Results 1 to 2 of 2
Thread: usbMIDI was not declared in this scope?
    I have been trying to send MIDI data over usb into the teensy 4.0. However, I cant wrap my head around the error message I am receiving "'usbMIDI' was not declared in this scope". I will post my code down below but I have included the MIDI.h library and my IDE is updated to version 1.56. I am using the boilerplate "inputFunctionsBasic" example from the examples tab. If anyone else has had similar issues I would love to hear your potential fixes.
    Thank you
    #include <MIDI.h>
      usbMIDI.setHandleNoteOn(myNoteOn);
      usbMIDI.setHandleNoteOff(myNoteOff);
      usbMIDI.setHandleControlChange(myControlChange);
      // The handler functions are called when usbMIDI reads data.  They
      // will not be called automatically.  You must call usbMIDI.read()
      // regularly from loop() for usbMIDI to actually read incoming
      // data and run the handler functions as messages arrive.
      usbMIDI.read();
    void myNoteOn(byte channel, byte note, byte velocity) {
      // When using MIDIx4 or MIDIx16, usbMIDI.getCable() can be used
      // to read which of the virtual MIDI cables received this message.
      Serial.print("Note On, ch=");
      Serial.print(channel, DEC);
      Serial.print(", note=");
      Serial.print(note, DEC);
      Serial.print(", velocity=");
      Serial.println(velocity, DEC);
    void myNoteOff(byte channel, byte note, byte velocity) {
      Serial.print("Note Off, ch=");
    void myControlChange(byte channel, byte control, byte value) {
      Serial.print("Control Change, ch=");
      Serial.print(", control=");
      Serial.print(control, DEC);
      Serial.print(", value=");
      Serial.println(value, DEC);
    28,001
    Usually usbMIDI not in scope means you need to click Tools > USB Type and configure the USB to be MIDI.
