CAN communication between two teensy 4.1
I'm trying to communicate two teensy using CAN communication.
I connected VP230 to CAN1 to the first teensy using pins 22-23 for CTX1 and CRX1, and I connected the the CANL and CANH of the VP230 IC to CANL and CANH of a second IC that is connected to the second Teensy 4.1 board.
i checked with the oscilloscope and saw the CAN message from the first Teensy and after conversion to CANL and CANH and the CAN message is available, but when I connect the second Teensy to Read from it using also CAN1, the message on the oscilloscope disappear. My problem is i can't read the CAN message that I'm sending.
Can anyone help me to solve this problem or tell me if i have a connection mistake or coding mistake?
thank you in advance
This is my sender code:
#include <FlexCAN_T4.h>
FlexCAN_T4<CAN1, RX_SIZE_256, TX_SIZE_16> Can1;
#define sw1 35
#define sw2 36
void setup(void) {
delay(400);
Can1.begin();
Can1.setBaudRate(1000000);
Can1.setMaxMB(16);
Can1.enableFIFO();
Can1.enableFIFOInterrupt();
Can1.onReceive(canSniff);
Can1.mailboxStatus();
Can1.enhanceFilter(MB6);
void canSniff(const CAN_message_t &msg) {
Serial.print("MB ");
Serial.print(msg.mb);
Serial.print(" OVERRUN: ");
Serial.print(msg.flags.overrun);
Serial.print(" LEN: ");
Serial.print(msg.len);
Serial.print(" EXT: ");
Serial.print(msg.flags.extended);
Serial.print(" TS: ");
Serial.print(msg.timestamp);
Serial.print(" ID: ");
Serial.print(msg.id, HEX);
Serial.print(" Buffer: ");
for ( uint8_t i = 0; i < msg.len; i++ ) {
Serial.print(msg.buf, HEX); Serial.print(" ");
CAN_message_t msg;
msg.id = 0x1;
Can1.events();
enableMode();
CW();
CCW();
Exit();
void enableMode()
Serial.println("Enter Motor Mode");
CAN_message_t msg;
msg.id = 0x88;
msg.buf[0] = 0xFF;
msg.buf[1] = 0xFF;
msg.buf[2] = 0xFF;
msg.buf[3] = 0xFF;
msg.buf[4] = 0xFF;
msg.buf[5] = 0xFF;
msg.buf[6] = 0xFF;
msg.buf[7] = 0xFC;
Can1.write(msg);
void CW()
Serial.println("CW");
CAN_message_t msg;
msg.id = 0x1;
msg.buf[0] = 0x85;
msg.buf[1] = 0x52;
msg.buf[2] = 0x7F;
msg.buf[3] = 0xF0;
msg.buf[4] = 0x51;
msg.buf[5] = 0x11;
msg.buf[6] = 0xE7;
msg.buf[7] = 0xFF;
Can1.write(msg);
void CCW()
Serial.println("CCW");
CAN_message_t msg;
msg.id = 0x1;
msg.buf[0] = 0x7A;
msg.buf[1] = 0xAC;
msg.buf[2] = 0x7F;
msg.buf[3] = 0xF0;
msg.buf[4] = 0x51;
msg.buf[5] = 0x11;
msg.buf[6] = 0xE7;
msg.buf[7] = 0xFF;
Can1.write(msg);
void Exit()
Serial.println("Exit");
CAN_message_t msg;
msg.id = 0x1;
msg.buf[0] = 0xFF;
msg.buf[1] = 0xFF;
msg.buf[2] = 0xFF;
msg.buf[3] = 0xFF;
msg.buf[4] = 0xFF;
msg.buf[5] = 0xFF;
msg.buf[6] = 0xFF;
msg.buf[7] = 0xFD;
Can1.write(msg);
Receiver code:
#define debug(msg) Serial.print("["); Serial.print(__FILE__); Serial.print("::"); Serial.print(__LINE__); Serial.print("::"); Serial.print(msg); Serial.println("]");
void debug_pause(void)
Serial.print("Paused...");
while (!Serial.available());
while (Serial.available()) Serial.read();
Serial.println("Restarted.");
FlexCAN_T4<CAN2, RX_SIZE_256, TX_SIZE_16> Can2;
static CAN_message_t msg;
static uint8_t hex[17] = "0123456789abcdef";
static void hexDump(uint8_t dumpLen, uint8_t *bytePtr)
uint8_t working;
while( dumpLen-- ) {
working = *bytePtr++;
Serial.write( hex[ working>>4 ] );
