Hello, I'm testing an audio project and would like to ask very basic questions:
I'm conneting a Korg Minilogue to Teensy Audio Line In, for now just trying to find the right gain without distortion.
I've put up a very simple sketch to listen input and plot peaks.
AudioAnalyzePeak peak1;
AudioInputI2S i2sInput;
AudioOutputI2S i2sOutput;
AudioConnection saida1(i2sInput, 0, i2sOutput, 0);
AudioConnection saida2(i2sInput, 0, i2sOutput, 1);
void setup(void) {
AudioMemory(8);
audioShield.enable();
audioShield.inputSelect(AUDIO_INPUT_LINEIN);
audioShield.volume(0.5);
if (peak1.available()) {
Serial.println(peak1.read());
Should I try to find the right gain, both in the instrument and audioShield.volume so the peaks aren't 1 or near, right?
I found I have to lower a lot the instrument gain like 25% to be OK.
Is there some way of lowering the line in gain? I suppose if I use a mixer after audioShield object it will already be clipping.
