This topic is about a Teensy 4.0 ultrasound microphone (open source project).
Our goal is to record bats echolocating sound with a simple device connected to a phone via his USB port. The samplerate is up to 384kHz.
Here is the Github page of the project.
Roadmap :
- Schematics of the board : Done. (link in Github project)
- PCB : Done. (link in Github project)
- High Samplerate : Done. Based on Frank B work
- Windows test : OK. pe1pwf have done a nice work figuring out the modification needed.
- Android test : NOK. Apps crash when trying to record.
i don't know how to debug this. I don't have any hardware USB analyser.
Anyone managed to get a USB Teensy microphone working with Android? I suspect a problem in the enumeration.
I managed to get a log on my phone :
Roadmap :
USB device attached.
checkUSBPermissions: id=1002 vendor=5824 class=0 name = Teensyduino
Device supported id=1002
No USB connection found for id=1002
USB device permission request.
Raw descriptors:
12 01 00 02 00 00 00 40 C0 16 D3 04 14 02 01 02 03 01 09 02 E9 00 04 01 00 C0 C8 09 04 00 00 02 03 00 00 00 09 21 11 01 00 01 22 21 00 07 05 82 03 40 00 01 07 05 02 03 20 00 02 08 0B 01 03 01 01 00 00 09 04 01 00 00 01 01 00 00 0A 24 01 00 01 3E 00 02 02 03 0C 24 02 01 01 02 00 01 00 00 00 00 09 24 03 02 01 01 00 01 00 0C 24 02 03 01 01 00 02 03 00 00 00 0A 24 06 31 03 01 01 02 02 00 09 24 03 04 02 06 00 31 00 09 04 02 00 00 01 02 00 00 09 04 02 01 01 01 02 00 00 07 24 01 02 03 01 00 0B 24 02 01 02 02 10 01 00 DC 05 09 05 83 09 00 03 04 00 00 07 25 01 00 00 00 00 09 04 03 00 00 01 02 00 00 09 04 03 01 02 01 02 00 00 07 24 01 03 03 01 00 0B 24 02 01 02 02 10 01 00 DC 05 09 05 03 05 00 03 04 00 84 07 25 01 00 00 00 00 09 05 84 11 04 00 04 07 00
fileDescriptor = 69
deviceName = /dev/bus/usb/001/002
manufacturer = Teensyduino
product = Teensy Audio
Configuration Descriptor:
Length: 233 bytes
1 Interfaces
Attributes: BusPowered SelfPowered
Max Power: 400mA
bDescriptorType=USB_INTERFACE_DESCRIPTOR bLength=9 bInterfaceNumber=0 bInterfaceClass=Human Interface Device bInterfaceSubclass=0x00 bAlternateSetting=0 bNumEndpoints=2
bDescriptorType=CS_DEVICE bLength=9
bDescriptorType=USB_ENDPOINT_DESCRIPTOR bLength=7 bEndpointAddress=130 type=Interrupt direction=IN
bDescriptorType=USB_ENDPOINT_DESCRIPTOR bLength=7 bEndpointAddress=2 type=Interrupt direction=OUT
bDescriptorType=11 bLength=8
bDescriptorType=USB_INTERFACE_DESCRIPTOR bLength=9 bInterfaceNumber=1 bInterfaceClass=Audio bInterfaceSubclass=AUDIOCONTROL bAlternateSetting=0 bNumEndpoints=0
bDescriptorType=CS_INTERFACE bLength=10 bDescriptorSubtype=HEADER bcdADC=0x000400
bDescriptorType=CS_INTERFACE bLength=12 bDescriptorSubtype=INPUT_TERMINAL bTerminalID=1 wTerminalType=0x000104 bAssocTerminal=0 bNrChannels=1
bDescriptorType=CS_INTERFACE bLength=9 bDescriptorSubtype=OUTPUT_TERMINAL bTerminalID=2 wTerminalType=0x000104 bAssocTerminal=0
bDescriptorType=CS_INTERFACE bLength=12 bDescriptorSubtype=INPUT_TERMINAL bTerminalID=3 wTerminalType=0x000104 bAssocTerminal=0 bNrChannels=2
bDescriptorType=CS_INTERFACE bLength=10 bDescriptorSubtype=FEATURE_UNIT bUnitID=49 bSourceID=3 bControlSize=1 iFeature=0
bDescriptorType=CS_INTERFACE bLength=9 bDescriptorSubtype=OUTPUT_TERMINAL bTerminalID=4 wTerminalType=0x000104 bAssocTerminal=0
bDescriptorType=USB_INTERFACE_DESCRIPTOR bLength=9 bInterfaceNumber=2 bInterfaceClass=Audio bInterfaceSubclass=AUDIOSTREAMING bAlternateSetting=0 bNumEndpoints=0
bDescriptorType=USB_INTERFACE_DESCRIPTOR bLength=9 bInterfaceNumber=2 bInterfaceClass=Audio bInterfaceSubclass=AUDIOSTREAMING bAlternateSetting=1 bNumEndpoints=1
bDescriptorType=CS_INTERFACE bLength=7 bDescriptorSubtype=AS_GENERAL bTerminalLink=2 bDelay=3 wFormatTag=1
bDescriptorType=CS_INTERFACE bLength=11 bDescriptorSubtype=FORMAT_TYPE bFormatType=1 bNrChannels=2 bSubFrameSize=2 bBitResolution=16 bSamFreqType=1 tSamFreq[0]=384000
bDescriptorType=USB_ENDPOINT_DESCRIPTOR bLength=9 bEndpointAddress=131 type=Isochronous direction=IN
bDescriptorType=CS_ENDPOINT bLength=7 bDescriptorSubtype=AS_GENERAL bmAttributes=0
bDescriptorType=USB_INTERFACE_DESCRIPTOR bLength=9 bInterfaceNumber=3 bInterfaceClass=Audio bInterfaceSubclass=AUDIOSTREAMING bAlternateSetting=0 bNumEndpoints=0
bDescriptorType=USB_INTERFACE_DESCRIPTOR bLength=9 bInterfaceNumber=3 bInterfaceClass=Audio bInterfaceSubclass=AUDIOSTREAMING bAlternateSetting=1 bNumEndpoints=2
bDescriptorType=CS_INTERFACE bLength=7 bDescriptorSubtype=AS_GENERAL bTerminalLink=3 bDelay=3 wFormatTag=1
bDescriptorType=USB_ENDPOINT_DESCRIPTOR bLength=9 bEndpointAddress=3 type=Isochronous direction=OUT
bDescriptorType=USB_ENDPOINT_DESCRIPTOR bLength=9 bEndpointAddress=132 type=Isochronous direction=IN