Serial.write( hex[ working&15 ] );
Serial.write('\r');
Serial.write('\n');
void setup(void)
int iSerialTimeout = 1000000;
while (!Serial && (iSerialTimeout-- != 0));
debug (F("start setup"));
Can1.setBaudRate(1000000); // I like to set the baud rates just to be on the safe side
Can2.setBaudRate(1000000);
Can1.begin();
Can2.begin();
// t4 missing msg.ext = 0;
msg.id = 0x100;
msg.len = 8;
msg.flags.extended = 0;
msg.flags.remote = 0;
msg.flags.overrun = 0;
msg.flags.reserved = 0;
msg.buf[0] = 10;
msg.buf[1] = 20;
msg.buf[2] = 0;
msg.buf[3] = 100;
msg.buf[4] = 128;
msg.buf[5] = 64;
msg.buf[6] = 32;
msg.buf[7] = 16;
debug (F("setup complete"));
//debug_pause();
void loop(void)
msg.buf[0]++; //since you are in a loop i just incremented each time in stead of doing it 5 times
Can1.write(msg); //you could do it your way as well
Serial.println("T4.0cantest - Repeat: Read bus2, Write bus1");
CAN_message_t inMsg;
if (Can2.read(inMsg)!=0) // Changed this to if as as opposed to while - the way you had it just gets stuck since you haven't even sent a message yet
Serial.print("W RD bus 2: "); hexDump(8, inMsg.buf);
delay(20);
#define sw1 35
#define sw2 36
void setup(void) {
	delay(400);
	Can1.begin();
	Can1.setMaxMB(16);
	Can1.enableFIFO();
void canSniff(const CAN_message_t& msg) {
	for (uint8_t i = 0; i < msg.len; i++) {
		Serial.print(msg.buf[i], HEX); Serial.print(" ");
	CAN_message_t msg;
	msg.id = 0x1;
	Can1.events();
	enableMode();
	CW();
	CCW();
	Exit();
void enableMode()
	CAN_message_t msg;
	msg.id = 0x88;
	msg.buf[0] = 0xFF;
	msg.buf[1] = 0xFF;
	msg.buf[2] = 0xFF;
	msg.buf[3] = 0xFF;
	msg.buf[4] = 0xFF;
	msg.buf[5] = 0xFF;
	msg.buf[6] = 0xFF;
	msg.buf[7] = 0xFC;
	Can1.write(msg);
void CW()
	CAN_message_t msg;
	msg.id = 0x1;
	msg.buf[0] = 0x85;
	msg.buf[1] = 0x52;
	msg.buf[2] = 0x7F;
	msg.buf[3] = 0xF0;
	msg.buf[4] = 0x51;
	msg.buf[5] = 0x11;
	msg.buf[6] = 0xE7;
	msg.buf[7] = 0xFF;
	Can1.write(msg);
void CCW()
	CAN_message_t msg;
	msg.id = 0x1;
	msg.buf[0] = 0x7A;
	msg.buf[1] = 0xAC;
	msg.buf[2] = 0x7F;
	msg.buf[3] = 0xF0;
	msg.buf[4] = 0x51;
	msg.buf[5] = 0x11;
	msg.buf[6] = 0xE7;
	msg.buf[7] = 0xFF;
	Can1.write(msg);
void Exit()
	CAN_message_t msg;
	msg.id = 0x1;
	msg.buf[0] = 0xFF;
	msg.buf[1] = 0xFF;
	msg.buf[2] = 0xFF;
	msg.buf[3] = 0xFF;
	msg.buf[4] = 0xFF;
	msg.buf[5] = 0xFF;
	msg.buf[6] = 0xFF;
	msg.buf[7] = 0xFD;
	Can1.write(msg);
//Receiver code :
static void hexDump(uint8_t dumpLen, uint8_t* bytePtr)
	uint8_t working;
	while (dumpLen--) {
		Serial.write(hex[working >> 4]);
		Serial.write(hex[working & 15]);
	Serial.write('\r');
	Serial.write('\n');
void setup(void)
	debug(F("start setup"));
	Can1.begin();
	Can2.begin();
	msg.id = 0x100;
	msg.len = 8;
	msg.buf[0] = 10;
	msg.buf[1] = 20;
	msg.buf[2] = 0;
	msg.buf[3] = 100;
	msg.buf[4] = 128;
	msg.buf[5] = 64;
	msg.buf[6] = 32;
	msg.buf[7] = 16;
	debug(F("setup complete"));
	//debug_pause();
void loop(void)
	if (Can2.read(inMsg) != 0) // Changed this to if as as opposed to while - the way you had it just gets stuck since you haven't even sent a message yet
	delay(20);
Can you post your code between code tags, using the # button.
It makes it much more readable and you are more likely to get some help.
