Teensy 4.1 serial host can't recognize another teensy
AlexGrand
New member
Hi everyone,
for a project I need to control a few different systems with the host serial of teensy.
Among these systems I will have to be able to control another Teensy with a Hub.
I soldered a usb connector to the USB host pins of my master teensy. And can recognize successfully some commercial USB thermometers and hubs.
I am using the library USBHost_t36 with the exemple USBHost_t36/Test/SerialTest.ino
If I plug a hub and my thermometer (which send the line #CT periodically before I unplug it in my test). The program recognize it without any problem.
USB Host Testing - Serial
*** Device Hub1 1a40:101 - connected ***
  product: USB 2.0 Hub
*** Device Hub2 1a40:101 - connected ***
#CT
#CT
#CT
*** Device USerial 483:5740 - connected ***
  manufacturer: STMicroelectronics
  product: STM32 Virtual COM Port
  Serial: CT000
#CT
#CT
#CT
#CT
*** Device USerial - disconnected ***
But when I try to plug another Teensy to my USB host nothing happen. (same thing with the HUB or without).
I digged a bit in the code and uncommented the line :
//#define USBHOST_PRINT_DEBUG in USBHost_t36.h to get a bit more informations. When I plug the teensy I get:
USB2 PLL running
 reset waited 6
USBHS_ASYNCLISTADDR = 0
USBHS_PERIODICLISTBASE = 20005000
periodictable = 20005000
port change: 10001803
    connect
port change: 1C001002
    disconnect
    connect
  begin reset
port change: 18001205
  port enabled
  end recovery
new_Device: 480 Mbit/sec
new_Pipe
enumeration:
enumeration:
enumeration:
Device Descriptor:
  12 01 00 02 02 00 00 40 C0 16 83 04 80 02 01 02 03 01
    VendorID = 16C0, ProductID = 0483, Version = 0280
    Class/Subclass/Protocol = 2 / 0 / 0
    Number of Configurations = 1
enumeration:
enumeration:
Manufacturer: Teensyduino
enumeration:
Product: USB Serial
enumeration:
Serial Number: 8823250
enumeration:
Config data length = 67
enumeration:
Configuration Descriptor:
  09 02 43 00 02 01 00 C0 32
    NumInterfaces = 2
    ConfigurationValue = 1
  09 04 00 00 01 02 02 01 00
    Interface = 0
    Number of endpoints = 1
    Class/Subclass/Protocol = 2 / 2 / 1
  05 24 00 10 01
  05 24 01 01 01
  04 24 02 06
  05 24 06 00 01
  07 05 82 03 10 00 05
    Endpoint = 2 IN
    Type = Interrupt
    Max Size = 16
    Polling Interval = 5
  09 04 01 00 02 0A 00 00 00
    Interface = 1
    Number of endpoints = 2
    Class/Subclass/Protocol = 10 / 0 / 0
  07 05 03 02 00 02 00
    Endpoint = 3 OUT
    Type = Bulk
    Max Size = 512
    Polling Interval = 0
  07 05 84 02 00 02 00
    Endpoint = 4 IN
    Type = Bulk
    Max Size = 512
enumeration:
USBHub memory usage = 960
USBHub claim_device this=20003C40
USBHub claim_device this=20003880
HIDParser claim this=20002C40
HIDParser claim this=20003260
HIDParser claim this=200046C0
USBSerial claim this=20004080
vid=16C0, pid=483, bDeviceClass = 2, bDeviceSubClass = 0, bDeviceProtocol = 0
09 04 00 00 01 02 02 01 00 05 24 00 10 01 05 24 01 01 01 04 24 02 06 05 24 06 00 01 07 05 82 03 10 00 05 09 04 01 00 02 0A 00 00 00 07 05 03 02 00 02 00 07 05 84 02 00 02 00
  Interface is Serial
    CS_INTERFACE - subtype: 0 10 1 - Header Functional Descriptor
    CS_INTERFACE - subtype: 1 1 1 - Call Management Functional
    CS_INTERFACE - subtype: 2 6 - Abstract Control Management
    CS_INTERFACE - subtype: 6 0 1  - union Functional
    Interface: 1
     Endpoint: 3
      tx_size = 512
     Endpoint: 84
      rx_size = 512
  exited loop rx:4, tx:3
Descriptor 4 = INTERFACE
Descriptor 36 =  ???
Descriptor 36 =  ???
Descriptor 36 =  ???
Descriptor 36 =  ???
