Hi everyone!
I'm trying to port code from Teensy 3.x to Teensy 4.0
I need help with the following lines of code that are for Teensy 3.x. They need to be refined so that they work on Teensy 4.0
I need this to run the TLC5940 chips
If I can I can fine-tune the standard library I tried to optimize these lines by looking at the code of the TimerOne TimerThree library and the code from manitou48 (https://github.com/manitou48/teensy4). But my attempts to understand in vain, firstly I don't understand which line is responsible for what, and secondly because there is no manual on how to configure timers on Teensy 4.0
Please, help
//BLANK_PIN -> pin 18 (A4) -> QuadTimer3 Module1
//XLAT_PIN -> pin 19 (A5) -> QuadTimer3 Module0
//GSCLK_PIN -> pin 5 -> FlexPWM2 Module1
#define set_XLAT_interrupt() FTM1_SC = FTM_SC_CLKS(1) | FTM_SC_CPWMS | FTM_SC_TOIE | (FTM1_SC & FTM_SC_PS(7))
#define clear_XLAT_interrupt() FTM1_SC = FTM_SC_CLKS(1) | FTM_SC_CPWMS | (FTM1_SC & FTM_SC_PS(7))
#define enable_XLAT_pulses() CORE_PIN3_CONFIG = PORT_PCR_MUX(3)|PORT_PCR_DSE|PORT_PCR_SRE
#define disable_XLAT_pulses() CORE_PIN3_CONFIG = PORT_PCR_MUX(1)|PORT_PCR_DSE|PORT_PCR_SRE
SIM_SCGC4 |= SIM_SCGC4_CMT;
CMT_MSC = 0;
CMT_PPS = 0;
CMT_CGH1 = TLC_TIMER_TEENSY3_NORMAL_CGH1;
CMT_CGL1 = TLC_TIMER_TEENSY3_NORMAL_CGL1;
CMT_CMD1 = 1;
CMT_CMD2 = 0;
CMT_CMD3 = 0;
CMT_CMD4 = 0;
CMT_OC = 0x60;
CMT_MSC = 0x01;
CORE_PIN5_CONFIG = PORT_PCR_MUX(2)|PORT_PCR_DSE|PORT_PCR_SRE;
FTM1_SC = 0;
FTM1_MOD = TLC_TIMER_TEENSY3_NORMAL_MOD;
FTM1_CNT = 0;
FTM1_C0SC = 0x24;
FTM1_C1SC = 0x24;
FTM1_C0V = TLC_TIMER_TEENSY3_NORMAL_MOD - TLC_TIMER_TEENSY3_NORMAL_CV;
FTM1_C1V = TLC_TIMER_TEENSY3_NORMAL_MOD - TLC_TIMER_TEENSY3_NORMAL_CV - 1;
FTM1_SC = FTM_SC_CLKS(1) | FTM_SC_CPWMS;
NVIC_ENABLE_IRQ(IRQ_FTM1);
CORE_PIN4_CONFIG = PORT_PCR_MUX(3)|PORT_PCR_DSE|PORT_PCR_SRE;
Please, help
