Results 1 to 5 of 5
Thread: Teensy 4.1 serial host can't recognize another teensy
    Jan 2022
    3
    Hi everyone,
    for a project I need to control a few different systems with the host serial of teensy.
    Among these systems I will have to be able to control another Teensy with a Hub.
    I soldered a usb connector to the USB host pins of my master teensy. And can recognize successfully some commercial USB thermometers and hubs.
    I am using the library USBHost_t36 with the exemple USBHost_t36/Test/SerialTest.ino
    If I plug a hub and my thermometer (which send the line #CT periodically before I unplug it in my test). The program recognize it without any problem.
    USB Host Testing - Serial
    *** Device Hub1 1a40:101 - connected ***
      product: USB 2.0 Hub
    *** Device Hub2 1a40:101 - connected ***
    #CT
    #CT
    #CT
    *** Device USerial 483:5740 - connected ***
      manufacturer: STMicroelectronics
      product: STM32 Virtual COM Port
      Serial: CT000
    #CT
    #CT
    #CT
    #CT
    *** Device USerial - disconnected ***
    But when I try to plug another Teensy to my USB host nothing happen. (same thing with the HUB or without).
    I digged a bit in the code and uncommented the line :
    //#define USBHOST_PRINT_DEBUG in USBHost_t36.h to get a bit more informations. When I plug the teensy I get:
    USB2 PLL running
     reset waited 6
    USBHS_ASYNCLISTADDR = 0
    USBHS_PERIODICLISTBASE = 20005000
    periodictable = 20005000
    port change: 10001803
        connect
    port change: 1C001002
        disconnect
        connect
      begin reset
    port change: 18001205
      port enabled
      end recovery
    new_Device: 480 Mbit/sec
    new_Pipe
    enumeration:
    enumeration:
    enumeration:
    Device Descriptor:
      12 01 00 02 02 00 00 40 C0 16 83 04 80 02 01 02 03 01
        VendorID = 16C0, ProductID = 0483, Version = 0280
        Class/Subclass/Protocol = 2 / 0 / 0
        Number of Configurations = 1
    enumeration:
    enumeration:
    Manufacturer: Teensyduino
    enumeration:
    Product: USB Serial
    enumeration:
    Serial Number: 8823250
    enumeration:
    Config data length = 67
    enumeration:
    Configuration Descriptor:
      09 02 43 00 02 01 00 C0 32
        NumInterfaces = 2
        ConfigurationValue = 1
      09 04 00 00 01 02 02 01 00
        Interface = 0
        Number of endpoints = 1
        Class/Subclass/Protocol = 2 / 2 / 1
      05 24 00 10 01
      05 24 01 01 01
      04 24 02 06
      05 24 06 00 01
      07 05 82 03 10 00 05
        Endpoint = 2 IN
        Type = Interrupt
        Max Size = 16
        Polling Interval = 5
      09 04 01 00 02 0A 00 00 00
        Interface = 1
        Number of endpoints = 2
        Class/Subclass/Protocol = 10 / 0 / 0
      07 05 03 02 00 02 00
        Endpoint = 3 OUT
        Type = Bulk
        Max Size = 512
        Polling Interval = 0
      07 05 84 02 00 02 00
        Endpoint = 4 IN
        Type = Bulk
        Max Size = 512
    enumeration:
    USBHub memory usage = 960
    USBHub claim_device this=20003C40
    USBHub claim_device this=20003880
    HIDParser claim this=20002C40
    HIDParser claim this=20003260
    HIDParser claim this=200046C0
    USBSerial claim this=20004080
    vid=16C0, pid=483, bDeviceClass = 2, bDeviceSubClass = 0, bDeviceProtocol = 0
    09 04 00 00 01 02 02 01 00 05 24 00 10 01 05 24 01 01 01 04 24 02 06 05 24 06 00 01 07 05 82 03 10 00 05 09 04 01 00 02 0A 00 00 00 07 05 03 02 00 02 00 07 05 84 02 00 02 00
      Interface is Serial
        CS_INTERFACE - subtype: 0 10 1 - Header Functional Descriptor
        CS_INTERFACE - subtype: 1 1 1 - Call Management Functional
        CS_INTERFACE - subtype: 2 6 - Abstract Control Management
        CS_INTERFACE - subtype: 6 0 1  - union Functional
        Interface: 1
         Endpoint: 3
          tx_size = 512
         Endpoint: 84
          rx_size = 512
      exited loop rx:4, tx:3
    Descriptor 4 = INTERFACE
    Descriptor 36 =  ???
    Descriptor 36 =  ???
    Descriptor 36 =  ???
    Descriptor 36 =  ???
