My setup:
Raspberry Pi 3B + Teensy 4.0 connected via USB.
Bottom line the Teensy will not connect to the Pi. Note I have not made any changes in the Pi to accommodate the Teensy. Note adding 00-teensy.rules to /etc/udev/rules.d does not change results.
Really don't know where to go from here so looking for clear direction as I'm probably missing something very basic.
Initial configuration of Teensy performed on Windows 10 laptop running Arduino IDE.
Detailed steps:
1. Enter and Upload the following basic program to the Teensy:
2. Code produces expected output on both the Arduino Serial Monitor and also when I connect to the same laptop USB port with Putty (COM4).
3. Unplug and reattach to Laptop - code restarts and produces same output.
4. Raspberry Pi has a Pi Keyboard/Mouse on one USB port.
5. Unplug Teensy from Laptop and plug into Raspberry USB port.
6. Restart Pi with Adruino connected produces a slightly different dmesg output:
Detailed steps:
while (!Serial) {
; // wait for serial port to connect.
Serial.println("CONNECTED!!!");
Serial.println("Hello World");
while (!Serial) {
CONNECTED!!!
Hello World
Hello World
Hello World
Hello World
Hello World
Hello World
Hello World
Hello World
pi@pi2:~ $ lsusb -t
/: Bus 01.Port 1: Dev 1, Class=root_hub, Driver=dwc_otg/1p, 480M
|__ Port 1: Dev 2, If 0, Class=Hub, Driver=hub/5p, 480M
|__ Port 1: Dev 3, If 0, Class=Vendor Specific Class, Driver=smsc95xx, 480M
|__ Port 3: Dev 4, If 0, Class=Hub, Driver=hub/4p, 480M
|__ Port 1: Dev 5, If 0, Class=Human Interface Device, Driver=usbhid, 1.5M
|__ Port 1: Dev 5, If 1, Class=Human Interface Device, Driver=usbhid, 1.5M
|__ Port 2: Dev 6, If 0, Class=Human Interface Device, Driver=usbhid, 1.5M
pi@pi2:~ $ ls /dev/tty*
/dev/tty /dev/tty19 /dev/tty3 /dev/tty40 /dev/tty51 /dev/tty62
/dev/tty0 /dev/tty2 /dev/tty30 /dev/tty41 /dev/tty52 /dev/tty63
/dev/tty1 /dev/tty20 /dev/tty31 /dev/tty42 /dev/tty53 /dev/tty7
/dev/tty10 /dev/tty21 /dev/tty32 /dev/tty43 /dev/tty54 /dev/tty8
/dev/tty11 /dev/tty22 /dev/tty33 /dev/tty44 /dev/tty55 /dev/tty9
/dev/tty12 /dev/tty23 /dev/tty34 /dev/tty45 /dev/tty56 /dev/ttyAMA0
/dev/tty13 /dev/tty24 /dev/tty35 /dev/tty46 /dev/tty57 /dev/ttyprintk
/dev/tty14 /dev/tty25 /dev/tty36 /dev/tty47 /dev/tty58
/dev/tty15 /dev/tty26 /dev/tty37 /dev/tty48 /dev/tty59
/dev/tty16 /dev/tty27 /dev/tty38 /dev/tty49 /dev/tty6
/dev/tty17 /dev/tty28 /dev/tty39 /dev/tty5 /dev/tty60
/dev/tty18 /dev/tty29 /dev/tty4 /dev/tty50 /dev/tty61
pi@pi2:~ $ dmesg| grep usb
[ 0.133977] usbcore: registered new interface driver usbfs
[ 0.134059] usbcore: registered new interface driver hub
[ 0.134227] usbcore: registered new device driver usb
[ 1.548199] usbcore: registered new interface driver lan78xx
[ 1.548424] usbcore: registered new interface driver smsc95xx
[ 2.537758] dwc_otg 3f980000.usb: DWC OTG Controller
[ 2.544099] dwc_otg 3f980000.usb: new USB bus registered, assigned bus number 1
[ 2.550529] dwc_otg 3f980000.usb: irq 56, io mem 0x00000000
[ 2.570122] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.04
[ 2.576609] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.583031] usb usb1: Product: DWC OTG Controller
[ 2.589445] usb usb1: Manufacturer: Linux 5.4.79-v7+ dwc_otg_hcd
[ 2.595795] usb usb1: SerialNumber: 3f980000.usb
[ 2.616799] usbcore: registered new interface driver usb-storage
[ 2.689153] usbcore: registered new interface driver usbhid
[ 2.695532] usbhid: USB HID core driver
[ 3.036151] usb 1-1: new high-speed USB device number 2 using dwc_otg
[ 3.286522] usb 1-1: New USB device found, idVendor=0424, idProduct=9514, bcdDevice= 2.00
[ 3.293035] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 3.626175] usb 1-1.1: new high-speed USB device number 3 using dwc_otg
