I can't see my own Teensy Board on PC
I designed my own Teensy Board to use the Teensy 3.1 infrastructure.
I followed Paul's instructions while performing the design. [https://www.pjrc.com/store/ic_mkl02.html]
I know there is no design sound.
Do I need to see any voltage at the oscillator pins of the MK20 chip? When I look through the oscilloscope, I can't see any DC voltage output.
SOLVED!!! BAD OSCILLATOR...
I changed the oscillator and problem is solved. I quickly see the Teensy 3.2 Interface after the changed with brand new oscillator...
If you has same problem, you can check this out.
- You may not post replies
- You may not edit your posts
Forum Rules
