Results 1 to 4 of 4
Thread: Doubt Regarding setRX function in Teensy 4.0
    Hello all,
    I was trying to explore how to use the setTX() and setRX() functions using teensy4.0.
    from the following link: https://www.pjrc.com/teensy/td_uart.html , i got the information that I can use pins 1, 2, 3, 4, 5, 7, 8, 30, 31, 32, 33 and 0, 34, 35, 36, 37, 38, 39 as alternate RX pins for Serial1. I have written the following two programs and uploaded them on two teensy 4.0's.
    1st Program uploaded on the 1st teensy:
    char input;
      Serial1.setRX(4);
      Serial1.begin(9600);
      if (Serial1.available() > 0)
        input = Serial1.read();
        Serial.println(input);
      if (Serial.available() > 0)
        input = Serial.read();
    2nd Program uploaded on the second teensy:
      Serial1.print('a');
    I have connected pin 1 (TX for Serial1) of the second teensy to pin 4 of the first teensy. I was expecting teensy 1 to print 'a' to the terminal, but it did not happen.
    When I connected the wire to pin0 (default RX for Serial1) it started printing 'a' to the console. This means that the RX pin of Serial1 has not been re-configured to pin 4.
    Could someone point out the mistake that I have done in my code or point me in the right direction?
    Additionally, as per the link that I shared above, the TX pins in teensy 4.0 don't have any alternate pins and hence the setTX() function is of no use in teensy4.0. Am I correct?
    Thank you
    Hi All,
    A quick update regarding this.
    the program works fine if the setRX() function is used after the Serial1.begin() fn.
    In the following webpage: https://www.pjrc.com/teensy/td_uart.html (Accessed on 29th Jan, 2023) the following is said about the setRX() fn: "This function may be called before Serial1.begin(baud), to pre-configure the pin used." This might need to updated as it will result in the problem I mentioned in my orignal post.
    Hope this helps the people facing a similar problem.
    Regards
    27,997
    Maybe we have a bug with setRX() and begin() when selecting the XBAR pins?
    Yes, looks like it.