[ 3.756571] usb 1-1.1: New USB device found, idVendor=0424, idProduct=ec00, bcdDevice= 2.00
[ 3.763060] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 3.870763] smsc95xx 1-1.1:1.0 eth0: register 'smsc95xx' at usb-3f980000.usb-1.1, smsc95xx USB 2.0 Ethernet, b8:27:eb:a9:1d:ce
[ 3.976162] usb 1-1.3: new high-speed USB device number 4 using dwc_otg
[ 4.107824] usb 1-1.3: New USB device found, idVendor=05e3, idProduct=0610, bcdDevice=32.98
[ 4.114728] usb 1-1.3: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 4.121656] usb 1-1.3: Product: USB2.0 Hub
[ 4.466277] usb 1-1.3.1: new low-speed USB device number 5 using dwc_otg
[ 4.756802] usb 1-1.3.1: New USB device found, idVendor=04d9, idProduct=0006, bcdDevice= 1.40
[ 4.764261] usb 1-1.3.1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 4.771759] usb 1-1.3.1: Product: RPI Wired Keyboard 4
[ 4.779111] usb 1-1.3.1: Manufacturer:
[ 4.856661] input: RPI Wired Keyboard 4 as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.3/1-1.3.1/1-1.3.1:1.0/0003:04D9:0006.0001/input/input0
[ 4.927047] hid-generic 0003:04D9:0006.0001: input,hidraw0: USB HID v1.11 Keyboard [ RPI Wired Keyboard 4] on usb-3f980000.usb-1.3.1/input0
[ 4.989723] input: RPI Wired Keyboard 4 as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.3/1-1.3.1/1-1.3.1:1.1/0003:04D9:0006.0002/input/input1
[ 5.066622] hid-generic 0003:04D9:0006.0002: input,hidraw1: USB HID v1.11 Device [ RPI Wired Keyboard 4] on usb-3f980000.usb-1.3.1/input1
[ 5.176181] usb 1-1.3.2: new low-speed USB device number 6 using dwc_otg
[ 5.322541] usb 1-1.3.2: New USB device found, idVendor=093a, idProduct=2510, bcdDevice= 1.00
[ 5.331238] usb 1-1.3.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 5.339941] usb 1-1.3.2: Product: USB Optical Mouse
[ 5.348637] usb 1-1.3.2: Manufacturer: PixArt
[ 5.362760] input: PixArt USB Optical Mouse as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.3/1-1.3.2/1-1.3.2:1.0/0003:093A:2510.0003/input/input2
[ 5.372552] hid-generic 0003:093A:2510.0003: input,hidraw2: USB HID v1.11 Mouse [PixArt USB Optical Mouse] on usb-3f980000.usb-1.3.2/input0
[ 8.450629] usbcore: registered new interface driver brcmfmac
Activity observed on 'udevadm monitor'
No change recorded in ls /dev/tty* Output
No change recorded in lsusb -t Output
Incremental output from dmesg follows:
[ 712.946142] usb 1-1.2: new high-speed USB device number 7 using dwc_otg
[ 713.486143] usb 1-1.2: device not accepting address 7, error -71
[ 714.396371] usb 1-1-port2: Cannot enable. Maybe the USB cable is bad?
[ 714.396503] usb 1-1-port2: attempt power cycle
[ 715.676278] usb 1-1-port2: Cannot enable. Maybe the USB cable is bad?
[ 715.776121] usb 1-1.2: new high-speed USB device number 10 using dwc_otg
[ 716.216195] usb 1-1.2: device not accepting address 10, error -71
[ 716.216345] usb 1-1-port2: unable to enumerate USB device
[ 716.216558] usb 1-1.3-port1: cannot reset (err = -71)
[ 716.216790] usb 1-1.3-port1: cannot reset (err = -71)
[ 716.216826] usb 1-1.3: USB disconnect, device number 4
[ 716.216860] usb 1-1.3.1: USB disconnect, device number 5
[ 716.216941] usb 1-1.3-port1: cannot reset (err = -71)
[ 716.598782] usb 1-1.3.2: USB disconnect, device number 6
[ 717.056199] usb 1-1.3: new high-speed USB device number 11 using dwc_otg
[ 717.187678] usb 1-1.3: New USB device found, idVendor=05e3, idProduct=0610, bcdDevice=32.98
[ 717.187692] usb 1-1.3: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 717.187699] usb 1-1.3: Product: USB2.0 Hub
[ 717.486122] usb 1-1.2: new high-speed USB device number 12 using dwc_otg
[ 718.396348] usb 1-1-port2: Cannot enable. Maybe the USB cable is bad?
[ 718.496128] usb 1-1.2: new high-speed USB device number 14 using dwc_otg
[ 719.406287] usb 1-1-port2: Cannot enable. Maybe the USB cable is bad?