#define sw1 35
#define sw2 36
void setup(void) {
delay(400);
Can1.begin();
Can1.setMaxMB(16);
Can1.enableFIFO();
CAN_message_t msg;
msg.id = 0x1;
Can1.events();
enableMode();
CW();
CCW();
// Exit();
// delay(1000);
void enableMode()
CAN_message_t msg;
msg.id = 0x88;
msg.buf[0] = 0xFF;
msg.buf[1] = 0xFF;
msg.buf[2] = 0xFF;
msg.buf[3] = 0xFF;
msg.buf[4] = 0xFF;
msg.buf[5] = 0xFF;
msg.buf[6] = 0xFF;
msg.buf[7] = 0xFC;
Can1.write(msg);
void CW()
CAN_message_t msg;
msg.id = 0x1;
msg.buf[0] = 0x85;
msg.buf[1] = 0x52;
msg.buf[2] = 0x7F;
msg.buf[3] = 0xF0;
msg.buf[4] = 0x51;
msg.buf[5] = 0x11;
msg.buf[6] = 0xE7;
msg.buf[7] = 0xFF;
Can1.write(msg);
void CCW()
CAN_message_t msg;
msg.id = 0x1;
msg.buf[0] = 0x7A;
msg.buf[1] = 0xAC;
msg.buf[2] = 0x7F;
msg.buf[3] = 0xF0;
msg.buf[4] = 0x51;
msg.buf[5] = 0x11;
msg.buf[6] = 0xE7;
msg.buf[7] = 0xFF;
Can1.write(msg);
void Exit()
CAN_message_t msg;
msg.id = 0x1;
msg.buf[0] = 0xFF;
msg.buf[1] = 0xFF;
msg.buf[2] = 0xFF;
msg.buf[3] = 0xFF;
msg.buf[4] = 0xFF;
msg.buf[5] = 0xFF;
msg.buf[6] = 0xFF;
msg.buf[7] = 0xFD;
Can1.write(msg);
#include <isotp.h>
isotp<RX_BANKS_16, 512> tp; /* 16 slots for multi-ID support, at 512bytes buffer each payload rebuild */
void myCallback(const ISOTP_data &config, const uint8_t *buf) {
Serial.print("ID: ");
Serial.print(config.id, HEX);
Serial.print("\tLEN: ");
Serial.print(config.len);
Serial.print("\tFINAL ARRAY: ");
for ( int i = 0; i < config.len; i++ ) {
Serial.print(buf, HEX);
Serial.print(" ");
} Serial.println();
Serial.print("MB "); Serial.print(msg.mb);
Serial.print(" OVERRUN: "); Serial.print(msg.flags.overrun);
Serial.print(" LEN: "); Serial.print(msg.len);
Serial.print(" EXT: "); Serial.print(msg.flags.extended);
Serial.print(" TS: "); Serial.print(msg.timestamp);
Serial.print(" ID: "); Serial.print(msg.id, HEX);
Serial.print(" BUS: "); Serial.print(msg.bus);
} Serial.println();
Serial.begin(115200); delay(400);
Can1.begin();
Can1.setClock(CLK_60MHz);
Can1.setBaudRate(95238);
Can1.setMaxMB(16);
Can1.enableFIFO();
// Can1.onReceive(canSniff);
tp.begin();
tp.setWriteBus(&Can1); /* we write to this bus */
tp.onReceive(myCallback); /* set callback */
static uint32_t sendTimer = millis();
if ( millis() - sendTimer > 1000 ) {
uint8_t buf[] = { 1, 2, 3, 4, 5, 6, 7, 8, 9, 0, 1, 2, 3, 4, 5, 6, 7, 8, 9, 0, 1, 2, 3, 4, 5 };
const char b[] = "01413AAAAABCDEFGHIJKLMNOPQRSTUVWXYZ0123456789ABCDEFGHIJKLMNOPQRSTUVWXYZ0123456789ABCDEFGHIJKLMNOPQRSTUVWXYZ0123456789ABCDEFGHIJKLMNOPQRSTUVWXYZ0123456789";
ISOTP_data config;
config.id = 0x666;
config.flags.extended = 0; /* standard frame */
config.separation_time = 10; /* time between back-to-back frames in millisec */
tp.write(config, buf, sizeof(buf));
tp.write(config, b, sizeof(b));
#define sw1 35
#define sw2 36
void setup(void) {
delay(400);
Can1.begin();
Can1.setMaxMB(16);
Can1.enableFIFO();
CAN_message_t msg;
msg.id = 0x1;
Can1.events();
enableMode();
CW();
CCW();
// Exit();
// delay(1000);
void enableMode()
CAN_message_t msg;
msg.id = 0x88;
msg.buf[0] = 0xFF;
msg.buf[1] = 0xFF;
msg.buf[2] = 0xFF;
msg.buf[3] = 0xFF;