    Descriptor 5 = ENDPOINT
    For comparison if I do the same with the termometer I get that:
    USB2 PLL running
     reset waited 6
        connect
        disconnect
        connect
      begin reset
    port change: 10001005
      port enabled
      end recovery
    new_Device: 12 Mbit/sec
    new_Pipe
    enumeration:
    enumeration:
    enumeration:
    Device Descriptor:
      12 01 00 02 02 00 00 40 83 04 40 57 00 02 01 02 03 01
        VendorID = 0483, ProductID = 5740, Version = 0200
    enumeration:
    enumeration:
    Manufacturer: STMicroelectronics
    enumeration:
    Product: STM32 Virtual COM Port
    enumeration:
    Serial Number: CT00001
    enumeration:
    enumeration:
      09 02 43 00 02 01 00 C0 FA
        NumInterfaces = 2
        Interface = 0
      05 24 00 10 01
      05 24 01 00 01
      04 24 02 02
      05 24 06 00 01
      07 05 82 03 08 00 FF
        Endpoint = 2 IN
        Type = Interrupt
        Max Size = 8
        Polling Interval = 255
        Interface = 1
      07 05 03 02 40 00 00
        Endpoint = 3 OUT
        Type = Bulk
        Max Size = 64
      07 05 81 02 40 00 00
        Endpoint = 1 IN
        Type = Bulk
        Max Size = 64
    enumeration:
    vid=483, pid=5740, bDeviceClass = 2, bDeviceSubClass = 0, bDeviceProtocol = 0
    09 04 00 00 01 02 02 01 00 05 24 00 10 01 05 24 01 00 01 04 24 02 02 05 24 06 00 01 07 05 82 03 08 00 FF 09 04 01 00 02 0A 00 00 00 07 05 03 02 40 00 00 07 05 81 02 40 00 00
      Interface is Serial
        CS_INTERFACE - subtype: 1 0 1 - Call Management Functional
        CS_INTERFACE - subtype: 2 2 - Abstract Control Management
        Interface: 1
         Endpoint: 3
          tx_size = 64
         Endpoint: 81
          rx_size = 64
      exited loop rx:1, tx:3
      rx buffer size:196
      tx buffer size:196
    new_Pipe
    new_Pipe
    Control - CDCACM DTR...
    *** Device USERIAL1 483:5740 - connected ***
      Serial: CT000
    control callback (serial) 6
    CDCACM setup: 00 C2 01 00 00 00 08
    control callback (serial) 4
    Control - 0x21,0x22, 0x3
    control callback (serial) 0
    rx token: 803B8100 transfer length: 64 len:5 - 23 43
    rx: 23 43 54 0D 0A
    #CT
    rx token: 3B8100 transfer length: 64 len:5 - 23 43
    rx: 23 43 54 0D 0A
    #CT
    rx: 23 43 54 0D 0A
    #CT
    rx: 23 43 54 0D 0A
    #CT
    rx: 23 43 54 0D 0A
    #CT
    rx: 23 43 54 0D 0A
    #CT
    rx: 23 43 54 0D 0A
    #CT
    rx: 23 43 54 0D 0A
    #CT
    rx: 23 43 54 0D 0A
    #CT
    rx: 23 43 54 0D 0A
    #CT
    rx: 23 43 54 0D 0A
    #CT
    rx: 23 43 54 0D 0A
    #CT
    rx: 23 43 54 0D 0A
    #CT
    rx: 23 43 54 0D 0A
    #CT
    rx: 23 43 54 0D 0A
    #CT
    rx: 23 43 54 0D 0A
    #CT
    rx: 23 43 54 0D 0A
    #CT
    rx: 23 43 54 0D 0A
    #CT
    rx: 23 43 54 0D 0A
    #CT
    rx: 23 43 54 0D 0A
    #CT
    rx: 23 43 54 0D 0A
    #CT
    rx: 23 43 54 0D 0A
    #CT
    rx: 23 43 54 0D 0A
    #CT
    rx: 23 43 54 0D 0A
    #CT
    rx: 23 43 54 0D 0A
    #CT
    rx: 23 43 54 0D 0A
    #CT
    rx: 23 43 54 0D 0A
    #CT
    rx: 23 43 54 0D 0A
    #CT
    rx: 23 43 54 0D 0A
    #CT
    It looks like some descriptors (Descriptor 36 = ???) are not recognized and the program just loop trying to get the missing informations.
    If someone has an idea how to proceed from here it would be helpful.
    Alex
    Feb 2020
    Dublin, Ireland
    81
    Hi Alex,
    I'm seeing a similar problem when connecting a Teensy 4.0 programmed as a MIDI device to a T4 USB Host port. In my case the same issue doesn't occur when connecting a T3.6 to the T4 USB Host port - so my issue occurs with High Speed USB and not with Full Speed USB, as with yours (one of your debug listings gives 480 Mbits/sec, while the other gives 12 Mbits/sec).
    All the best,
    Alan
    10,350
    You might try changing the example (or your sketch) from using USBSerial and instead try USBSerial_BigBuffer
    It was setup to handle at the 480 MBits and larger packet sizes
    Feb 2020
    Dublin, Ireland
    81
    Adding
    USBSerial_BigBuffer userial(myusb);
    does not help with my MIDI problem (USBHost_t36 and High Speed USB MIDI messages (pjrc.com)),
    All the best,
    Alan
    Jan 2022
    3
    indeed changing the line:
     USBSerial userial(myusb)
    by
    solved my problem.
    Thanks a lot KurtE for the help
    Alex