[ 719.406395] usb 1-1-port2: attempt power cycle
[ 719.436398] usb 1-1.3-port1: cannot reset (err = -71)
[ 719.436533] usb 1-1.3-port1: cannot reset (err = -71)
[ 719.436657] usb 1-1.3-port1: cannot reset (err = -71)
[ 719.436782] usb 1-1.3-port1: cannot reset (err = -71)
[ 719.436788] usb 1-1.3-port1: Cannot enable. Maybe the USB cable is bad?
[ 719.436922] usb 1-1.3-port1: cannot disable (err = -71)
[ 719.437072] usb 1-1.3-port1: cannot reset (err = -71)
[ 719.437189] usb 1-1.3-port1: cannot reset (err = -71)
[ 719.437314] usb 1-1.3-port1: cannot reset (err = -71)
[ 719.437439] usb 1-1.3-port1: cannot reset (err = -71)
[ 719.437562] usb 1-1.3-port1: cannot reset (err = -71)
[ 719.437568] usb 1-1.3-port1: Cannot enable. Maybe the USB cable is bad?
[ 719.437686] usb 1-1.3-port1: cannot disable (err = -71)
[ 719.437697] usb 1-1.3-port1: attempt power cycle
[ 720.656300] usb 1-1-port2: Cannot enable. Maybe the USB cable is bad?
[ 721.566408] usb 1-1-port2: Cannot enable. Maybe the USB cable is bad?
[ 721.566561] usb 1-1-port2: unable to enumerate USB device
[ 721.566859] usb 1-1.3-port1: cannot reset (err = -71)
[ 721.567023] usb 1-1.3-port1: cannot reset (err = -71)
[ 721.567085] usb 1-1.3: USB disconnect, device number 11
[ 721.567192] usb 1-1.3-port1: cannot reset (err = -71)
[ 721.886148] usb 1-1.3: new high-speed USB device number 20 using dwc_otg
[ 722.017910] usb 1-1.3: New USB device found, idVendor=05e3, idProduct=0610, bcdDevice=32.98
[ 722.017926] usb 1-1.3: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 722.017933] usb 1-1.3: Product: USB2.0 Hub
[ 722.336130] usb 1-1.3.1: new low-speed USB device number 21 using dwc_otg
[ 722.617385] usb 1-1.3.1: New USB device found, idVendor=04d9, idProduct=0006, bcdDevice= 1.40
[ 722.617408] usb 1-1.3.1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 722.617423] usb 1-1.3.1: Product: RPI Wired Keyboard 4
[ 722.617436] usb 1-1.3.1: Manufacturer:
[ 722.687046] input: RPI Wired Keyboard 4 as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.3/1-1.3.1/1-1.3.1:1.0/0003:04D9:0006.0004/input/input3
[ 722.757132] hid-generic 0003:04D9:0006.0004: input,hidraw0: USB HID v1.11 Keyboard [ RPI Wired Keyboard 4] on usb-3f980000.usb-1.3.1/input0
[ 722.810859] input: RPI Wired Keyboard 4 as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.3/1-1.3.1/1-1.3.1:1.1/0003:04D9:0006.0005/input/input4
[ 722.876544] hid-generic 0003:04D9:0006.0005: input,hidraw1: USB HID v1.11 Device [ RPI Wired Keyboard 4] on usb-3f980000.usb-1.3.1/input1
[ 722.976174] usb 1-1.3.2: new low-speed USB device number 22 using dwc_otg
[ 723.122664] usb 1-1.3.2: New USB device found, idVendor=093a, idProduct=2510, bcdDevice= 1.00
[ 723.122678] usb 1-1.3.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 723.122686] usb 1-1.3.2: Product: USB Optical Mouse
[ 723.122694] usb 1-1.3.2: Manufacturer: PixArt
[ 723.128062] input: PixArt USB Optical Mouse as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.3/1-1.3.2/1-1.3.2:1.0/0003:093A:2510.0006/input/input5
[ 723.128469] hid-generic 0003:093A:2510.0006: input,hidraw2: USB HID v1.11 Mouse [PixArt USB Optical Mouse] on usb-3f980000.usb-1.3.2/input0
[ 3.996200] usb 1-1.2: new high-speed USB device number 4 using dwc_otg
[ 4.976177] usb 1-1.2: device descriptor read/64, error -71
[ 6.006474] usb 1-1-port2: Cannot enable. Maybe the USB cable is bad?
[ 6.916460] usb 1-1-port2: Cannot enable. Maybe the USB cable is bad?
[ 6.916579] usb 1-1-port2: attempt power cycle
[ 8.176494] usb 1-1-port2: Cannot enable. Maybe the USB cable is bad?
[ 8.235245] usbcore: registered new interface driver brcmfmac
[ 9.088121] usb 1-1-port2: Cannot enable. Maybe the USB cable is bad?
[ 9.088275] usb 1-1-port2: unable to enumerate USB device
