1. I saw many projects done TSOP39338 receiver with a remoter, can TSOP39338 receiver receive signal from a IR LED? and how? no matter used one or two Arduino.
2. https://www.pjrc.com/teensy/td_libs_IRremote.html
said:
Transmitting
IRsend irsend;
Create the transmit object. A fixed pin number is always used, depending on which timer the library is utilizing.
irsend.sendNEC(IRcode, numBits);
Send a code in NEC format.
irsend.sendSony(IRcode, numBits);
Send a code in Sony format.
irsend.sendRC5(IRcode, numBits);
Send a code in RC5 format.
irsend.sendRC6(IRcode, numBits);
Send a code in RC6
irsend.sendRaw(rawbuf, rawlen, frequency);
does this mean that the IR LED can only send the 5 types data format above?
is this OK:
irsend.sendANY(anydate, numBits);
Send a code in ANY?
Adam
