dimitre
I'm working on this project with a custom object.
It is basically a recorder / looper. I've added 3 instances of this object and the line in instrument connected to a mixer4.
I've noticed if I use
it work OK but the audio output gain is very low after passing through the mixer.
and if I use
it plays back with the original level, but stop mixing with the original instrument source.
code here
https://github.com/dimitre/Slicer/tree/main/src
Thanks for any help or recommendations
audio_block_t *block = receiveWritable();
and if I use
audio_block_t *block = receiveReadOnly();
code here
