emmanuel63
I have build a quite big polyphonic synth with many oscillators, and 3 LFOs. The patch is quite complicated with many cords.
To simplify the patch and the code, I tried a new approach for the LFOs section. My idea is to read the amplitude of my LFOs as fast as possible (2.9ms) with the Peak object, and use the result to modulate the oscillators parameters within the sketch. For polyphonic synths, I find it easier.
Do you think it is a valid solution ?
The audio lib is updated every 2.9ms. Is it fast enough to modulate smoothly oscillators pitch, shape, amplitude ? and filters FC ? My first tests seem to be OK except for amplitude modulation (little clicks).
Thanks for any advice.
Emmanuel
Emmanuel
