible to prioritize keyboards first?
    I think one possible way to fix this is to occupy the KeyboardController with a HID device without Mouse Interface first before the one with mouse interface.
    bump 10 chars
    10,979
    Sorry, my anti-virus stuff does not allow access to that site to look at it...
    Also, in this thread: https://forum.pjrc.com/threads/70824...l=1#post310597
    I put up a more enhanced HID dumper program. Takes changes to USBHost_t36 to expose the HID Descriptor.
    Later in that thread, I showed where I put in a Pull Request for it, which should give you more up to date versions.
    16,370
    @KurtE - my computer didn't stop my getting to the post #20 'downloader' (and didn't see an obvious attack) it displayed an HTML that won't attach as a file. Here is a TEXT copy of the content.
    USB-Verbundgerät
    Connection Status	Device connected
    Current Configuration	1
    Speed	Full (12 Mbit/s)
    Device Address	30
    Number Of Open Pipes	3
    Device Descriptor USB Receiver
    Offset	Field	Size	Value	Description
    0	bLength	1	12h
    1	bDescriptorType	1	01h	Device
    2	bcdUSB	2	0200h	USB Spec 2.0
    4	bDeviceClass	1	00h	Class info in Ifc Descriptors
    5	bDeviceSubClass	1	00h
    6	bDeviceProtocol	1	00h
    7	bMaxPacketSize0	1	40h	64 bytes
    8	idVendor	2	046Dh	Logitech, Inc.
    10	idProduct	2	C547h
    12	bcdDevice	2	0402h	4.02
    14	iManufacturer	1	01h	"Logitech"
    15	iProduct	1	02h	"USB Receiver"
    16	iSerialNumber	1	00h
    17	bNumConfigurations	1	01h
    Configuration Descriptor 1 Bus Powered, 98 mA
    0	bLength	1	09h
    1	bDescriptorType	1	02h	Configuration
    2	wTotalLength	2	0054h
    4	bNumInterfaces	1	03h
    5	bConfigurationValue	1	01h
    6	iConfiguration	1	04h	"MPR04.02_B0009"
    7	bmAttributes	1	A0h	Bus Powered, Remote Wakeup
    4..0: Reserved		...00000
    5: Remote Wakeup		..1..... 	Yes
    6: Self Powered		.0...... 	No, Bus Powered
    7: Reserved (set to one)
    (bus-powered for 1.0)		1.......
    8	bMaxPower	1	31h	98 mA
    Interface Descriptor 0/0 HID, 1 Endpoint
    0	bLength	1	09h
    1	bDescriptorType	1	04h	Interface
    2	bInterfaceNumber	1	00h
    3	bAlternateSetting	1	00h
    4	bNumEndpoints	1	01h
    5	bInterfaceClass	1	03h	HID
    6	bInterfaceSubClass	1	01h	Boot Interface
    7	bInterfaceProtocol	1	02h	Mouse
    8	iInterface	1	00h
    HID Descriptor
    0	bLength	1	09h
    1	bDescriptorType	1	21h	HID
    2	bcdHID	2	0111h	1.11
    4	bCountryCode	1	00h
    5	bNumDescriptors	1	01h
    6	bDescriptorType	1	22h	Report
    7	wDescriptorLength	2	0053h	83 bytes
    Endpoint Descriptor 81 1 In, Interrupt, 1 ms
    0	bLength	1	07h
    1	bDescriptorType	1	05h	Endpoint
    2	bEndpointAddress	1	81h	1 In
    3	bmAttributes	1	03h	Interrupt
    1..0: Transfer Type		......11 	Interrupt
    7..2: Reserved		000000..