Descriptor 5 = ENDPOINT
For comparison if I do the same with the termometer I get that:
USB2 PLL running
 reset waited 6
    connect
    disconnect
    connect
  begin reset
port change: 10001005
  port enabled
  end recovery
new_Device: 12 Mbit/sec
new_Pipe
enumeration:
enumeration:
enumeration:
Device Descriptor:
  12 01 00 02 02 00 00 40 83 04 40 57 00 02 01 02 03 01
    VendorID = 0483, ProductID = 5740, Version = 0200
enumeration:
enumeration:
Manufacturer: STMicroelectronics
enumeration:
Product: STM32 Virtual COM Port
enumeration:
Serial Number: CT00001
enumeration:
enumeration:
  09 02 43 00 02 01 00 C0 FA
    NumInterfaces = 2
    Interface = 0
  05 24 00 10 01
  05 24 01 00 01
  04 24 02 02
  05 24 06 00 01
  07 05 82 03 08 00 FF
    Endpoint = 2 IN
    Type = Interrupt
    Max Size = 8
    Polling Interval = 255
    Interface = 1
  07 05 03 02 40 00 00
    Endpoint = 3 OUT
    Type = Bulk
    Max Size = 64
  07 05 81 02 40 00 00
    Endpoint = 1 IN
    Type = Bulk
    Max Size = 64
enumeration:
vid=483, pid=5740, bDeviceClass = 2, bDeviceSubClass = 0, bDeviceProtocol = 0
09 04 00 00 01 02 02 01 00 05 24 00 10 01 05 24 01 00 01 04 24 02 02 05 24 06 00 01 07 05 82 03 08 00 FF 09 04 01 00 02 0A 00 00 00 07 05 03 02 40 00 00 07 05 81 02 40 00 00
  Interface is Serial
    CS_INTERFACE - subtype: 1 0 1 - Call Management Functional
    CS_INTERFACE - subtype: 2 2 - Abstract Control Management
    Interface: 1
     Endpoint: 3
      tx_size = 64
     Endpoint: 81
      rx_size = 64
  exited loop rx:1, tx:3
  rx buffer size:196
  tx buffer size:196
new_Pipe
new_Pipe
Control - CDCACM DTR...
*** Device USERIAL1 483:5740 - connected ***
  Serial: CT000
control callback (serial) 6
CDCACM setup: 00 C2 01 00 00 00 08
control callback (serial) 4
Control - 0x21,0x22, 0x3
control callback (serial) 0
rx token: 803B8100 transfer length: 64 len:5 - 23 43
rx: 23 43 54 0D 0A
#CT
rx token: 3B8100 transfer length: 64 len:5 - 23 43
rx: 23 43 54 0D 0A
#CT
rx: 23 43 54 0D 0A
#CT
rx: 23 43 54 0D 0A
#CT
rx: 23 43 54 0D 0A
#CT
rx: 23 43 54 0D 0A
#CT
rx: 23 43 54 0D 0A
#CT
rx: 23 43 54 0D 0A
#CT
rx: 23 43 54 0D 0A
#CT
rx: 23 43 54 0D 0A
#CT
rx: 23 43 54 0D 0A
#CT
rx: 23 43 54 0D 0A
#CT
rx: 23 43 54 0D 0A
#CT
rx: 23 43 54 0D 0A
#CT
rx: 23 43 54 0D 0A
#CT
rx: 23 43 54 0D 0A
#CT
rx: 23 43 54 0D 0A
#CT
rx: 23 43 54 0D 0A
#CT
rx: 23 43 54 0D 0A
#CT
rx: 23 43 54 0D 0A
#CT
rx: 23 43 54 0D 0A
#CT
rx: 23 43 54 0D 0A
#CT
rx: 23 43 54 0D 0A
#CT
rx: 23 43 54 0D 0A
#CT
rx: 23 43 54 0D 0A
#CT
rx: 23 43 54 0D 0A
#CT
rx: 23 43 54 0D 0A
#CT
rx: 23 43 54 0D 0A
#CT
rx: 23 43 54 0D 0A
#CT
It looks like some descriptors (Descriptor 36 = ???) are not recognized and the program just loop trying to get the missing informations.
If someone has an idea how to proceed from here it would be helpful.
Alex
Hi Alex,
I'm seeing a similar problem when connecting a Teensy 4.0 programmed as a MIDI device to a T4 USB Host port. In my case the same issue doesn't occur when connecting a T3.6 to the T4 USB Host port - so my issue occurs with High Speed USB and not with Full Speed USB, as with yours (one of your debug listings gives 480 Mbits/sec, while the other gives 12 Mbits/sec).
All the best,
Alan
You might try changing the example (or your sketch) from using USBSerial and instead try USBSerial_BigBuffer
It was setup to handle at the 480 MBits and larger packet sizes
indeed changing the line:
 USBSerial userial(myusb)
by
USBSerial_BigBuffer userial(myusb)
solved my problem.
Thanks a lot KurtE for the help :)
Alex