msg.buf[4] = 0xFF;
msg.buf[5] = 0xFF;
msg.buf[6] = 0xFF;
msg.buf[7] = 0xFC;
Can1.write(msg);
void CW()
CAN_message_t msg;
msg.id = 0x1;
msg.buf[0] = 0x85;
msg.buf[1] = 0x52;
msg.buf[2] = 0x7F;
msg.buf[3] = 0xF0;
msg.buf[4] = 0x51;
msg.buf[5] = 0x11;
msg.buf[6] = 0xE7;
msg.buf[7] = 0xFF;
Can1.write(msg);
void CCW()
CAN_message_t msg;
msg.id = 0x1;
msg.buf[0] = 0x7A;
msg.buf[1] = 0xAC;
msg.buf[2] = 0x7F;
msg.buf[3] = 0xF0;
msg.buf[4] = 0x51;
msg.buf[5] = 0x11;
msg.buf[6] = 0xE7;
msg.buf[7] = 0xFF;
Can1.write(msg);
void Exit()
CAN_message_t msg;
msg.id = 0x1;
msg.buf[0] = 0xFF;
msg.buf[1] = 0xFF;
msg.buf[2] = 0xFF;
msg.buf[3] = 0xFF;
msg.buf[4] = 0xFF;
msg.buf[5] = 0xFF;
msg.buf[6] = 0xFF;
msg.buf[7] = 0xFD;
Can1.write(msg);
#include <isotp.h>
Serial.print(" ");
} Serial.println();
} Serial.println();
Can1.begin();
Can1.setMaxMB(16);
Can1.enableFIFO();
tp.begin();
ISOTP_data config;
config.id = 0x666;
sender
#define sw1 35
#define sw2 36
void setup(void) {
  delay(400);
  Can1.begin();
  Can1.setMaxMB(16);
  Can1.enableFIFO();
  CAN_message_t msg;
  msg.id = 0x1;
  Can1.events();
  enableMode();
  CW();
  CCW();
//  Exit();
//  delay(1000);
void enableMode()
  CAN_message_t msg;
  msg.id = 0x88;
  msg.buf[0] = 0xFF;
  msg.buf[1] = 0xFF;
  msg.buf[2] = 0xFF;
  msg.buf[3] = 0xFF;
  msg.buf[4] = 0xFF;
  msg.buf[5] = 0xFF;
  msg.buf[6] = 0xFF;
  msg.buf[7] = 0xFC;
  Can1.write(msg);
void CW()
  CAN_message_t msg;
  msg.id = 0x1;
  msg.buf[0] = 0x85;
  msg.buf[1] = 0x52;
  msg.buf[2] = 0x7F;
  msg.buf[3] = 0xF0;
  msg.buf[4] = 0x51;
  msg.buf[5] = 0x11;
  msg.buf[6] = 0xE7;
  msg.buf[7] = 0xFF;
  Can1.write(msg);
void CCW()
  CAN_message_t msg;
  msg.id = 0x1;
  msg.buf[0] = 0x7A;
  msg.buf[1] = 0xAC;
  msg.buf[2] = 0x7F;
  msg.buf[3] = 0xF0;
  msg.buf[4] = 0x51;
  msg.buf[5] = 0x11;
  msg.buf[6] = 0xE7;
  msg.buf[7] = 0xFF;
  Can1.write(msg);
void Exit()
  CAN_message_t msg;
  msg.id = 0x1;
  msg.buf[0] = 0xFF;
  msg.buf[1] = 0xFF;
  msg.buf[2] = 0xFF;
  msg.buf[3] = 0xFF;
  msg.buf[4] = 0xFF;
  msg.buf[5] = 0xFF;
  msg.buf[6] = 0xFF;
  msg.buf[7] = 0xFD;
  Can1.write(msg);
Receiver:
#include <isotp.h>
    Serial.print(buf[i], HEX);
    Serial.print(" ");
  } Serial.println();
  } Serial.println();
  Can1.begin();
  Can1.setMaxMB(16);
  Can1.enableFIFO();
  tp.begin();
    ISOTP_data config;
    config.id = 0x666;
Also I tried this code for receiver but still didn't work
FlexCAN_T4<CAN1, RX_SIZE_256, TX_SIZE_16> can1;
FlexCAN_T4<CAN2, RX_SIZE_256, TX_SIZE_16> can2;
CAN_message_t msg;
void setup(void) {
  can1.begin();
  can1.setBaudRate(1000000);
  can2.begin();
  can2.setBaudRate(250000);
  if ( can1.read(msg) ) {
    Serial.print("CAN1 ");
    Serial.print("MB: "); Serial.print(msg.mb);
    Serial.print("  ID: 0x"); Serial.print(msg.id, HEX );
    Serial.print("  EXT: "); Serial.print(msg.flags.extended );
    Serial.print(" DATA: ");
    for ( uint8_t i = 0; i < 8; i++ ) {
      Serial.print(msg.buf[i]); Serial.print(" ");
    Serial.print("  TS: "); Serial.println(msg.timestamp);
  else if ( can2.read(msg) ) {
    Serial.print("CAN2 ");