    4	wMaxPacketSize	2	0040h	64 bytes
    6	bInterval	1	01h	1 ms
    Interface Descriptor 1/0 HID, 1 Endpoint
    0	bLength	1	09h
    2	bInterfaceNumber	1	01h
    7	bInterfaceProtocol	1	01h	Keyboard
    8	iInterface	1	00h
    HID Descriptor
    0	bLength	1	09h
    7	wDescriptorLength	2	0085h	133 bytes
    Endpoint Descriptor 82 2 In, Interrupt, 1 ms
    0	bLength	1	07h
    2	bEndpointAddress	1	82h	2 In
    Interface Descriptor 2/0 HID, 1 Endpoint
    0	bLength	1	09h
    2	bInterfaceNumber	1	02h
    6	bInterfaceSubClass	1	00h
    7	bInterfaceProtocol	1	00h
    8	iInterface	1	00h
    HID Descriptor
    0	bLength	1	09h
    7	wDescriptorLength	2	0036h	54 bytes
    Endpoint Descriptor 83 3 In, Interrupt, 1 ms
    0	bLength	1	07h
    2	bEndpointAddress	1	83h	3 In
    Interface 0 HID Report Descriptor Mouse
    Item Tag (Value)	Raw Data
    Usage Page (Generic Desktop)	05 01
    Usage (Mouse)	09 02
    Collection (Application)	A1 01
        Usage (Pointer)	09 01
        Collection (Physical)	A1 00
            Report Count (16)	95 10
            Report Size (1)	75 01
            Logical Minimum (0)	15 00
            Logical Maximum (1)	25 01
            Usage Page (Button)	05 09
            Usage Minimum (Button 1)	19 01
            Usage Maximum (Button 16)	29 10
            Input (Data,Var,Abs,NWrp,Lin,Pref,NNul,Bit)	81 02
            Report Count (2)	95 02
            Report Size (16)	75 10
            Logical Minimum (-32767)	16 01 80
            Logical Maximum (32767)	26 FF 7F
            Usage (X)	09 30
            Usage (Y)	09 31
            Input (Data,Var,Rel,NWrp,Lin,Pref,NNul,Bit)	81 06
            Report Count (1)	95 01
            Report Size (8)	75 08
            Logical Minimum (-127)	15 81
            Logical Maximum (127)	25 7F
            Usage (Wheel)	09 38
            Usage Page (Consumer Devices)	05 0C
            Usage (AC Pan)	0A 38 02
        End Collection	C0
        Usage Page (Vendor-Defined 1)	06 00 FF
        Usage (Vendor-Defined 241)	09 F1
        Report Count (5)	95 05
        Logical Maximum (255)	26 FF 00
        Input (Data,Ary,Abs)	81 00
    End Collection	C0
    Interface 1 HID Report Descriptor Keyboard
    Usage (Keyboard)	09 06
        Report ID (1)	85 01
        Usage Page (Keyboard/Keypad)	05 07
        Usage Minimum (Keyboard Left Control)	19 E0
        Usage Maximum (Keyboard Right GUI)	29 E7
        Report Count (8)	95 08
        Usage Page (LEDs)	05 08
        Usage Minimum (Num Lock)	19 01
        Usage Maximum (Kana)	29 05
        Output (Data,Var,Abs,NWrp,Lin,Pref,NNul,NVol,Bit)	91 02
        Report Size (3)	75 03
        Output (Cnst,Var,Abs,NWrp,Lin,Pref,NNul,NVol,Bit)	91 03
        Report Count (112)	95 70
        Usage Minimum (Keyboard a and A)	19 04
        Usage Maximum (Keyboard F24)	29 73
        Usage Minimum (Keyboard International 1)	19 87
        Usage Maximum (Keyboard International 5)	29 8B
        Report Count (3)	95 03
        Usage Minimum (Keyboard LANG1)	19 90
        Usage Maximum (Keyboard LANG3)	29 92
    End Collection	C0
    Usage (Consumer Control)	09 01
        Report ID (3)	85 03
        Logical Minimum (1)	15 01
        Logical Maximum (767)	26 FF 02
        Usage Minimum (Consumer Control)	19 01
        Usage Maximum	2A FF 02
    End Collection	C0
    Usage (System Control)	09 80
        Report ID (4)	85 04
        Report Size (2)	75 02
        Logical Maximum (3)	25 03
        Usage (System Sleep)	09 82
        Usage (System Power Down)	09 81
        Usage (System Wake Up)	09 83
        Usage (Undefined)	09 9B
        Report Size (5)	75 05
        Input (Cnst,Var,Abs,NWrp,Lin,Pref,NNul,Bit)	81 03
    End Collection	C0
    Interface 2 HID Report Descriptor Vendor-Defined 1
    Usage (Vendor-Defined 1)	09 01
        Report ID (16)	85 10
        Report Count (6)	95 06
        Output (Data,Ary,Abs,NWrp,Lin,Pref,NNul,NVol,Bit)	91 00
    End Collection	C0
    Usage (Vendor-Defined 2)	09 02
        Report ID (17)	85 11
        Report Count (19)	95 13
    End Collection	C0
    This report was generated by USBlyzer
